- Recommended Next mod on my 3rd Gen 4Runner: Winch or 35's?
- Does anybody have an old Downey Catalog?
- Best way to clear clogged a/c drain line?
- Walbro 190 failure?
- 18" magnaflow too loud...options?
- OME 890's with bilstein 2451's
- Ordering a lift kit from Toytec (finally)
- 4Runner hood black-out
- Fuel pressure regulator
- OME 881's with Bilstien 2450's
- 3.4L engine problems...
- 4Runner Overheating Inconsistently yet Frequently
- My First Toyota - 2002 Tacoma! *Pic*
- Driving on spacers with 2 missing studs/lugs
- Borla exhaust
- Has anyone replaced the ECM/ECU?????
- 2004 Toyota Tacoma 3.4 Idle Problem
- where to install remote transmission filter
- emergency brake handle stuck in the down position
- Fabtech coilover bushings.
- 96 4 runner power loss
- '01 Rear Bumper Replacement?
- Aftermarket upper control arms - Camburg or Total Chaos
- engine running after cut off
- Lil more bang? (New heads)
- Need new upper control arm bushings but theres a problem....
- Who here has deleted their balance shafts?
- Axle Tone Ring and Retainer position???
- changing timing belt, do i remove the crankshaft pulley?
- 2002 4Runner 3.4 - Throttle by wire?
- P0440 code agggghhhh!
- fender trim question
- 1.5inch Deaver/OME suspension lift
- Rear Window Squirter Doesnt Work. What to look for?
- Whats the difference in 96-98 and 00-01 Tail Lights? (4Runner)
- Weird sound coming from truck - sounds like a bullfrog under my truck
- using anti freeze
- 4Runner sluggish after battery install
- Icon Rear Reservoir Shocks Installed
- Help w/ Sluggish Power Locks & Fuse Issues
- CV Boot Replacment
- CEL Code P0031 Question!
- Interchangeability of clock springs (spiral cables)
- 2004 taco extended cab - carseat help!
- Knocking sound from back driver wheel area when breaking...
- Another mpg thread, is 15mpg "average"!? 3.4 AT 4runner
- Suspension ques.with kingcoilovers
- Aloha Bruddahs! MissFire P305
- Do I need ball-joints?
- 1997 tacoma 5 speed transmission problem
- Noob looking for help wiring my hella700s
- 98 4runner overheating problems
- just built this stinger for my buddies taco!
- Painted My 3RZ Block W/ POR 15
- Yakima Mega Warrior Roof Rack questions...
- Brakes upgrade w/ 15" rims on 98 Tacoma
- 2.7l muffler replacement
- Camber Adjustment Screw
- Has anyone replaced 3RZ balance shaft bearings??
- more elocker swap wiring help needed
- Block and Head Performance Mods fo the 5vz
- Long cranking
- Differential Noise When Put In Gear
- 99 runner V6- Random Overheating question
- E-Locker Indicator Switch Question
- Changing alternator belt?
- 98 L4 2.7 coil igniters
- 99' 4Runner V6 long cranks when engine is warm
- Need to test the MAF
- brake pedal grabs low in my 4 runner
- HELP!! My '02 Tacoma's IFS Differential Questions>>?
- Should I flush my tranny fluid? Pics
- Lights, Accessories, No Starter
- 2001 DRL/Head Lamp Circuit Schematic?
- Sloppy Steering 2003 taco
- Blue Sea Systems fuse panel install pics!
- Replaced 3.4 (5VZ-FE) - new motor won't start
- 99 Prerunner and 2wd difference in driveshaft?
- Dash "D" Dimming ???
- Show Me Your Satoshi...Grill
- how much life is left on the 3.4?
- After routine maintenance....P0125 & P0171
- Squeak in DRIVE only low MPH
- steering rack replaced but same issue remains '00 tacoma
- Supercharger noise - low oil?,Worse?
- Love my 4runner, maintenance questions
- rear diff locker
- Idle Issue
- t100 vs 3rd Gen 4runner tcase questions
- Brake Fluid Leak?
- Stock Cd/Cassette Stereo Died. Found one for $10 BUT!! Radio Code
- Replaced 2004 Tacoma 4 Cyl Water Pump
- Adjustable Bilstein shock suggestions
- ruff ride on fabtech coilovers
- Quick question 1998 4Runner AWD? Such a thing?
- Swaying with every crevice in the road.. Multiple conclusions
- Can someone tell me if this is a limited or a Sport
- Mystery Noise -- Give a listen!
- What is this switch in my fuse box?
- brake pedal clunk
- Valve Cover Gasket
- Aftermarket oil pressure sender on 5vz?
- Fuel Pulsation Damper
- Towing 4,100lbs for 12 hours w/ a 3rd gen 5spd 4x4
- 5spd not going into gear - clutch?
- what's the best 4 banger muffler
- Supercharged Tacoma Video
- strange brake problem 00 4runner 2wd
- 3RD Gen 99 4runner Rear D/S window issue-off track
- any experance with fabtech coilovers?
- 185 Degree (F) ATF Temps with cooler in 90 (F) degree outside temp, is this normal?
- Compression numbers?
- Need cheap antenna replacement, not Tacoma Whip mod.
- 265/75/16 won't fit under the spare area?
- Coil Issues
- new tires
- damp carpet
- Installed a E-fan. looking for better ways to control it.
- I'd like to paint my bumpers black. What's the best way?
- 3rd Gen Front Receiver
- speedometer misreading and milage
- Cracked air box. Fixing ideas
- Front Wheel Bearing write up?
- Tranny cooler opinions?
- Stock Cooling Fan questions
- What are my concerns after a rollover?
- Mechanical Transmission Temp Gauge Install
- HELP- 2000 4R sat for 8 mo. and now burns oil
- Front end Sagging(ARB bumper), what Springs to get
- O2 Sensor nuts?
- Tundra Brake Upgrade Rattle Fix
- Purchased a Shrockworks Bumper today, let the countdown begin
- E-Locker on 2WD
- My '02 T4R Sport w/ SL, 285s & Basket
- Indestructable water pump
- Taco Steering Wheel
- Can I get some opinions on 2001 SR5 with 198K - maintenance?
- Yakima Rack and Less MPG
- which transmission line heads to the tranny cooler?
- Flasher Relay
- 5th Gen rims on 3rd Gen
- Fan Clutch replacement
- Fog lights for 02 4runner
- Looking for lift with 265/75R16 photos
- Pics of my 1996 Toyota 4Runner Limited
- HELP! removing trim pannels...
- Need help with thread direction on 99 runner transfer case.
- 1999 4Runner - What o2 Sensor Should I Get For My Situation?
- AC Belt
- Overheating issue with Taurus Fan Mod
- High Idle
- Where are all of the Tacomas going?
- A/C expansion valve
- AC blowing on driver's feet
- Vibration when braking
- 1995 OBD1 Tacoma CEL not flashing when pins jumped.
- front axle shaft
- 4runner hunt. 5speed vs auto elocker.
- 3rd Gen Toytec or OME
- heavy front end
- 98 4Runner moonroof safety switch Defect and One Touch Operation moD
- O2 sensor bypass question
- intermitant blower
- Can tie rod ends fuse to the ball bracket
- rear bumpers
- Anyone change the driveshaft seals on the trans. case on 99 runner?
- "Gear Set Loose"?
- Front Shock Part Number Difference
- Painted my alloys black
- 3rd gen lifted Runner-show off front mud flaps please
- Failed smog, need advice
- 99 4Runner Axle replacement
- 2002 Tacoma CCV/VSV wiring
- I'm back and I'm a 3rd genner now but I need help
- Misc. New 4runner Questions
- 1998 3.4 Auto 4Runner, Overheating Issue, Suggestions?
- stock coil wraps
- 2.7 Idle Surge
- rear diff leaking on 2000 4runner LTD
- Torn Ball joint boots...Aftermarket grease boots available?
- Sunroof opens (tilts up) by itself? Ideas?
- tundra/sequoia 17" rims tire size question
- Sliding Ashtray
- Anyone in the Denver area have Sonoran steel 1.2 installed?
- Ideas for Rear Sleeping Platform and Storage
- A340 tacoma shift kit, know of one?
- Strut top hat and isolator
- AC compressor/clutch died
- flywheel broken-what to do? transmission replacement
- Rear lockright install tips. 4runner
- Recalled truck has a dangerous problem
- 97 4runner ltd fender flares
- trailer wires
- Buzzing noise after engine is turned off .96 tacoma 2.7 liter manual trans
- Engine misfire? No CEL. (01 4Runner)
- 00' Tacoma xtracab leans to the passenger side...
- 97 3.4 overheats
- How to: Change Drive Belts 3.4 L 5VZ-FE
- Got locked up today...
- HELP! P0301 Code - Misfiring
- Cargo Liner
- torquing lower balljoint castle nut
- Help! Electrical Issues - Gas Guage and Fog lights
- New Guy Old Question Regarding TRD Cooler
- Pacemaker vs. JBA vs. Doug Thorely Headers
- elocker '01 4runner issues
- What coolant for 2000 4Runner with 3.4 liter engine?
- outer tierod removal: outer nut turns counter clockwise?
- Limiting Moonroof travel.. How?
- 1st bad picture of my lift
- Sway Bar End Links
- Fluid Leak at driver side CV
- Rear bumper replacement
- front end shake
- How to: Replace steering rack guide- Pictures
- The Dreaded Front diff drain bolt!
- Installed new brake shoes -- adjustment?
- P0136 hell
- Killer Hesitation
- 2001 stereo in a 1997 truck?
- Tundra UCA and LCA on 3rd gen Runner
- Toyota locking lugnuts - 2 different part nos.
- 3.4l won't idle or downshift
- Better! The Velocity Stack Mod for your airbox (8hp for $3).
- Timing belt help
- EGR valve gaskets: 2.7L 4runner
- Finally got OME Lift - 881/890 - Pics to come!
- 99 seatbelt problem
- Chipped Harmonic Balancer
- 03 Taco 2.7l 4x4 power steering nightmare!!
- need some help on a couple of ECM circuits
- Selecting an external tranny cooler
- Trouble Removing Steering Rack
- Aftermarket engine oil cooler and fan clutch questions
- New to me 2000 4Runner
- HELP p0773 Shift Solenoid E Electrical
- Auxillary 12VDC Outlets in 3rd Gen console
- 1999 4runner OME 881/890 with 1/4" top plate spacer ?
- E-fan swap
- 4Runner 3vze/5 speed
- Changing Brakes-Draining Brake Fluid from the Line Fix
- Reversing the Daytime Running Light Disable Mod
- How I read my fuel pressure
- Did I get the right front shocks?
- 3rd Gen Front Trim removal
- Rear Axle bearing Bad?
- Flywheel application question
- Need Help Locating Gauge lines in Firewall
- Stuck bolts/body lift
- Spark plug issue
