Engine knocks when starts
Old May 18, 2006 | 04:38 PM
pat2724's Avatar
I have a 95 pickup with 22 re motor with 84,500 miles on it and it knocks for like secomd when it starts. Is this normal? How can I stop it? I just put amsoil 5w30 synthetic oil it and it still does it ....
Old May 18, 2006 | 09:51 PM
Chuki's Avatar
whats your oil pressure like?
Could also be your timing chain, slapping a little till the oil tensioner takes up the slack.
Old May 19, 2006 | 03:57 AM
Flash319's Avatar
That is normal as far as any 22RE FI I know. Like Chuki said the oild presure needs to take up the slack in the timing chain, also these engines run on the lean side so you get a knock until the ECU sorts everything out.
Old May 19, 2006 | 04:42 PM
subliminaltrips's Avatar
mine does too and its a fresh motor. my oil psi is way up at 75 psi at 3000 rpm when the engine is cool.
Old May 20, 2006 | 08:48 AM
miket223's Avatar
I'd consider the timing chain slack issues these engines love to have. That LH chain guide likes to fall apart and make all kinds of racket. This problem eventually leads to a hole in the timing cover which will fill the engine's oil sump with coolant.
Old Jun 8, 2006 | 05:47 PM
pat2724's Avatar
I replaced the head gasket and the timing chain tensioner 2 months ago. The truck runs mint but I am a little nervous about the slight knock when starting. It only does when motor warmed up and sits for a little bit. When cold does not do it. I am running amsoil 5w30 synthetic.
What would happen if I ran thicker oil? 20w50??
Old Jun 8, 2006 | 07:27 PM
Chuki's Avatar
1st of all I would get rid of the 5w30 and go with at least 10w30...
although my new fav oil has become amsoil 15w40 synthetic, I give my hybrid engine hell, and I was recommended that if I do alot of slow crawling or high rpm that a 15w40 would be a good engine oil to use.
Old Jun 10, 2006 | 05:33 AM
86_runner's Avatar
Oil thins as it heats and tends to leak off pressure quicker, like the timing tensioner. I agree with chuki use a thicker oil.
Old Jun 10, 2006 | 10:34 AM
1989toy4wd's Avatar
Dont worry about it, most vehicles new and old all knock when first started up, it is only bad if it starts doing it when you are driving! My dads 2003 Silverado knocks when first starting up sometimes, so dont worry about it. Mine does too!
Old Jun 11, 2006 | 04:45 PM
84sr5yoty's Avatar
Yeah, it's called piston slap. I read that it's considered normal for the 22r series motors to do this, even though mine never has in 22 years. Don't worry about it until the knocking is continuous with a warm motor.
By the way, what weight motor oil are you using? Use nothing below 10-30.
Old Jun 11, 2006 | 05:15 PM
pat2724's Avatar
I am using 5w 30 and am thinking about switching it to castrol high mileage oil.... it has only 85,000 miles and runs mint.
Any opinions on the high mileage oils???
Old Jun 11, 2006 | 06:14 PM
84sr5yoty's Avatar
Aha! Yeah, 5-30 is too thin for these motors....well, not the bottom end, but the whole rocker assembly was setup to use 10-30 or thicker. It gets noisy with thinner oils.
As far as oil, a couple of years ago I would have said, "Use anything and you'll be fine." Things have changed though.
Starting around 2001, oil makers were required to practically eliminate the amount of zinc in their oils because zinc is a little hard on catalytic converters. Yeah, that's fine and dandy for roller rocker motors, but zinc is MANDITORY for conventional rockers, or cams and rocker arms (or lifters if it's that design) will be damaged. That's is exactly what is happening. Older pushrod motors are wiping cam lobes and dishing lifters. I don't know about the 3.0, but the 22re is NOT a roller rocker design and REQUIRES zinc in the oil
The common practice now is to either use oil containg a high amount of zinc, or use a supplement such as STP oil treatment or GM’s EOS (Engine Oil Supplement). In my 59 Pontiac, I use both. Shell Rotella 15-40 contains a higher amount of zinc than all but a few motor oils so I use that only in the Toyota. I use 15-40 Shell Rotella and STP oil treatment in the Pontiac.
voiddweller
19
May 2, 2016 09:10 PM
miah
Jul 6, 2015 06:39 AM
puddlepirate
Jun 30, 2015 05:08 PM
rbravo1
Jun 29, 2015 01:34 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
