Transmission is not shifting while, driving, only in park???
Old 11-10-2016, 08:58 AM
Diego toyota's Avatar
Well, guys I don't smoke cigarettes, I need one, two now. I just put a brand new clutch in my 91 22 re, exited about a test drive and it doesn't want to go in gears while driving. When I put it in park with the clutch in or not it goes into gear find. Please tell me I don't have to drop the transmission again. Help thanks.
Old 11-10-2016, 12:13 PM
wyoming9's Avatar
Red face
I only hope your just excited if you can put your Transmission in Park I can`t see how you have installed a clutch .
You meant to say Neutral Not Park !!!
Did you compare all the New Parts with the old parts ??
Except for wear they should have been the same !!
Did you forget to install the clutch fork with the clutch release bearing ??
Maybe Knock it off getting the transmission in place ??
Have the transfer case in neutral??
Forgot to install the driveshafts ??
I have done that a few times so glad to get the transmission in only to look and see the drive shaft standing beside the tool box
Old 11-10-2016, 04:59 PM
Staff
Terrys87's Avatar
I would check to see if the slave cylinder is good. Seems like once I pull a transmission, the slave cylinder fails afterwards. Now when I do a clutch I just replace the slave cylinder.
Old 11-10-2016, 05:29 PM
scope103's Avatar
DO check the clutch bracket.
https://www.yotatech.com/forums/f116...fatigue-32667/
Old 11-11-2016, 02:16 AM
Wyoming9, very funny!🤔 But to be honest, sadly I did not, the new clutch came in the kit and I slapped it in. Because of that response, I'll drop it again. As I drop it, I'll do the inspect the clutch fork with the release bearings. thanks.
Old 11-11-2016, 02:21 AM
Terrys87, I bled the slave cylinder to no avail. I'll drop the tranny, and do the inspection, you suggest changing the cylinder? Thanks!
Old 11-11-2016, 05:36 AM
no transfer case
Old 11-12-2016, 12:29 PM
Originally Posted by Diego toyota
no transfer case
well guys, I changed the slave cylinder, took it for a test drive,but putting it in reverse is struggle, any suggestions. Thanks again for all the help!
Old 11-18-2016, 08:19 AM
Well guys, I ended up, dropping the tranny, making sure the push out fork was sitting well with the push out bearing. This is what I did. 1. Changed the clutch slave an master cylinder, adjusted the clutch pedal. And it's been shifting in all gears pretty well. Thanks for the help guys. Love Yota world.
