locking hub/disk brake removal, help needed
Old Oct 6, 2016 | 03:53 PM
DanOfDoom's Avatar
Alright, right off the bat I apologize but I have searched and searched and apparently I am using the wrong words to describe my problem. I keep finding dead ends or am unable to find my issue. So here it is, and thanks in advance, I'm sure it's simple I just have never encountered this.
I cant seem to figure out how to remove the outer guard surrounding the hub. any amount of hitting or tapping and it bends, any tips, tricks or techniques will be appreciated.
Old Oct 6, 2016 | 05:24 PM
muddpigg's Avatar
Seems like I had to cut down the outside and peel off. That outer part is decoration only and not toyota.
Old Oct 7, 2016 | 03:06 AM
wallytoo's Avatar
looks like an american racing center trim piece. use a thin blade screwdriver to pry under the edge at the disc. stuck due to galvanic action.
Old Oct 7, 2016 | 12:43 PM
wyoming9's Avatar
Penetrating spray of your choice get something in there to help free it up.
Then you can fight with the cone washers
Old Oct 7, 2016 | 02:08 PM
ewong's Avatar
what they said
That "guard" is an inner trim ring for an aftermarket wheel
Basically - its not stock and never was stock.
Its galvanic "welded" to the brake rotor.
Remove it
Cut it with a dremel or
heat it wit a torch
Drill a hole and pry
But "rip" it off and throw it away
Old Oct 7, 2016 | 02:09 PM
ewong's Avatar
if you have to have another one to replace it......
https://www.summitracing.com/parts/a...MS1hoCoGvw_wcB
Old Oct 7, 2016 | 09:37 PM
DanOfDoom's Avatar
Thanks everyone, you were exactly right of course, super simple and non important. I ended up cutting them off and trashing them.
Old Oct 8, 2016 | 06:12 AM
muddpigg's Avatar
I never replaced mine and never will.
Old Oct 8, 2016 | 11:19 AM
DanOfDoom's Avatar
Same, not worth it at all in my opinion.
Old Oct 8, 2016 | 05:55 PM
Racersk's Avatar
Looks IDENTICAL to the 1st one I removed!
Same situation.
Old Oct 8, 2016 | 06:22 PM
ewong's Avatar
Back when my 1989 4Runner was new, I ordered some "white wagon" wheels via the local 4x4 shop.
The owner, Sam, asks me if I want the center caps for the wheels.
I say "will they make the truck go faster?"
He looks at me funny... "uh - no"
So I say "nope"
He says - good - cause they always end up rattling and I have to deal with irate customers...
theodolus
Oct 10, 2016 12:57 PM
chucknbach
Oct 5, 2016 01:48 PM
Eric Briden
Oct 2, 2016 09:33 AM
KidSheleen
Sep 23, 2016 04:13 PM
stener
Sep 16, 2016 08:23 PM
