Front side gear shaft play and noise
Old May 30, 2006 | 01:27 PM
Lanman's Avatar
On my 1994 4Runner, 3vze I hear a clicking sound when I am driving. It's louder when I hit road bumps. The sound started about a month ago.
I looked under, by the front drive shaft and the side gear shaft off the differential and found some movement on what the six bolts are on. It is not the bolts. The bolts are tight.
When I move/wiggle the drive shaft I hear the click sound. There is play at the side gear shaft end where it connects to the drive shaft.
Do I have to replace the drive shaft or the side gear shaft? or both?
Can I just add lithium grease to the drive shaft boot?
Can I just add oil to the differential case?
The differential case looks dried and has some rust patches.
What is the price range for the shafts?
What is the resolution? DIY, dealer or local shop?
Thanks for any help ...
Old May 31, 2006 | 05:32 AM
Lanman's Avatar
The local mechanic says all is fine with drive axle, the shocks are bad. He advises to change the shocks to KYB.
I hope this clear the noise.
Old Jun 2, 2006 | 07:34 AM
Red3.slow's Avatar
same problem with mine, I've had inner spindle bushings recommended to me.
Ichneumon
Sep 27, 2015 04:21 PM
Dillon1983
Jul 7, 2015 06:47 PM
Vargntucson
Jul 4, 2015 12:15 PM
Mr.Black
Jun 21, 2015 10:17 AM
