engine rattle
Old May 29, 2006 | 11:17 AM
kceb10's Avatar
engine rattle
I'm looking into buying a 93 truck with a 22re that has about 150k miles. they are selling it for cheap but the engine has a loud rattle noise comeing from the top of the engine all the time they had the valves adjusted at a local shop and didnt help with the noise. looks like the front cover was removed not to long ago and the shop that adjusted the valves said it looks like someone just put a timing chain in it.
the truck is on a friends car lot just got it from auction
Old May 29, 2006 | 11:24 AM
kceb10's Avatar
also the truck runs fine but has no power
Old May 29, 2006 | 12:19 PM
91_4x4runner's Avatar
How bad is the rattle? Is it like this one?
https://www.yotatech.com/forums/f116/listen-my-engine-79991/
Old May 29, 2006 | 01:33 PM
kceb10's Avatar
ya it sounds like that. The noise is pretty loud. any ideas what it could be should i buy the truck?
Old May 30, 2006 | 06:31 AM
kceb10's Avatar
any ideas?
Old Jun 10, 2006 | 05:27 AM
Biker_1450's Avatar
Let me know what you find out as I just bought a 92 with the VERY same problem...I have had the valves ajusted twice by two diff mech. and still the very same tick.
Old Jun 10, 2006 | 08:34 AM
kyle_22r's Avatar
timing chain tensioner could be shot. if it's overtightened or something gets in it, it will stop working. i had this problem and it started about 6 months after i installed a new one. i think it was engine sludge -- i just said F it and tore the whole engine apart...
Old Jun 10, 2006 | 10:30 AM
1989toy4wd's Avatar
Cool
Mine makes that same sound, since I bought it, and I have put about 10k miles on it. The only thing that gets me is that you said that it has no power, maybe you are just used to something with a bigger engine, these toyota pickups arent racecars in any way, shape, or form. You may have a rod knock or something, which is serious, if its a rod knock, then you are going to have to rebuild it anyways, so just drive it around, if it gets worse have it checked out by a mechanic. It is hard to diagnose sounds on a computer
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
