Rolled pickup, what now?
Old Oct 12, 2016 | 11:41 AM
Yowzzerz's Avatar
I rolled my 93 v6 3.0 the other night and the engine stalled as soon as it rolled, adrenaline kicked in and I just wanted out once I got out I didn't want to crawl back in through the glass to turn the ignition off, even though I know I should have. Leaked a bit of oil in the garage nothing crazy, what now do I need to check anything before trying to start it up again, what is going to need fixed or replaced because of this?
Old Oct 12, 2016 | 12:31 PM
millball's Avatar
Remove plugs before first crank.
Might get away with just turning it over with breaker bar with plugs still in, but better safe than sorry.
Crank with plugs out first to insure no oil or other liquid is hydro-locking engine before replacing plugs and trying to start.
Old Oct 12, 2016 | 12:39 PM
wyoming9's Avatar
Red face
Don`t forget to just do the normal make sure the coolant is where it should be .
Cracked Radiator or cut hose.
What happened that caused this little mishap ??
Anything you get out under your own Power does not sound to bad .
It is when one goes for a ride on the Chopper things are interesting
Old Oct 12, 2016 | 02:11 PM
Yowzzerz's Avatar
What happened that caused this little mishap?
Just took a corner too fast on a dirt road and when I hit the ditch she flipped.
kooter77
Sep 8, 2016 11:37 AM
Jesse-James
Aug 21, 2016 03:03 PM
hmmwv15
Aug 11, 2007 07:27 PM
safado4
53
Nov 16, 2006 05:01 PM
