leaf springs for an 88 4runner
Old May 27, 2006 | 10:13 AM
Chapman88SR5's Avatar
where can i buy rear leaf springs for my 88 4runner? mine are straight and flat. i want a little bit of lift out of them also.
Old May 27, 2006 | 10:27 AM
SoCal4Running's Avatar
I've got Downey on my runner, have had them almost 2 years and havent began to sag any yet. If you only want a little lift just change to longer shackles.
Old May 27, 2006 | 10:29 AM
what all would i need for a three inch lift?
Old May 27, 2006 | 02:25 PM
Bill's Avatar
seeing that you have to replace them anyways, why not do a swap to 63" chevy springs? The swap give about 1.5" of lift, and better articulation.
Not quite a straight swap in, you need to weld on a new front hanger, but not that bad if you've got some skills, or a buddy with a welder.
I've also heard about being about to swap in jeep springs (insert wise crack here)
Chebby's
Old May 27, 2006 | 07:15 PM
InternetRoadkill's Avatar
Try this link for replacement rear springs. It's what I used in mine. They ride great and even gave a slight lift.
http://www.jackit.com/store/supercart.cgi?s=skj_tr20s
*** BE SURE TO ORDER THE BUSHING KIT WITH THESE *** The factory ones won't work.
Old May 27, 2006 | 09:25 PM
BLKNBLU's Avatar
I also went with the Downey springs. I got their 3" lift springs and realized about a 2" lift after settling. Someone mentioned that may be due to a 4 runner being heavier in the rear than a truck and that the rating might be based on a truck. Don't know about that, I just know that I got 2" out of them and have been happy with them. I recall them being a bit more expensive than the ones linked by InternetRoadkill above, but did come with new bushings. About $185 IIRC.
Old May 28, 2006 | 02:45 PM
AxleIke's Avatar
I have downeys. The 3 inch. If i did it over again, i'd go with Alcan's. The downeys are decent, and the price is right, but they do sag a bit. A longer shackle in addition to the downeys will work well.
I wouldn't worry about articulation. Articulation doesn't do you much good in the rear, when the front has almost none. Whatever springs you get, you are going to have more than enough for the front, and doing a chevy swap is going to be more work. If you are prepared for it, go for it.
Downeys are fine, these other places are fine. Pick something, and try it. Either way they'll last you a few years, and you can evaluate what you want to change about them as you go.
Old May 28, 2006 | 03:18 PM
Toyopnoy's Avatar
So these are $151 for a single leaf or pair? If it's a single then the Downey ones are cheaper.
Jun 1, 2021 01:51 PM
BeMiceElf
Oct 10, 2015 09:40 PM
cars-guy
Jul 11, 2015 07:51 PM
Nickdigg
Jul 7, 2015 06:04 AM
toyoda8488
Jul 5, 2015 10:18 PM
