Sponsored by: CARiD
Electrical Issues on my 86 22r HELP!
Old Jul 14, 2016 | 04:37 AM
GabrielRamos's Avatar
Okay, so let me first start by saying I am no mechanic, and I am DEFINITELY not good with anything electrical. (I look at wiring diagrams like they are written in Ancient Cuneiform.)
Well, I love Toyota Trucks and recently purchased a new to me 1986 Pickup 4WD with the 22r Engine. After a day of driving it, I got home shut off the engine, and went inside. I came out later to start the truck and NOTHING. Just a "Click" noise coming from what sounded like under the hood near the starter relay. Well, I inspected the connections and did a little research and decided to replace the starter.
After installing the starter, the truck cranked right up and I drove it for a few days. But last night as I was driving home, I noticed my radio cut out, my headlights starting getting really dim, my dash lights got really dim and so I pulled over and cut the engine off. When I tried to start it again, there was the same "Click" sound and no start. Also my radio was on and working, but when I turned my headlights all the way on, it cut off, and the dash lights dimmed.
I rollstarted the truck and limped home (It's a manual) and parked. This morning the truck actually tried to start! But the battery was dead so I heard "click-click-click"
Here's my question following this lengthy post: Does this sound like an alternator problem, or God forbid something bad deep in the electrical system like a short, or bad ground, etc.?
Old Jul 14, 2016 | 11:54 AM
wyoming9's Avatar
Time to break out or buy a Multi meter !!
Get some real world voltage readings!!
First thing put the battery on the charger get it recharged
It could be a failed alternator
It might be a simple bad ground
If the wire from the B terminal of the alternator has never been changed they get old and brittle with age. Along with the other battery cables.
Old Jul 15, 2016 | 05:30 AM
Great news! I got home from work and checked all the connections and the alternator, and the alternator was COVERED in black sludge. So, I pulled the old one, got it tested and sure enough it was shot. Replaced it with a new alternator and been running and starting great. Let's hope this solved the problem. Thanks!
dixiemuddtoy
Oct 24, 2024 06:16 PM
leviathan278
Feb 26, 2016 12:02 PM
karlm-c
Feb 21, 2016 11:51 PM
adam_w1992
Feb 7, 2016 11:30 PM
dixiemuddtoy
Jan 31, 2016 12:06 AM
