PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. 2000 4Runner Sport - Transfer Case Issue? Wants to jump out of 2HI and GRIND/BANG BAD
  2. 98 Toyota 4 Runner 4 cylinder
  3. What is this? (pic)
  4. 92 4runner front brakes won't release sometimes
  5. Are all 24F batteries interchangeable?
  6. 99 Toyota 4Runner's horn just stopped working.
  7. Height Help Please 99 Runner
  8. What is this part ????
  9. 99 4runner won't stay running, what am I missing?
  10. Toyota 4Runner 2003 throttle body leaking fluid
  11. When did Toyota stop making a super basic tacoma?
  12. 99 4runner Rack n Pinion loose and clunking
  13. New Rear Axles: Longfield?
  14. 97 Tacoma cutch release bearing
  15. head gasket
  16. po770 code
  17. Need Help on 02 4runner a/c issues
  18. i have a 1993 toyoya t100. I am having a roaring noise inside cab at 40 to 45mph
  19. Hyperflash problem
  20. well, is there a EGR valve on a 2001 3.4L Toyota 4 Runner
  21. wheel bearing removal question
  22. wtf?
  23. 3rd Gen 4Runner Transmission issue
  24. tacoma tundra brake upgrade
  25. 2001 Toyota tacoma - normal steering rack play?
  26. Help! Maf Sensor Connector broke
  27. A/C compressor
  28. Front diff breather and filling through it
  29. Running a half quart over
  30. Radiator options with trani cooler bypass
  31. 2006 4Runner Clunk in Rear when I stop.
  32. auto engine into manual truck ecu problems
  33. 2002 toyota tacoma 2.4L extra cab 2x4
  34. Looking at a 97 tacoma
  35. shifting into park clicking
  36. Code 14 Igniter signal to ECU missing
  37. 3rd gen 1999 4runner rear bumper replacement
  38. Which solid rear pinion spacer: Trail Gear or ?
  39. Rear drivers side clunk
  40. Why your truck might be running a few degrees hotter
  41. Spare WHEEL Size
  42. Loud clanking from engine compartment?
  43. P0130 + P0133 as well as uncoded misfire
  44. 98 3.4 Running Dead Lean
  45. Slipping transmission
  46. 96-02 4Runner Rear Differential Rebuild Kits?
  47. '98 engine swap into '96
  48. '97 Tacoma 4WD rear axle bearing info: KOYO 6308T
  49. What could cause an occasional gas/exhaust smell from 2001 Tacoma?
  50. After-factory A/C Heater Blend Door Actuator replacement
  51. Broken bolt while changing LBJ. Am I screwed?
  52. Need new rear limited options
  53. 1999 4runner limited supercharged engine and tranny swapped to a sr5
  54. Won't go into 4WD
  55. key fob program worked and now not working
  56. 99 tacoma, can't turn all the way off
  57. Misfire in cylinder 5
  58. [Help] Engine Turns over but wont start without Gas Pedal
  59. tach mod 3.4 swap
  60. Cuts out for a split second while accelerating PLEASE HELP!
  61. Leaking alot of oil!
  62. '97 V6 Tacoma 4WD: factory driveline alignment?
  63. O2 sensor problems after replacement
  64. Rough Shaking 3.4
  65. 338mm x 32mm 4runner brakes fit 1st gen Tundra?
  66. 96 Tacoma Front End Parts
  67. 1997 Tacoma 4WD CV Axles?
  68. 1999 AC Part ID?
  69. 3.4 Engine redux time! 2000 Taco
  70. Broken ignition induction coil,(the housing around ignition lock cylinder)
  71. LSPV siezed
  72. Unknown trans issue
  73. Replacing 98-2002 intake on a 96
  74. new alternator new BATTERY
  75. 02 Tacoma Front End Damage-How to fix
  76. rattle from tailshaft hilux ute
  77. Parts Advive--Front LCA and UCA Bushings, Upper and Lower Balljoints, Sway Bar Links
  78. 96 4Runner wheel bearing replacement
  79. '99 Tacoma Fuel/Knock Sensor Puzzle
  80. Roof basket for 2000 4runner?
  81. 1998 4runner replaced spark plugs now its not fireing
  82. Brake issue
  83. 1996 4Runner 3.4 Clutch Help Needed
  84. truck pulling to the right
  85. Tacoma hesitating stumbling with rough idle when warm
  86. power loss
  87. 3.4 Misfire and oil issue
  88. 04 Tacoma to TDI Conversion
  89. SOLVED - VSC kills throttle and screams for no apparent reason
  90. 99 4runner acceleration issues
  91. How are the 1996 tacoma license plate lights wired?
  92. Snap-On MT2500 connection
  93. replacing hood inuslation heat shield
  94. need help asap
  95. 4Runner won't start when hot
  96. 1996 3rzfe EGR questions
  97. Electrical Problems!
  98. 2002 Tacoma Clutch Issues
  99. positive camber after front end rebuild
  100. '97 T4R, ONLY Passenger Brake Light Not Working??
  101. Steering hose issue
  102. Opinion on 4Runner purchase
  103. Rough Running 3.4
  104. Supercharger Question
  105. Spare Tire Question
  106. Steering Yoke Sub-Assy - change in diameter
  107. New thread old problem
  108. 1997 4runner 4cyl 2 wheel drive manual
  109. Need to know what this sensor is
  110. 1997 4Runner with head gasket leak. Fix or sell?
  111. Locating 2WD axle shaft and 14x6 wheel rim?
  112. SS brakelines/2001 4Runner
  113. My truck dies when lights are turned on
  114. 99 4Runner Rear Defroster
  115. 1999 4Runner Limited stuck in “AWD”
  116. e-locker compatibility
  117. Airbag light does not illuminate at startup, failed safety check
  118. Rear axle housing difference?
  119. Big Tranny Question ?
  120. Considering parting out or partially parting out 02 4Runner
  121. 2001 5vz-fe 3.4 Timing issues?- need help
  122. Ball joint thread size?& making bj spacer
  123. Gear and Axle parts supplier
  124. Fuel Leak, but Truck running fine?
  125. 2000 4runner w/manual trans.
  126. Leak in floor board,drivers side
  127. tundra start problem
  128. Rubbing sound from front. Not tires
  129. Early Tacoma 4x4 3rz to 2rz swap
  130. Good source for OEM 3rd gen black plastic mud flaps
  131. Strawberry milk
  132. Strawberry milk
  133. transfer case 99 Limited
  134. 99 Limited Minor Annoyance: Beeping sound when key is removed from ignition
  135. Whine Coming From Rear Differential
  136. 5VZ-FE power steering pressure line replacement
  137. good buy? 97 4runner?
  138. 95.5 4WD Controller Module Out
  139. 99 4Runner Code 446 fixed
  140. Looking Thread Pitch for Part #90164-45005
  141. Replacing stock shocks n struts with bilstein 4600s worth it?
  142. 97 4runner Timing Belt Tensioner pulley bolt
  143. ABS light comes on with bumps
  144. Air Filter Door Hold Down Clip Broken
  145. PO446 on a 2002 Toyota Sequoia
  146. Hello what is this part and where can I get? Console 2004 4Runner
  147. Mudguards = hensteeth?
  148. What type grease for '97 V6 Tacoma 4WD CV Axles?
  149. 2001 tacoma v6 2wd automatic transmission question
  150. Bolts for front skid plate
  151. Opinions,looking at 2000 sr5 4runner - 95k
  152. Rear window switch
  153. Need list of sizes to replace vacuum hoses
  154. What's the hottest headlight for 3rd gen runners these days?
  155. 99 Runner retro wheel refresh
  156. Need to cut fenders past pinch weld - is it okay?
  157. New guy to the page.
  158. 2001-2004 front end conversion
  159. what is the best brand of oil for 5vz-fe
  160. Show off your 255's
  161. Thrown Rod in '95 4Runner
  162. Security System and Fog Light Failures
  163. 3rd hand runner with some cut wiring Q
  164. 2000 tacoma shake.
  165. ABS Code 32 on 2000 T4R Limited not sensor!!
  166. Are there DIY options for repairing faded Toyota paint?
  167. 99 runner front projector lamp options ?
  168. p0300 p0302 p0304 codes - misfire
  169. Taco Door Panel Help
  170. Getting ODBII on older Australian Prado
  171. 01 4runner starts then dies
  172. Recently changing timing belt and water pump, truck runs the dies
  173. Another VSC OFF/VSC TRAC Thread
  174. 02 taco lower ball joints-Moog vs. Factory
  175. Unsure of fuses needed for inverter install
  176. 02 4Runner e lock rear end ???s
  177. another EGR thread
  178. 3.4L starting issue after 7th injector kit install
  179. QUESTION/VIDEO - Tapping/Knocking Sound -- Would you please help me diagnose?
  180. 400,000 mile club
  181. 99 Limited Heat/AC problems
  182. rear diff housing bent?
  183. 2000 4Runner ??
  184. What is it?
  185. No reverse!!!!
  186. *FREE Yotatech Decals*
  187. VSC OFF, VSC TRAC & ABS lights on
  188. 2000 4runner 3.4L overheating...
  189. 4runner lift
  190. 33x10.50x15
  191. Brake Locking Up
  192. ECU difference 89666-35141 and 89666-35140?
  193. HELP —-> Which one would you choose!? <—-
  194. Just installed 2" body lift - wheel spacers or not?
  195. Just installed 2" body lift, now the stick shift hits body.
  196. 4 wheel drive in 2001 Tacoma Doesn't Work
  197. Bad shake 50mph
  198. over heating and heater
  199. Installed new suspension including rear Gabriel Air shocks. Now I want 3" lift.
  200. SF Bay area 4runner consulting on purchase?
  201. Please Help! Fuel Gauge/ Sending Unit Issues
  202. Advice requested for my first drum brake replacement job ever
  203. 04 4Runner
  204. 4wheel drive acuator motor
  205. 02 4runner intermittent brake warning
  206. 99 4Runner Everything shut off
  207. Oxygen sensor fell out and P0120 code
  208. 4wd not engagin
  209. 2000 Tacoma v6 automatic 4x4 California model compatible transmissions
  210. cabin air intake location?
  211. question on what a "dealer" repair to awd on 98 ltd
  212. WHEEL OFFSET ( 2000 YOTA TACO 4x4 )
  213. No heat
  214. Federal California ECU Swap in 2000 limited ??
  215. Disappearing coolent
  216. 2004 Tacoma won't move
  217. 97 sas swap
  218. super charger
  219. 99 base Taco cluster upgrage
  220. High Idle after Auto to Manual transmission swap
  221. Another RTT mounting question. Sorry!
  222. Vibration at 90 km/h
  223. Will a 2000 4runner seat fit in a 95
  224. 2.7 engine problems
  225. transfer case input seal replacement
  226. 96 runner spare tire removal
  227. Bolt cross reference, part number to size?
  228. 3.4 Swap Running Bad
  229. My alternator finally gave up the ghost :)
  230. ECM repair
  231. Tranny issues!!
  232. Fan clutch no longer loud on startup
  233. 1999 4Runner fog light switch
  234. Question on the A340F shift logic.
  235. 98 t4r speedo not working, no abs lights
  236. Obd2 port under hood vs inside the cabin
  237. 2000 4Runner - Tail lights not working; all others work (dash, head, rvs, lic. plate)
  238. Alignment for 1998 4runner ltd, stock suspension.
  239. Did I bend/break something in my trans?
  240. Black Supercharger question
  241. Speed/Tach/Odo meter inop. P0500 Vehicle Speed Sensor fault. '98 Tacoma 3.4
  242. 1998 Tacoma Power Steering Issue
  243. 3.4 random no start no fuel.
  244. Excessive positive camber
  245. missing, stalling, whining when warm 1998 5VZE 3.4L
  246. P0330 Everyone's Favorite Code
  247. Valve Cover Bolt Part #
  248. Faulty brake booster or master cylinder?
  249. Diagnostic help- what happened??
  250. 1998 4Runner Defogger EWD
