Anti-Freeze Leak
Old May 22, 2006 | 04:41 AM
psychobillyman's Avatar
Anti-Freeze Leak
Hi everyone,
I've got a 1988 4runner with the 22re. I've got an anti-freeze leak through the metal tube I think the lower radiator connects to. The leak just sprung yesterday. I was just searching around the internet to see if I could find the part to replace it, but I haven’t had any luck. If anyone knows what I’m talking about and maybe a place to find it that would be a great help.
Thanks,
Jake
Old May 22, 2006 | 09:12 AM
waskillywabbit's Avatar
There is a metal tube that goes around the back side of the engine that is flanged on one end and hose clamps on the other I believe. Mine was just worn out and was actually weeping instead of leaking...wasn't much or hard to replace. You should look at an FSM to see exactly what it is called.
Contact strap22 on here (Toyota of Dalls www.trdparts4u.com) and see if he can help you locate what part it is and get you the part.
EDIT: Either the "heater tube" or "water bypass tube" sounds like what you are talking about, but I can't find a good picture of the radiator in the FSM, go figure.
Old May 22, 2006 | 10:39 AM
rdlsz24's Avatar
I'm also having what sounds to be this same problem. I have to add coolant every couple of weeks. I think this may be where mine is leaking from because when it's really cold out, the engine steams really bad from the back.
Rob
Old Sep 1, 2006 | 10:30 AM
rdlsz24's Avatar
Is this a replacement for the part that waskillywabbit is talking about?
Link
I'm still looking to fix my leak. As a temp fix I've just been adding coolant to it every so often.
Rob
he's gone
7
Dec 3, 2019 07:08 AM
4runnerjunk
Aug 22, 2015 09:06 AM
accuracy
Aug 4, 2015 08:05 PM
itzmywife's
Jul 25, 2015 04:55 PM
Avenged
Jul 9, 2015 07:55 AM
