should you care that idle goes up using accessories
Old May 24, 2006 | 06:47 AM
jluce's Avatar
I read some threads today about removing vacuum lines and how they are there to increase idle when using accessories....
is there any reason why you would have to have these... is it gonna put any extra strain on the engine if I plug em...
Old May 24, 2006 | 06:53 AM
subliminaltrips's Avatar
your ac wont work properly with out the idle up lines connected and your power steering will whine and cause the pump to wear prematurely.
Old May 24, 2006 | 07:47 AM
Marc's Avatar
I don't have an A/C idle up module and I plugged my power steering idle up lines 2 years ago and everyting works fine.
I do adjust my idle up a bit manually for the summer whe using A/C
Old May 24, 2006 | 08:08 AM
AH64ID's Avatar
what would benefit from this?
Old May 24, 2006 | 08:16 AM
snap-on's Avatar
idle up for a couple of reasons.
1) the addtional load on the motor can stall it at normal idle speed
2) by turning the compressor for the AC faster it works better, by drawing more air through the condensor it works better
the PS idle up is ONLY at the end of the stearing lock when the pressure on the pump increases dramtically and can cause the motor to stall. the idle up on the PS is connected to a pressure switch. it should only idle up once the pressure on the pump increases to a certain point.
Blamalam
Mar 12, 2022 07:34 AM
skoob
Oct 15, 2015 03:23 PM
Sarcazmo
Aug 15, 2015 08:22 PM
anniesball
Jul 29, 2015 11:46 AM
