Flamethrower Injector kit pintle cap question
Old Oct 9, 2016 | 06:31 AM
toiyodah4WD's Avatar
I appreciate any replies. I don't have photo before I installed injectors --- I don't have job done yet, rain etc. Do the injectors as pictured on ebay have the pintle cap installed?? Grey top ones. I should have asked this question before installing. Compared to photos of injectors online, and the Denso ones I pulled out, it looks to me like there is no pintle cap on flamethrower injectors? Are the caps for end pointing into piston only. Confused newbie....
Old Oct 9, 2016 | 07:10 AM
I'm seeing photos of Flamethrower injectors with a black dome type cap on end that goes into fuel rail?? Do I need those caps? I greased 2 O rings per instructions, and put that directly into fuel rail.
Old Oct 9, 2016 | 10:13 AM
cbr600rx7's Avatar
The flame throwers come with every thing you need to install them. You reuse the lower injector cup that rests in the intake manifold. I replaced the little O rings on the cups with some from Toyota when I did mine.
Old Oct 9, 2016 | 11:15 AM
Thanks. Based on some forum photos it seemed they may have forgot to include "black pintle caps" in my kit. They mention pintle caps in ebay listing. As far as I can tell I installed injectors with no pintle caps. Proper O rings, grommets, but no "caps".
I may as well throw this question out. I Torqued rails to spec (12 foot pounds), but I could not by hand rotate injectors as it states in FSM. I did not try my hardest, but they are tighter in rail than FSM would suggest. Any thoughts on if this matters??
Grabbit89
Feb 1, 2023 01:36 PM
nbl300
Dec 6, 2016 03:52 AM
cryptkeeper
Sep 22, 2016 02:01 PM
sam_KOR
Sep 11, 2016 11:05 AM
satans4runner
Sep 11, 2016 07:41 AM
