Transmission Shut Down
Old May 26, 2006 | 09:54 AM
bluetick73's Avatar
Question Transmission Shut Down
I have a '94 4Runner, 3.0/auto. All was ok until I just changed the power steering belt and battery. Started it up and the tranny just slips as if in neutral - does nothing in any gear. I am completely confused here. I cannot imaging the tranny going south all of a sudden. Fluid is good and proper level. Is there any electronics to check that may shut down the tranny? Truck runs great otherwise.
TIA,
Jerry
Old May 26, 2006 | 04:34 PM
regularguy412's Avatar
Are you getting any codes from the O/D Off Light on the dash? Press the O/D switch on the shifter and turn the O/D ON. That makes the dash light go out. Then jumper the Te1 and E1 pins in the diagnostic port ( just like if you were gonna read the CEL codes from the Check Engine Light). The auto tranny has a flash sequence similar to the engine code sequence. The O/D Off light will flash with a code, if it has one stored. Otherwise, it will just flash at a constant rate (no pauses). You may get some info there. Post what you find there, if anything.
Mike in AR
Old May 27, 2006 | 09:53 AM
bluetick73's Avatar
The OD light is not flashing. The light does operate correctly. No error codes stored.
Jerry
Old May 27, 2006 | 10:14 AM
Did you check to see if the mechanical linkage from the shifter to the tranny is still intact and properly adjusted? My shifter has a little 'play' in it. I've been 'making sure' it is in 'D' for so long , now, when I shift out of Park / Reverse, that I do it subconsciously. If the linkage has somehow come apart, the shifter will move, but won't actually engage the tranny.
If I put my tranny in Drive and it's actually sort of 'hung' between detents (compared to the P-R-N-D-2-L on the shifter housing), I can drive down the road, but tranny never shifts out of 2 and the engine just continues to wind up.
Here's a link to the troubleshooting page for the A340H:
http://personal.utulsa.edu/~nathan-b...30generalt.pdf
Mike in AR
Old May 27, 2006 | 10:21 AM
mr toytech's Avatar
also check to make sure the transfercase isnt in neutral. may of got bumped.
Jwp1
Sep 6, 2015 11:03 AM
Wardog
Sep 6, 2015 07:57 AM
eggens
Sep 5, 2015 12:16 AM
BigMike
Marlin Crawler
Sep 3, 2015 07:49 PM
kelly1450
Sep 2, 2015 12:29 PM
