4runner rear window roll down
Old May 30, 2006 | 11:44 AM
funrunner91's Avatar
hey guys, i really need help on this one. i have a 91 4runner, my gate was hit and bent in about 3 inches. the window wont roll all the way down. i found a donor 4runner with a perfect rear window. the problem is that there is no battery, no engine, and no key......is there a way to splice one of the wires from the rear window switch to power that rear window to roll it down???? since that seems to be the only way to get the gate off
Old May 30, 2006 | 11:49 AM
Red3.slow's Avatar
look in a manual and find out where wires run for that motor and hook up a battery. or possibly use the connections in the center console
Old May 30, 2006 | 11:56 AM
i will buy that manual today. useing the center console is exactly what i want to use. witch wire is my hot wire that i can connect to my battery? and witch one is the ground? also will these wires run to a relay in the engine bay or fuse? because everything in the engine is gone
Old May 30, 2006 | 12:04 PM
snap-on's Avatar
im looking at the wiring diagram now... its not that easy....
the best bet would be to hotwire the motor in the back after pulling off the access pannel. then you can bypass the safty switches/relays for a WHOLE bunch of things. (rear gate open, rear wiper on, key on, window lockout etc)
Old May 30, 2006 | 12:18 PM
the engine was removed with the battery and something that connected from the battery to the inside of the truck???? i'm going to get the manual right now and see if this might work. if this does not work do you think i should bust the widow out and take the gate, them buy a window????
Old May 30, 2006 | 12:20 PM
snap-on's Avatar
no reason to bust the window!....
at the most you would have to disable the regulator in the tailgate and "manually" take the window down/out
Old May 30, 2006 | 01:04 PM
ok so i got the manual and when i get home i will read it and practice on my truck.... i will post pictures of mine to see if you guys think it could be repaired, dent pulled or something....thanks
Old May 30, 2006 | 08:17 PM
^VooDoo^'s Avatar
Pull on the carpetplate (pops right off) Pull the plastic cellephane sheet from the drivers side to the passengers side halfway, you will see the window motor, Pull the plug and use jumperwires to activate the motor ( It is polorized, Flip polarity to go up and down.)
You can even do it while the door is laying down.
Old May 30, 2006 | 09:30 PM
ok that i will try this weekend when i drive out to my donor truck, it's an hour away so just incase i dont get it right and the sun starts going down can i do this, again just in case. here is my truck's gate
and here are three bolts on both sides that i can reach from underneeth the truck
can someone with a nd gen take a picture or two witch their tail gate down and pictures of the hing and bolts....hopefully this is a quick way to drop the back gate
Old May 30, 2006 | 09:32 PM
also can someone take a picture of the molding that goes around the rear window, a picture from there inside with the window down....thanks guys
Old May 31, 2006 | 09:13 AM
can someone take a picture of the hinges on your tailgate when it is down on a 2nd gen 4runner??????? please
Old May 31, 2006 | 12:44 PM
please??????
Old May 31, 2006 | 07:52 PM
Old Jun 1, 2006 | 09:13 AM
just one picture????
Jun 1, 2021 01:51 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
CJ94yota
Jul 3, 2015 10:14 PM
