PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. moonroof motor question
  2. CEL Trouble
  3. 99 tacoma timing
  4. 98 tacoma overheating problem
  5. Upper ball joint removal
  6. P0325 knock sensor code - 3.4l specialists help
  7. spark plugs and p0304 code
  8. 4x4 auto transmission is toast?
  9. Hesitation and mushy pedal help
  10. Died and won't start
  11. 3.4L head job
  12. 3rz water loss problem
  13. Bought my first T4R today
  14. stereo wiring issues
  15. Manual or Auto fo DD?
  16. 3.4 missing coolant
  17. possible bad rear o2 sensor?
  18. Heli-coil kit for 3.4L oil pan to block bolts
  19. O2 sensor location and part number
  20. New Marlin 1200lbs clutch but light pedal effort
  21. Carrier bearing bad or good?
  22. towing.
  23. thorly headers on a 3.4L - heat issue ?
  24. Overheating, but Only while off roading up hill!?
  25. Long-time 2nd Gen owner looking to upgrade
  26. Amsoil filters
  27. Spark plug popped out
  28. Power loss under hard(ish) acceleration
  29. clutch pressure issues
  30. Replacement key fob case for 1998 4runner
  31. truck stalls out from brakes, turn signals or wipers
  32. 95 taco 2.7 3rz starting problem/ idel
  33. A340F transmission driveline truns in neutral
  34. San Diego Tacoma Supercharger Needs Tuning
  35. Bad vibration on decel
  36. Flush mount Rigid Dually's on ARB front bumper?
  37. Maintenance Double Check - 148k
  38. COR Location???
  39. Help snapped off front hub from work truck!!!
  40. Cv axle removal tool?
  41. 97 Limited Tire Choice/Body Kit
  42. door buzzer/power locks
  43. 2.7 Oil Leak passenger side
  44. Matters Light
  45. Replace transfer case
  46. Vibrating Rotors
  47. Very slight knocking sound from 5VZ...thoughts?
  48. TrdParts4u and Bajarack
  49. Another 99 tall coil mystery (blue/blue?)
  50. Max Tire size VS. lift
  51. Exhaust price, manifolds back?
  52. Cylinders not all firing @ 1200 & 1800 rpm
  53. How to pinpoint a worn wheel bearing?
  54. 97 limited 4runner No crank no start
  55. prewired for elocker
  56. Slight Backfire/Misfire at Startup
  57. 98 4Runner starting problems
  58. 98 brake drum issue
  59. 1996 flatbed conversion aftermarket lighting issue
  60. 1998 sr5 overheat 3.4, where to start?
  61. 1997 4runner not shifting into reverse when cold.
  62. How is the drive shaft balanced at the factory?
  63. power window problem, GRRRRRRR
  64. Bilstein 5100 bushing question
  65. 1998 3.4L 270k motor issues
  66. Yakima vs. Factory Roof Rack Fuel Economy
  67. Gauge overlay or face replacement
  68. Looked at a pre-runner today - weird transmission situation
  69. CBI Rear Bumper put on
  70. 2001 4runner 2wd no transmission response?!!
  71. Cam position sensor
  72. Steering wheel pulls when braking! (car stays straight!)
  73. 2003 3.4 taco threw a rod!!! What the care bears!?!?!?!
  74. 1997 Tacoma runs but dies after a few seconds
  75. 2.5 inch for a 99 Taco
  76. Better pads - Better brakes
  77. Ball Joints and Tie Rods
  78. spark plug tube gasket removal and replace
  79. P0401 code on 99 toyota tacoma prerunner
  80. 02 4runner suspension issue
  81. 3.4 stuck intake valves
  82. 3.4L front crank seal install
  83. Newbie here from TX
  84. my busted bucket; need help with a botched valve adjustment
  85. click click starting issues- final answer is?
  86. e-locker light on BUT NOT LOCKER OR SWITCH
  87. Difference between these two stock 3.4 fuel injectors?
  88. EGR Temp Sensor Wire Colors
  89. 1998 4runner transmission?
  90. 96 Tacoma Locking Hubs Problem
  91. Front Lock-Out Hubs and Locker
  92. OME 906 and Trekmasters
  93. Misfire after rain
  94. Rear Window Bushing?
  95. 2000 4runner auto to manual
  96. 4runner non ABS axles shafts in an ABS housing
  97. 2000 Tacoma ADD axle Dust covers??
  98. Does TYC Make Koyo??
  99. 98 Taco wont shift into 4th (A43D)
  100. im worried about my baby girl URGENT!!
  101. Engine dies after changing 2 fuel injectors
  102. miss fires need compression test
  103. 99 Taco Exahust Valve Replacement -- Wisdom Needed
  104. 2001 tacoma 3.4l oxygen sensor wiring diagram
  105. 97 4runner wont start
  106. Please help on long road trip.
  107. adding ac to tacoma
  108. 1997 4runner SR5 3.4L clutch
  109. '01 3.4L 5vz-fe Attaching Fan Pulley to Water Pump Flange--Electric Fan Install
  110. front axle 4wd actuator question
  111. 1998 4Runner disk brake writeup
  112. 98 4Runner 4WD - Gas pedal vibrates
  113. 98 3.4 won't start, has codes for maf and igniter
  114. repin a 99 maf
  115. 97 4Runner ECU/ECM wiring diagram/PIN diagram
  116. 4x4 Tacoma CV Axles
  117. 99 Tacoma 3.4 oil leak after timing belt repair
  118. 2.7 3rz-fe misfire - po1305
  119. 96-04 3.4 Engines
  120. towing an 02 tacoma double cab
  121. Key sound
  122. need pinouts for 95 taco and 97 runner
  123. 3.4 swap 02 sensor troubles
  124. Steering rack leak!!
  125. 02 runner 4x4 auto trans rattling at start up and when on gas
  126. 1998 4runner 3.4: emissions sticker drama
  127. 03 Tacoma new owner - recommendations needed
  128. TRD tacoma struts in my 97 4runner???
  129. 2001 4runner p0300 p0303 vsc off vsc trac
  130. What are good mods for improving off-road capability without lifting?
  131. 96 4Runner Shock Swap Help
  132. 96 4runner having trouble shifting into 4wd
  133. CV boot cut or split open?
  134. 1999 4runner Rear driveline universal joints 4X4 constent Velosity
  135. p1300 code 01 tacoma
  136. overheating/electrical issue
  137. What size brake rotor do I need?
  138. Need help finding brake lines and bushings for my 99 runner
  139. 01 toy 4Runner
  140. NOOB Mistake Wrench on Battery
  141. If only one grease
  142. 4runner coil spring replacement
  143. Climate control
  144. 99 4runner apsr
  145. 2000 4runner way to disable alarm
  146. Headlamp Screws Worn Out
  147. Low range offroad harness
  148. p0141 ..can't make it go away.
  149. Intermittent engine knock - 1999 4runner
  150. Steering Rack qualitiy
  151. WRU Heavy Duty Lift Support Struts???
  152. Need help on front diff
  153. drive shaft wobble
  154. Need help with 3.4
  155. boost gauge Question??
  156. tuffcoat cargo carrier
  157. Swimmerboy2112's 1997 5 Speed Swap
  158. Increased fan blowing and lights getting brighter
  159. 4runner stalling out at traffic lights ?
  160. Engine pulleys; chirp, squeal, squeak, and wobble
  161. 96 taco no spark problem
  162. 2000 4Runner MultiMode Transfer Case Fluid
  163. 01 4R climate control lights
  164. Fuel filter/fuel line trouble on 96 4Runner
  165. Online Toyota Tundra FSMs - Some Still Accessible
  166. 96 4Runner door speakers
  167. OBD II diagnostic software
  168. Could this be the reason your 95-97 2GR-FE-3GR-FE Idles Rough?
  169. Stiff Automatic Shifting
  170. 96 4runner 5vz-fe, random top end knock?, link to video aswell.
  171. WOT redline rev limit not shifting
  172. key wont turn off
  173. DRL Mod Trouble
  174. 97 taco 3rz no spark no start
  175. Problem starting cold mornings
  176. P0306 code
  177. VSC/TRAC that bad?
  178. Lifter Noise/ Bad Valve? 97 4Runner, 3.4
  179. Check valve clearance; what else?
  180. 2000 Tacoma P1130 & P1135
  181. Help, 3rd gear power 'cut out'
  182. water pump change, wojt start
  183. 3.4 Manual Trans Water pump
  184. '98 4Runner 3.4 Overheat... fixed?
  185. Anyone run 285's on 17" tundra wheels
  186. 5vz Running Woes
  187. 3.4 idler puller removal
  188. Where to find new engine for '00 4Runner
  189. Timing belt installed incorrectly?
  190. Looking at a 99 Tacoma, should I buy?
  191. 98 4runner 4hi Jumpy? Help!
  192. (pics) Sunk 4Runner. Electrical, Mechanical, and Emotional help needed
  193. Power steering pump comparisons
  194. Terrible Toyota Experience/Misfires
  195. 3RZ cam and timing chain installation q's
  196. split 3 spoke vs coke bottle wheels
  197. lock panel in cargo 01 4R
  198. 97 rear window issue stumped
  199. 2000 4runner
  200. Texas 4Runner rough idle CEL codes repair advice?
  201. 96 4Runner lift
  202. Clutch issue - 2004 Tacoma
  203. Cat Efficiency Temp ??
  204. Help please: Moonroof opens randomly
  205. Dashboard lights not working
  206. hello everyone i need help tuning
  207. What is the size of the 96 Toyota 4Runner 3.4, fuel line?
  208. Oil Leak
  209. some problems with my 99 4runner
  210. 3.4 4Runner Won't Start, I'm Stumped....
  211. odometer broken.....
  212. 3.4 lower intake plentum
  213. Sonoran steel panhard build issue
  214. sylvania silverstar headlight bulbs brighter?
  215. Wiring Harness repair
  216. Disable ABS on snow
  217. 99 4Runner 2WD V6 Rough Idle When Warm Only
  218. drum brake help asap!!
  219. My 98 Limited 4runner
  220. Rear axle flange bolt pattern?
  221. 2001 Tacoma double Cab Lift help
  222. Just crunk up now won't crank
  223. exhaust mods
  224. 4wd dash light not working
  225. 2000 SR5 painted fender flares to medium black textured?
  226. 3.4 started smoking, now won't start.
  227. What's the best bake combo for a '99 tacoma SR5?
  228. Is rear quarter panel rust common?
  229. wiring diagrams needed
  230. Is this normal? pic)
  231. 4Runner Transmission issue
  232. Tacoma Inclinometer?
  233. Body roll
  234. Bilstein 5100 front shocks, compatible with Downey front sus lift?
  235. 02 Tacoma temp gauge at the 9:30 position.
  236. 1999 Muffler advice
  237. 4WD & Center Diff Lock Flash Flicker HELP
  238. motor price ?
  239. 91 3vze burning oil.
  240. 96 4runner 3.4 won't start
  241. P0340 code camshaft position sensor
  242. Tuning a Supercharged Engine?
  243. Lifter Noise and cold ac pump?
  244. Rear O2 sensor trick?
  245. what to look for when buying a 3.4 4runner?
  246. Air filter tube on 3.4?
  247. Backfiring 3.4 5VZE no CEL Help!
  248. Won't pass inspection...
  249. Steering Wheel Locked
  250. P0420B error code
