Engine jerk.
Old May 20, 2006 | 12:13 PM
91_4x4runner's Avatar
Exclamation Engine jerk.
I came up with a new problem today with my 4Runner. It's got 222,000 miles as of today on it. I was driving it home from my moms work in hot weather. I came to a stop light, and when the light turned green, I started. As soon as the engine got about 3k RPMS (right around my shifting point/powerband), the engine started to jerk me around, where it is usually very smooth. This happened through every gear and at every stoplight. I watched my temp and oil guage and both remained normal during the time. Does anyone have an idea what this could be? It's got me very weary about driving around in it at the moment. Thanks, Eric.
Old May 20, 2006 | 04:00 PM
regularguy412's Avatar
I'm sure they all get tired of hearing me say this, but try looking at your fuel pressure / fuel filter / fuel pump. I had same problem when I first bought my 92 3.0 used. Bucked and jerked like a wild horse. Even broke a little of the plastic housing inside the cab around the shifter. Other times, when it didn't buck, it didn't have enough power to get out of its own way.
Replaced fuel pump and filter. No more problem.
Mike in AR
Old May 20, 2006 | 04:41 PM
Same thing I was told by my dad/mechanic. Thank you very much. I'll definitely look into it.
Old Jun 11, 2006 | 10:03 PM
TexJJ's Avatar
Question: Did this jerk happen all the time, or very spurratic? I've had a similar problem, but it is VERY random, sometimes going 200+ miles between jerks. I get one jerk then smooth as silk.
Old Jun 11, 2006 | 10:45 PM
stock87's Avatar
How old are the plug wires? Mine started doing exactly that when the original set finally died after 16 years. The wire from the coil to the dist went bad.
Old Jun 12, 2006 | 07:51 PM
toyotaoffroad91's Avatar
check your egr valve
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
