how to prove CEL works
Old May 28, 2006 | 01:30 PM
linuxrunner's Avatar
Title says it all, this is on a 22re 1st gen. It has lots of problems, but CEL has never come on unless i use the jumper thing. is their a way the PO could have dissabled it? and is their a way i can make it go on? something i might be able to unhook?
Old May 28, 2006 | 01:51 PM
Elton's Avatar
try unpluging the 02 sensor if that dont work maying the bulb is burnt out
Old May 28, 2006 | 01:54 PM
Elton's Avatar
you could also unplug the maf sensor
Old May 28, 2006 | 03:19 PM
terryjmatthew's Avatar
The CEL should light up w/ the key in the run position and engine off.
I have seen some crazy things done w/ CEL's (bulb taken out/wires cut)!
Old May 28, 2006 | 03:27 PM
well i knew my bulb was good, because it would light up when key was turned, but now i know a few more things. Like if i remove the MAF the CEL light does turn on woo hoo, also my truck wont run long without the MAF plugged in. Thanks all for your help, i guess the 22re light does not turn on very often.
Old May 28, 2006 | 04:51 PM
mr toytech's Avatar
it shouldnt come on unless there is an electrical malfunction or egr prob w/ the motor. and i have seen people wire the efi fuse to kill the 2trip logic to the ecu.
Old May 28, 2006 | 09:28 PM
Snorkeldepth's Avatar
In my FSM I read the method to check the CEL. IIRC it involves connecting two of the test connections. I can't remember where I read that. If you really need to check your light let me know and I'll try to find the procedure in the FSM for you.
ashersullivan88yota
Jan 18, 2022 05:37 PM
crashburnoveride
Jul 10, 2015 06:39 AM
Roger Borba II
Jul 9, 2015 05:05 PM
madxman21
Jul 9, 2015 10:26 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
