Sponsored by: CARiD
Fuel injector ohms
Old Sep 20, 2016 | 09:09 AM
cryptkeeper's Avatar
Fuel injector ohms
who can tell me what the Ohm would be for 1995 toyota pickup fuel injectors ? Mine read 13 ohms, if that is low what would be the resin for that ? Just getting old and worn out ?
Old Sep 20, 2016 | 11:29 AM
91bluerunner's Avatar
The spec is 13.4-14.2 ohms for both the 4 & 6 cylinder engines. I would say that yes, yours are just getting old. I would have them flow tested and matched. Or just replaced all together. But 13 isn't that far off they're probably just dirty.
Old Sep 20, 2016 | 05:19 PM
Ok thanks, I will check the cost of new onces , and see if I can clean the others they have one whole , any input on a good brand or info on 3 or 4 wholes ,I have read some info on here but not what is good or bad, Thanks again 91 blue runner
Old Sep 20, 2016 | 06:36 PM
I got my 3rd gen injectors with adapters on eBay from a seller named injectordyne (not an endorsement, just who I happened to buy from). That was about a year ago and I haven't had any issues. Had a noticeable increase in throttle response after installation, I'm still very happy with that purchase.
Old Sep 22, 2016 | 11:38 AM
I checked the ohms again last night on my fuel injectors and they read at 16 ohms on some of the Utube sites some are saying any where between 14 - 17 should be good I still can't find anything on line, I don't understand why with the tech, you just can ask the qwestion and get the ans or a table that lists the in of, My Haynes manuel doesn't even say anything. Or what voltage they fire at are there any wed sites that are free that can help ?
Old Sep 22, 2016 | 11:45 AM
Terrys87's Avatar
Per Haynes Manual Page 4-2, 89 and on is 13.4-14.2
What I went thru on my injectors. https://www.yotatech.com/forums/f199...l#post51897320
Are they firing? https://www.yotatech.com/forums/f116...t-22re-270857/
Old Sep 22, 2016 | 11:49 AM
wyoming9's Avatar
Your just reading the coil that has nothing to do with weather they are dirty
Just that the coil is not open .
Old Sep 22, 2016 | 01:03 PM
Thanks Terrys87 and wyoming9 , I went back to the Haynes and looked where you said and there it was , I must of just looked at it to fast and missed it, so if the coil is open I will not get the reading of 13.4 - 14.2 ohms , I'm going to flush the injectors will that help ? I'm just trying to see if they are good and just buy some rebuild kits, I'm on limited funds.
Old Sep 22, 2016 | 01:41 PM
Terrys87's Avatar
To test them, I take a syringe, battery, hose, and some leads https://www.yotatech.com/forums/f116...jector-295953/ this is a test that will tell you if the injectors are working. Use a 9 volt battery.
Old Sep 22, 2016 | 02:01 PM
Ok I will Try that , Thanks
96taco4x4
Feb 6, 2020 05:16 PM
nbl300
Jul 27, 2018 09:34 AM
nuknuk
Dec 11, 2016 08:13 AM
ryanespi
Aug 8, 2016 04:56 PM
pursang
Jul 9, 2016 01:48 AM
