Question on 94 3vze engine
Old May 20, 2006 | 10:30 AM
scrid's Avatar
Hey all, are these 3vze engines a &*tch to take out or what.
I may be buying a 94 with a locked engine and was wondering ahead of time.
Old May 20, 2006 | 12:11 PM
Elton's Avatar
did a search
https://www.yotatech.com/forums/show...ne+removal+3.0
https://www.yotatech.com/forums/show...e+removal+3vze
Old May 20, 2006 | 12:59 PM
DirtCheap's Avatar
Pulling the engine was a real pita but it was worth it. Drop the rear of the trans a few inches to get to the top bellhouse bolts. You'll need a long extension and swivel for the top bolts. I, also suggest you install headers since the factory exhaust is suggested to cause the overheating problems. Take a lot of pics, especially of the hoses.
If you choose to install headers it is a lot easier since the headers will go on after the engine is in.
Good Luck
Old May 20, 2006 | 01:13 PM
Ganoid's Avatar
I pulled mine twice now but I have a 1.5" body lift to clear my headers. Once you do it a few times its not bad at all in fact I would pull the motor to do head gaskets.
Old May 20, 2006 | 05:15 PM
tc's Avatar
tc
Do a search on the 3.4 (5VZFE) swap
Old May 21, 2006 | 07:28 AM
95RunnerSR5's Avatar
its not very difficult to pull, just be sure to label all hoses, connections, sort the bolts/nuts into marked bags...i just finished this last week and putting it back in was a breeze, only took about four hours. good hunting
bigjstang
Jun 2, 2025 03:56 PM
kazuya2416
Apr 5, 2024 02:17 AM
smiley52
Jul 11, 2015 05:16 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
