loss of power 22re
loss of power 22re
To start i have a 92 22re 4x4 pickup and it just rolled over to 250k miles. I drove to work and back today and it drove great without even a hint of a problem. I got back from work around 5:30pm and around 8pm i go to move my truck in the driveway from the street.
-started with a noticeibley lower idle than normal (1000 at cold start versus about 1500).
- I decide to take it around the block and it has about half the power it normally does.
- hot idle is irratic between 500 and stalling.
- very slow to rev when in neutral.
My guess is somthing to do with fuel or ignition?
Any ideas guys?
Thanks
Any ideas guys?
Thanks
Originally Posted by Elton
whens the last time it had a tuneup
Sounds like a head gasket. I had this happen to me before. One cylinder leaks into the other. What I did was make a connector out of an old spark plug so I can put compressed air in through the plug hole. Then I screw it into each cylinder and turn the presure up and feel the plug hole next to the cylinder you are filling (The fill cylinder must have both valves closed).
Jeffreynmandy
Jul 18, 2015 08:26 AM
