Rebuilt the whole darned thing and now it just clicks when I turn the key.
Old May 17, 2006 | 11:08 AM
jluce's Avatar
I rebuilt the head, water pump, oil pump, exhaust header, fuel injectors, and now all I get is a click when I turn the key. What are the odds that my starter just died... what else could it be... what order should I check things to get it started....
? battery to starter
? ignition switch
? solenoid
Old May 17, 2006 | 12:38 PM
PeanutRanger's Avatar
Hey
My runner likes to click too sometimes, on mine its the starter. When you try to start it and it clicks do you keep trying back to back or just not try that much again. Mine when it acts up i sometimes i have keep turning the key, sometimes 3 times sometimes 30, i snatched my starter out filed the carbon off the contacts and put it back in! Works FINE!
Old May 17, 2006 | 01:16 PM
AH64ID's Avatar
Is it clicking on the starter or behind the dash? Could be two different things.
Old May 17, 2006 | 02:14 PM
jluce's Avatar
I think it is clicking behind the starter... I'll try taking it off and filing the carbon thingy. Hey ah64ID... my nephew is a mechanic on the ah65... just got back from iraq about 2 months ago...
Old May 17, 2006 | 05:24 PM
AH64ID's Avatar
Very nice, we appreciate the heck out of those guys... They do the hard job, we do the fun one
Old May 18, 2006 | 05:05 AM
maxpower_hd's Avatar
I had to replace the ground wire that goes from the head to the firewall during my rebuild because it was so corroded. May not be the problem but it's something easy to check.
Old May 20, 2006 | 10:35 AM
StoogeBrother's Avatar
Also check the wire from the pos. battery terminal to the fuse box. That is a common source of .. no start... probs.
Old May 24, 2006 | 11:21 AM
surfmobile's Avatar
what could be wrong if it's clicking behind the dash? my 86 4runner wont start either it just clicks behind the dash. Actually its more behind the passenger side wall (where the ECU sits)
Old May 24, 2006 | 11:37 AM
95RunnerSR5's Avatar
possible short?
Old May 24, 2006 | 11:39 AM
rdlsz24's Avatar
My truck was doing this a couple weeks ago. It turns out the negative connection on the battery was loose.
Rob
Old May 24, 2006 | 12:46 PM
881stGenRunner's Avatar
Men did fall off too, but if it did he would absolutely NOTHING, no clicks or anything, no power going to anything. I replaced my starter, didnt want to worry about taking it out again after how much of a B-Hole it is to take out. (96.00 with core charge at Advanced Auto Parts)
Old May 24, 2006 | 01:49 PM
toyaholic's Avatar
low battery charge, dirty or loose terminal connectors, or possibly bad starter. get someone to beat your starter with a hammer while you try to start it.
razorman8669
Jul 12, 2015 12:13 PM
shar
Jul 9, 2015 12:38 PM
colinmil
Jul 6, 2015 04:03 PM
wilbertd
Jul 6, 2015 07:39 AM
karbin
Jul 5, 2015 11:37 PM
