1994 steering stops
Old May 18, 2006 | 06:25 PM
Lanman's Avatar
1994 steering stops
On the 1994 4Runner 3vze. Where is the steering stops located? What do they look like? Any pics?
I have a noise when making right or left turns. It sounds like something grinding, skipping. the noise is intermitten. Sometimes it does not make any noise on turns.
I want to try and fix it myself before I have a mechanic check it.
Thanks for any assistance ...
Old May 18, 2006 | 06:31 PM
ChickenLover's Avatar
Do a search. You'll find some pics. Just smear some grease on the stops and the noise will stop. No need to take it to a mechanic.
Old May 18, 2006 | 09:30 PM
bike4miles's Avatar
Just poke your head in the wheel well and you will see the "pins" that hit the stops. Gota smear some grease on em now and then. Ever 6 months or so.
Old May 19, 2006 | 10:17 AM
celica's Avatar
has anyone tried adjusting the stops to reduce your turning radius?
Old May 19, 2006 | 11:19 AM
snap-on's Avatar
dude i have a EX cab. if my turning radius gets any larger im gonna need a dude with flashlight cones to direct me!
Old May 19, 2006 | 11:22 AM
eric-the-red's Avatar
For those of you in wet climates I found antisieze lasts longer than grease on the steering stops. It doesn't seem to wash away as quick.
Old May 19, 2006 | 11:41 AM
snap-on's Avatar
oh wait... now that i read that again... are you saying makeing the turning radius smaller! (thus the use of the word reduce) :pat:
anyway if your talking about makeing sharper turns i dont think that works because the CVs bind expecially when flexed
Old May 20, 2006 | 08:50 AM
miket223's Avatar
Also, don't worry about it. These steering stops were a faulty design and always make horrendous noises that get you funny looks. Just grease it, that is all you can do.
Old May 21, 2006 | 11:00 AM
Bobakazi's Avatar
Mine were cut off before I bought my truck. I have never had a problem, and never hear any noise at full lock. I am not necessarily advise this, maybe somebody else will chime in the pros and cons.
Old May 21, 2006 | 06:43 PM
Lanman's Avatar
Found them and greased them. The caps are there but the tips of it are gone. No more noise for a while. Thanks ...
Old May 22, 2006 | 10:21 AM
That's usually what happens, the tips contact the steering stops and wear out. Just keep them lubed and it'll be quieter.
Old Jun 21, 2006 | 10:15 AM
kt19's Avatar
Has any body bought the new caps? If so where and are they worth it. I drive on a dirt road daily and I'm sure that the grease will get full of dirt and rocks.
Old Jun 21, 2006 | 10:18 AM
TNRabbit's Avatar
Probably not worth it unless you are just anal. Grease works fine. don't forget both sets.
Old Jun 21, 2006 | 02:07 PM
celica's Avatar
I think when I first got the truck the caps were $7 each canadian, so probably about $5 a piece in the states
Old Jun 21, 2006 | 02:30 PM
jbd202's Avatar
Mine make that noise all the time. I'm just to lazy to grease them. I have done it a few times. It is really funny when you are in a parking lot and making a tight turn near other cars and they start making noise. People give you some funny looks.
Old Jun 21, 2006 | 05:35 PM
Elton's Avatar
steering stops http://www.4x4wire.com/toyota/mainte...ront_end/lube/
Old Jun 21, 2006 | 06:13 PM
javadoody's Avatar
i was missing two complete stops, rubber on the others and when i went in checked and found out you can't just get the caps anymore. new replacements were brass. work fine with grease.
Doug4320
Mar 24, 2018 10:11 PM
Road Bull
Oct 10, 2015 04:55 PM
delmert
Sep 30, 2015 04:34 PM
Scotto6591
Sep 1, 2015 03:24 PM
JHalcyonM
Aug 4, 2015 01:19 PM
