Little fan???
Old May 22, 2006 | 08:04 AM
bigpest88's Avatar
Little fan???
I have seen a small electric fan on the left side behind the grill on my radiator of my 95 4Runner, and was wondering if anybody knows what it is? I tried looking for it the repair manuals, Ive asked at part stores, but no luck. No one seens to know what its for. So If anyone can tell me what its for, I would greatly appreciate it. Thanks
ChRiZ
Old May 22, 2006 | 08:12 AM
snap-on's Avatar
pusher fan for when the AC comes on. or supposed to be at least. i have one on my 92 runner but have no idea if it works like it should
Old May 22, 2006 | 05:11 PM
bigpest88's Avatar
Is there a way to test it to check if it is working correctly? Are there any consaquences(Spelling) of running it with the messed up?
Old May 22, 2006 | 05:19 PM
mt_goat's Avatar
It should be as easy as turning on the AC and looking to see if it is running.
Old May 22, 2006 | 05:26 PM
bigpest88's Avatar
:pat:
I was wondering of there was another way.
Old May 23, 2006 | 06:51 AM
eric-the-red's Avatar
Yes, run some wires straight from the battery to the fan. If it's working it will spin. Watch your fingers
FYI there are 2 relays in the circuit as well, if the fan is working with direct power but not with the AC then one of them could be bad. They are labelled in the wiring diagram as AC condenser fan relay #1 and #2, both in the relay block on right side of the engine compartment.
Old May 23, 2006 | 07:22 AM
AH64ID's Avatar
The only thing that will happen if it doesnt work propelly is your A/C wont be as cold when your not moving (i.e. at a stop light), condensers require lots of airflow to work well, hence the fan.
Old May 23, 2006 | 08:00 AM
brandontrek's Avatar
i am going to go check if mine has that....i never saw it before...
Old May 23, 2006 | 08:25 AM
mt_goat's Avatar
Pickups don't have them, only the 4runners. I guess since the pickups don't have as much interior space they don't need the extra cooling.
kawazx636
Oct 6, 2021 03:03 PM
voiddweller
Sep 28, 2015 11:21 PM
Matthew Perez
Sep 28, 2015 05:43 PM
runnermedic
13
Sep 21, 2015 05:20 PM
Aaron Logan
Sep 3, 2015 08:08 AM
