PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. 1997 tacoma with a 3.4 l v6 has no powere to anything!
  2. Ac compressor rebuild
  3. Looking for insight - Engine issues after a roll over. purchased wrecked
  4. UCA and LCA Bushing Question
  5. 98 4runner front wheel bearings
  6. Help me decide on front suspension. 3rd gen 4runner.
  7. KP Gasket Kit Review/Info
  8. Toyota Reliability and Durability
  9. Re gearing 98 4runner questions?
  10. Rear end?
  11. curious rear end wiggle over speed bumps
  12. my 2001 4runner. need something new to do to it
  13. 1997 4runner center support bearing? Can't find one...
  14. '96 4runner Limited won't start. need help!
  15. Stabilizer Links - 1998 TRD
  16. Looking for better suspension? Ideas
  17. Help: 96 4Runner won't stay running..
  18. Help. 1998 toyya 4 Runner -Overheated
  19. Frame ?
  20. 1999 4runner - Keeps losing lug nuts on one wheel
  21. Using 1999-02 MAF sensor on 1998 4runner
  22. help me determine the cause of this noise?
  23. Tacoma 3.4 idles at 2,000 RPM Help!
  24. Code 0171
  25. No spark cylinder 6
  26. 2004 Taco 100k Tune Up
  27. Air box to Plenum hose tank full of oil?
  28. 1996 tacoma top end knock sometimes????????
  29. 2000 SR5 4WD with ABS Rear Axle Differences
  30. driver side lean?
  31. Snorkle vs cold air intake vs deckplate mod
  32. Brake Problem
  33. 1996 4Runner inner CV joint
  34. Strange warm start up noise
  35. Timing Belt replacement parts and tools Q
  36. clutch stuck
  37. AC Question
  38. Replacing SRS airbags
  39. 1999 4Runner cigarette lighter light bulb
  40. '96 Tacoma add interval wipers
  41. 3" suspension with leveling kit?
  42. 2001 4Runner Won't Move
  43. JDM Swap 5VZFE using newer fuel injectors?
  44. Tranny trouble 00 taco 5spd?
  45. Under Hood Charcoal Canister Operation Questions
  46. Re-use OE hoses w/ trans cooler?
  47. Side-to-Side Rocking
  48. Supercharger Generations?
  49. fixing leaky clutch master/slave cylinders - what parts do I need?
  50. GF dropped a ring between the console and Seat
  51. 1999 4runner Fuel Injector
  52. Idle problems?
  53. Instrument panel lights
  54. "Experts Help!" Buying '99 LTD. with 242k.
  55. Reverse polarity? Now problems
  56. Toytec Ultimate Lift Q
  57. P0171 3.4 Running Rich
  58. Clanking noise and vibration
  59. Motor Mounts
  60. Buying 98 4runner with 230k miles?
  61. Auto shifter wiring diagram for 2000 3.4L
  62. Front cross member?
  63. Tranny swap question
  64. 99 4runner heater/ac control cable replacement
  65. can't do an alignment?!
  66. Transmission Temperature Musings
  67. 2000 Tacoma: Can't hold it in the road
  68. Failed Frame Inspection
  69. DIY inside bike rack
  70. who removed upper ball joint 3rd gen 96 runner?
  71. Broken security lug nut socket
  72. VSC TRAC, TRAC OFF, ABS lights -No check engine
  73. 3' TG suspension lift?
  74. '98 4runner tranny slip
  75. Illegal Modifications?
  76. overheated disc rotors
  77. 5VZ camshaft alignment
  78. 96' Tacoma purge/vsv issue - opinions needed
  79. gas&oil mixed lead to p0120 tps failed?
  80. Will a 4th gen (2005) 4runner rear end fit a 3rd Gen?
  81. p1126 code on 02 4runner
  82. Figure This One Out
  83. 1998 4Runner sr5 Lagging/Hesitation/Poor Acceleration
  84. Installed Daystar lift - blew out both CV joints on test drive
  85. Custom center console on 3rd gen 4runner
  86. gotted scanned today 4 codes pull up
  87. jacking up the rear, need height
  88. Removing front seat for car seat
  89. caster adjuster bolts freak'n TIGHT!
  90. Rear Bucket Seats in a 4Runner
  91. Sunroof leak
  92. Need Help With Brakes
  93. Leaking Rear Axle seals
  94. Heater - hot air only when moving
  95. 97 Tacoma wont start?? Help!
  96. clutch pedal sticks. wd40? grease? or something more?
  97. Tube door how-to wanted
  98. 98 Taco E-brake light...help!?
  99. Water stains on headliner. Where's the water coming from
  100. 4Runner transmission tugs
  101. Bad rear sag
  102. Spark plug thread is no good
  103. Wanted to post a brake bleeding method that worked great
  104. light styling.
  105. 4wd swapquestion
  106. O2, Evap, and Misfire question
  107. Overdrive question - 2000 4runner
  108. Pink Milkshake Paranoia!
  109. AC Compressor shaft chipped...
  110. Chained Tcase-repair/replace?
  111. Unplugged connector under engine
  112. 97 4runner front end grinding.
  113. Which fuel pump to get?
  114. Aftermarket or stock? Exhaust recommendations needed…
  115. 2 alignments, new shocks pass front tire still cupping, HELP!
  116. New to forum old guy
  117. AAAARRRRRGGGHHHH, New Cam Seal Leaking
  118. Tacoma t case
  119. Help: ID this cluster, 97 Taco?
  120. Help ASAP... Truck won't accelerate
  121. Mudflap Fail.
  122. shock stud centering collar w/toytec ULK?
  123. Tie rod ends
  124. steering gear adjustment?
  125. will 32's fit on a 2001 4runner sr5 sport 4x4
  126. auto rad in manual?
  127. 4runner to Tacoma engine swap?
  128. My new 01 4runner 4wd question
  129. cylinder #2 misfire
  130. Daystar Lift Issue
  131. Help
  132. Brakes suddenly weak and slow to stop
  133. Magnefine in-line ATF filter - revisited
  134. O2 sensor voltage and other problems
  135. Hello everyone
  136. 2000 4Runner valve body trouble - should I shoot this thing?
  137. 97 4Runner Ltd Suspension Help needed
  138. Axle Seal Disaster
  139. FJ cruiser rims compatible with 231 mm Tundra brakes?
  140. Rear end swaying when accelerating.
  141. 2001 4Runner dying computer?
  142. tacoma heavy duty rear leaf springs?
  143. Help needed finding a brake line part #
  144. Paint clear coat peeling. What to do?
  145. 03 tacoma manual hub conversion
  146. what's up with this ball joint??!!!
  147. Latest Cheapest Way to Lift 1997 4Runner Sr5
  148. 4runner hood with scoop on a taco
  149. a/c low side pressures?
  150. 4Runner transformation..
  151. Installed new diffs and now goes into neutral when engaging 4wd
  152. Is this worth fixing?
  153. Cheap Tube doors
  154. 96 Runner headlights hot side or negative
  155. 3.4L rebuild
  156. After Mudding, Spark Jumping
  157. 1999 Rear Sag - 3/4" Lower on the right
  158. Damp driver floorboard
  159. Help with rear bumper install 99 4runner
  160. 1999 Coil swap w/ Bilstein shocks -front end looks higher
  161. cylinder 2 missfire on 97 4runner motor swapped into mr2
  162. Can't get the bolt back on the CV shaft
  163. why do my headlights dim??
  164. Gas leak when filling tank
  165. 3RZ Compression Check
  166. '00 T4R front end grind/grating noise
  167. 3.4L (5VZ) - valve adjustments required?
  168. ISR mod and Deckplate!
  169. 1998 toyota tacoma brake light problems
  170. Greasable '97 Tacoma 4WD Ball Joints?
  171. 2000 tacoma 2.7 p0325 code
  172. Part # for OEM 2000 Tundra brake pads (199mm calipers)?
  173. 96 tacoma want to upgrade from HB1 sealed beam headlight
  174. 3" Lift Kit 1997 4runner limited
  175. help with a 96 2.7L tacoma
  176. Wiring harness question for swap
  177. What Suspension Do I Have???
  178. HID Kits for my 96 Tacoma..installing and whats best
  179. Sharng my CS130 alternator upgrade experience
  180. airbag sensor location
  181. If you cant take the heat get out the hood
  182. Difference in Runner and Taco brake boosters
  183. 2002 4Runner 4X4 Trans leak
  184. anyone have the fsm saved
  185. 4runner Auto Up/Down windows
  186. Brake fitting size
  187. Gentex Compass/Temp/Auto Dim Mirror Questions
  188. ECU issue....completly stumped!
  189. Another Starter Problem thread
  190. tune up / plug boots
  191. Well Looks like it is my turn for a ball joint failure
  192. 2002 tacoma axle shaft wanted
  193. Tinted Tail Lens
  194. Silly ATF Question
  195. RF window stopped working today, I could use some help.
  196. Need help w/ dashboard airbag cover removal
  197. Tacoma Vibration & Clunking Diagnosis Thread
  198. coolant leak problem?
  199. gearing
  200. Oil Pan removal 4wd 3.4
  201. Deck Plate and ISR Mods - Option #2
  202. tow hook on rear threaded ???
  203. 2000 4runner, 4th wheel bearing/seal in 6k! Really?
  204. Where to buy OME 881/890 set?
  205. Timing job. How to, parts, and tools needed.
  206. Mpg
  207. Timing Abd shimming price for 3.4
  208. V6 limited slip into 4 cyl third member?
  209. Tube style bumper plans?
  210. Time to lift the 01
  211. Bumps at 60-70 mph
  212. '00 4Runner Axle Stabilizer?
  213. Another ABS VSC Off VSC Trac Brake Light Question
  214. EMERGENCY engine fault... ever seen before?
  215. How the dealer screwed me today
  216. diff flange and driveshaft matching issue?
  217. Radio that fits 1995 Taco dash?
  218. What is this?
  219. plastic bumper trimmed pics
  220. Engine cuts out at full throttle
  221. 99 4Runner Odometer crapped out while changing dash lights..
  222. TRD Tundra strut dimensions
  223. 98 2.7L 4Runner (Blown HG/Cracked Block)
  224. Low Idle and accelerating slugishly any ideas????? Please help
  225. Clunking when I let off the accelerator but only at around 50mph???? Help Please!!!!
  226. How do I know if U-joints are going bad?
  227. 03 cutting out only at low speeds and full throttle?
  228. 3rz problem
  229. 2000 4Runner limited with clunking sound: Transmission or Driveshafts?
  230. Quick Tune-up ??
  231. Sensor type for a 99 toyota 4 runner sr5 with a Apexi S-AFC?
  232. 1995 cb radio install questions
  233. Toolbox for truck bed; brands and models with best fit
  234. 02 Tacoma grabby when driving
  235. Early 1st-Gen Disc Brake Question
  236. trans flush
  237. 96 4Runner V6 Crankshaft Seal Replacement
  238. Missfire when engine is started hot
  239. Interior light issues
  240. Ignition key hanging up
  241. Possible Pink Milkshake warning sign
  242. Shift linkage slack and slop 95 Tacoma 2WD Auto
  243. 3rd Gen ('99) 4R and '03 Tacoma Half Shafts
  244. Lots of codes - 01 4runner
  245. What vacuum line for sea foam 5vz-fe?
  246. Timing Belt Question
  247. Rust on my drive shaft. is it okay?
  248. good rim offset
  249. Time for new rear brakes
  250. 96 brake master cylinder brand
