rear window nothing but click click
My rear window will not go back up. I hear a click when I try to roll it up but no movement or other sounds. I did read other posts and Roger Browns write-up but sounds to technical for me. Everything looks really clean, all grounds and connections look good. Motor or Relay?
Is the clicking from the front or the back? I ran into problems with the notches grinding them selves down, so the clicking was the gears slipping past each other. I ended up taking the door apart, and building up the gear material by welding and grinding.
Well I got kind of lucky because I found the problem right way. The first thing I did was take a test light and found I had power to the motor. So I bought one from the wrecker ($125) and it took about an hour to install. Works smooth and lot faster than before.
Jun 1, 2021 01:51 PM
sabine
Jul 18, 2015 03:59 PM
icentropy
Jul 14, 2015 10:23 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
Jul 6, 2015 04:07 AM
