I'm at a loss, help please
Old May 17, 2008 | 02:11 PM
Hyperwrx's Avatar
Exclamation I'm at a loss, help please
86 Toyota with bad oil pump.
After trying to pop the bolt loose with the starter, the a dang 19mm bolt head is now rounded and I can't get a grip enough to work with it anymore (I was using 6 sided socket). Spent last 2 hours with impact hammer on the outside edge trying to get it to break loose and move- nothing. It's on TIGHT.
I am at a loss now as to how to get this bolt off.
Suggestions? Thanks in advance.
Old May 17, 2008 | 02:17 PM
jason191918's Avatar
Maybe a vise grip and the starter trick?
Old May 17, 2008 | 02:28 PM
jasond's Avatar
http://www.awdirect.com/easy-off-met...quipmenttools/
These work great, I think everyone should have at least one set.
BigBluePile's Avatar
Round bolt now, huh? Well, you could go to sears and get those really sweet bolt remover thingys...I'm too cheap for that. Here's some thoughts:
-hammer the next size smaller socket on(try a standard size socket)
-use a grinder and make new sides to the bolt head
-use pb blaster
-instead of the starter method, put the tranny in 5th or park. Then use something to jam the brake pedal to the floor. Should be about 24" in length I think.
-use the search function on this site...
-good luck!!!
Old May 17, 2008 | 02:30 PM
Another thing I just thought of. Weld a different bolt on top of that one.
Old May 17, 2008 | 02:33 PM
Yup, those are the ones I was thinking of!
puddlepirate
Jul 30, 2016 06:29 PM
shredder4286
Oct 1, 2015 01:09 PM
puddlepirate
Sep 29, 2015 08:02 PM
Shagool22
Sep 28, 2015 07:53 PM
charlie_fong
Sep 27, 2015 10:06 PM
