AagghHH! Someone please help...
Old Oct 5, 2016 | 03:06 PM
River92SR5's Avatar
So .. 92 4Runner SR5 out of the blue.. no gauges, power windows, and no climate control.
I have checked and replaced every fuse even a $9 pink one that I broke trying to check.. Moved on to the fusible link and got a new one as well as a new battery just in case. Runs good dash lights work radio works and the power windows work...
Where do I go from here? should I just take apart the dash, slap it around a bit and put it back together? .. maybe someone else in this world has had similar issue ..
Or at least a fix to get my windows back up..
Old Oct 5, 2016 | 04:03 PM
muddpigg's Avatar
Run the wires back. Check to see each connection and fuse till you find you have power. Then inspect wires between for damage.
Old Oct 5, 2016 | 05:03 PM
coopster's Avatar
From: exo-reality -wave if you see me; Front Range, CO
And also the grounds!
Old Oct 6, 2016 | 08:19 AM
RAD4Runner's Avatar
On the first-gen MoreFunner 22RE, that would be a problem on:
1) Power run TO the IG contacts of the ignition switch, OR
2) IG contact itself, OR
3) Wiring supplied by the IG contacts.Inspect and measure them all, like Muddpigg says ^^^
Re grounds stock grounding sucks.
Sand the mating surface between body and ring terminal of ground cable, so you have shiny bare metal touching. Coat bare metal surfaces with 100% silicone (di-electric) grease and re-connect.
GabrielRamos
Jul 15, 2016 05:30 AM
loganwolff
Jul 13, 2016 03:08 PM
PutzRunner
Jul 13, 2016 07:34 AM
orbt
Jul 10, 2016 10:38 PM
trbbhm
Jul 9, 2016 11:15 AM
