1990 4runner pulls right while braking
Old May 26, 2006 | 09:08 PM
davemacneil's Avatar
When I apply the brakes moving or not the wheel will turn to the right... any ideas?
Old May 26, 2006 | 09:36 PM
Red3.slow's Avatar
How does your tire tread look?
Old May 26, 2006 | 09:38 PM
even wear i believe, ill take a closer look tommorrow
Old May 26, 2006 | 10:33 PM
89macrunner's Avatar
most likely that means you have a seized caliper..
When my dad bought the 4runner i have now the caliper on the left side seized and it pulled to the right.. We replaced both about two years ago and i still on the same break pads
Old May 27, 2006 | 11:06 PM
Red3.slow's Avatar
Yeah thats a good possiblity. Are you getting any grinding or noise from the front right.
Old May 28, 2006 | 01:52 PM
Nope no noise, just pulls right under braking. Sounds like a seized (open) caliper on the left side is the most likely cause, makes sense. Thanks macrunner for the help and you too red3.slow
Old May 28, 2006 | 06:45 PM
paintball11090's Avatar
I had that problem, all I did was turn the roters and replace the pads. Its not fixed but its 20X better
Old May 29, 2006 | 10:00 AM
the_4runnin'_beast's Avatar
yeah...that would mean you need to replace the caliper. its better to fix the real problem than to just replace some parts and mask it for a while. when you put on new pads, it is allowing the piston to not travel as far, so it will work...for a while. you should replace that caliper as soon as possible. "micky mousing" your vehicle is no way to live!!! lol...good luck!
Old May 29, 2006 | 11:05 AM
UKMyers's Avatar
My 94 did the same thing.. Calipers from like AutoZone aren't too bad with a core. Something you may want to try before that is taking the pads out, pushing the pistons back in with a C-clamp and then pumping the brakes to push them out. Just be careful though with no pads as you can overextend the pistons. Work them back and forth a few times. Sometimes that will get you by for a while. From what I hear you can rebuild them yourself too but for the cost it's way easier to just get some new ones and bolt em on. Good luck!
Old May 29, 2006 | 02:50 PM
yah id rather spend the money and not have to keep quick fixing the same problem when it reoccurs. Thanks all for your help.
voiddweller
19
May 2, 2016 09:10 PM
DjShiznit
Jul 5, 2015 11:51 PM
ZONAYODA
Jun 30, 2015 05:36 PM
miceal383
Jun 29, 2015 12:27 AM
