Is a 3.slow a Zero Clearance Motor?
Old May 28, 2006 | 05:25 PM
Twinkie's Avatar
Scenario: 4000RPM, low range, 2nd gear, in a minor mud hole. Rolled out of the hole with no power, truck then would not start. Disty isn't turning so I'm guessing the timing belt, BUT, is the 3.0 a 0 clearance motor? Are my valves done?
I'm probably gonna do the belt with a buddy anyway, but should I get my hopes up?
Old May 28, 2006 | 05:40 PM
DirtCheap's Avatar
The 3.0 is a noninterference engine. If the belt broke the valves will not make contact with the piston.
Good Luck
Old May 28, 2006 | 05:51 PM
Twinkie's Avatar
Well I hope it's just the timing belt then. Is it at all common for the distributor shaft itself to break?
Old May 28, 2006 | 05:59 PM
Elton's Avatar
i think it all depends on how many miles it has
Old May 28, 2006 | 06:05 PM
DirtCheap's Avatar
I, would think the TB is the problem. I, broke a TB three months ago and the dist was the first thing I, checked. It wouldn't turn as I cranked the engine which was due to the broken TB.
Old May 28, 2006 | 06:07 PM
Twinkie's Avatar
Yah, I'm just going over everything in my head. It was a fun 4 days of wheeling, broke in the last 2 hours which was a crappy ending to the weekend. Now my mind is turning a mile a minute going over all the possible problems/causes.
Old May 29, 2006 | 01:28 AM
Bumpin' Yota's Avatar
yea, the distributor is driven by the driver's side cam, which is turned by the timing belt. Personally in over 2 or 3 years Ive been on this board, I have never heard of a distributor shaft breaking... Timing belts are cake on the 3.0..
Old May 29, 2006 | 08:14 AM
tc's Avatar
tc
How minor a mud hole? Sure you didn't hydrolock it?
Old May 29, 2006 | 08:16 AM
Twinkie's Avatar
Minor.....not even to the beads on the wheels. Just bumpy trying to cross some rutted tracks, so it took some throttle.
Old May 29, 2006 | 08:24 AM
Twinkie's Avatar
Another thought, I have no spark or fuel pressure. Are all of these tied to the computer getting a signal from a cam sensor or something? This has me soooo stumped. There was pressure in the line when I removed it cause it sprayed everywhere, but no flow when I turned the key on, with the line off.
Old May 29, 2006 | 05:46 PM
In order for the fuel pump to turn on when the key is on the VAFM's flap must be open... There is also a fuel turn on if you apply 12v to one of the terminals under hood. I dont remember which though.
Old May 30, 2006 | 02:29 AM
Twinkie's Avatar
OK, hate to sound rrreeaaalllyyyyy stupid, but what is a VAFM?
Old May 30, 2006 | 03:40 AM
the flapper thingy on the end of the intake that measures the volume of air coming in as well as its temperature. That front flap has to be open for the fuel pump to kick on.
Old May 30, 2006 | 12:28 PM
Twinkie's Avatar
Hmmmm, will keep it in mind when we reassemble tonight. Currently doing the idler, tensioner, seal and of course the belt.
Old May 31, 2006 | 06:28 AM
Twinkie's Avatar
Thank you guys! It is reassembled and rolling again. It's a heck of a lot quieter now with new idler and tensioner. Also no more tick, guess that could have been the belt hitting the belt cover, who knows.
bigjstang
Jun 2, 2025 03:56 PM
Flying91
45
Apr 11, 2024 04:39 PM
foampile
Dec 18, 2022 01:29 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
