- Truck Guard Ultra...Anyone heard of it?
- 4Runner roof rack on a Landcruiser
- California Mini-Trucks
- Uneven Tire and Shock wear?
- Tie Rod Replacement Info
- 3VZ Cross Over Pipe the reason why
- Replacing my auto hubs with manual-any gotcha's I need to know about?
- PF Brake Pad Dust
- Toyota customer satisfaction
- Rear Window Regulator (Ebay)
- Transmission Hump Hot
- 3vze exhaust valve
- HELP...Need Parts!!
- New Tires and Rims
- looking to get a new exhaust
- exhaust
- Rust ahh!
- New tires install, alignment needed?
- Power Antenna mod - mini write up
- 3rd Gen P/U - pic of sliders?
- Want to upgrade seats in 96 Tacoma, What fits?
- white goo in radiator
- LS & BPV Adjustments
- 22R Question
- Removing Crank Bolt with Head Removed?
- What gear?
- Which is bigger
- Should CEL flash at startup?
- UPS guy delivered my "new" soft top (PICS!!!!)
- Will this transmission work?????
- Nasty brake feel...
- modine radiators?
- Kickin' Revo Deal and 3rd Gen Limited Size Question
- Dynamat hood liner
- Lovin my yota
- Just bought 92 truck, interior question
- Hot smell?
- Rear seat stuck...
- Charcoal Canister
- factory gearing questions
- Just Bought TRD Exhaust...
- Tacoma or FJ Cruiser?
- Pic request of Speed Grilles by street scene
- Pic of 4-Runner with convertible top
- Colo. people -> more engine knock lately?
- Front springs in the Rear?
- Help!!!! I broke off 2 wheel studs
- FZJ80 springs on 4runner
- tune up worth?
- Electric fan
- Spare tire hanging
- WooHoo!
- Should I get my tires siped?
- Front Mount Trailer Hitch Spare Tire Adapter
- are these new lights by hella?
- Need injector help or something with the fuel.
- Where to buy front bumper?
- how much will a new tail pipe cost me?
- talk about carma
- looking for info on a 3rd gen power interter mod i saw on yt
- The air shocks are on!!!
- Durabak instead of paint job.
- 3rd gen 4runner push bar. fit on a 2nd gen?
- Stock 3rd gen 4Runner exhausts - single cat vs dual cat?
- Prolly gonna sell the 4runner
- steering rack bushings
- Engine Management options
- Need FAST info - dealer wants $1200 for driveshaft
- Cracked Windshield...interesting tidbit
- Urgent Towing Question
- Mounting lights on roof rack??
- a different, same old tire question.
- Backspacing Question
- How to tell gearing if codes don't match
- Need some advice
- Traded in the 2nd gen for a 3rd gen
- 95 3 liter 4runner problem
- towing limit
- Motor oil suggestions
- Is this a factory A/C setup?
- Block off EGR ???
- Emergency Brake Light
- abs light
- Fender Liner Mod
- Just a couple of hood scoop questions.
- Convertible Top for 86' 4-Runner
- Was rescued Saturday Night.
- a thousand dollars worth of rust
- Electrical Solutions
- Fuel filter nut stripped
- ball joint install....HELP
- K&N Intake question...
- 3rd Gen Rear Hatch Hydraulics
- pro comp es3000 vs es9000
- the gods are talking to me
- How do you remove shocks? (Rears)
- New Shocks
- 1997 4Runner Bumper Bolt Size
- new seats for the 87
- OPINIONS WANTED- possible bumper repaint
- old steelies please...
- Need 4wd help
- Good place to get tires in the BAY AREA?
- Can you guys help me find someone who has put a 99+ bumper on a 96-98?
- profields or long fields
- small lift on the cheap
- Oversized window ventvisors
- 3rd gen. Airlift outback & Downey 3.5 springs
- Question concerning Exhaust on 3.4 swap
- fan control wont work on 2nd gen
- Ajusting headlights
- Truck sits to high/lowering options?
- Finaly done
- My secret mod idea
- Truck doesnt run right.
- Shock selection question
- Anyone running 275/70R16 with a stock suspension? (3rd Gen)
- Electric Fan with Variable Speed Controller Installed
- Price check on a '84 4Runner
- Rear Suspention
- dash rattles
- Mounting a Warn M8000 onto the TJM T-17 Bumper?
- Aux Lighting/Wiring question
- Woohoo! We made it 400,000!
- Homeade aftermarket shift boot for 4X4
- 3 link and rear susp. Q's
- dash board removal
- Anybody Line-xed their quarter panels, fender wells?
- How do you fry a power steering pump on a 3rd gen P/U ?
- Square Driveshaft Paper for '85 4Runner
- New tires and rims... lots of PICS!
- Stupid stock decals, nothing is more 80s!!!
- 3rd gen inclinometer
- Flowmaster or Vortex?!
- Engine knoking when cold!
- Is there a solution to uneven tire wear on 4runner ?
- Is this truck lifted or not? Trying to decide.
- Pics for the guys who wanted them
- A/C help?
- V8 swap question...
- 94 toy p/u starts then stalls/replaced AFM
- my turn!! . I got a visit from DHL courtesy of CBIfab
- 84 4runner 3 link in the rear
- Do you get horrible gas milage? I have the answer!!!
- Blue Top Optima in a 3rd gen
- Fuel system problem
- Micro DE Fog Lamp Splash Guard for 3G 4Runner
- Rough idle on swapped 22re... Any ideas?
- Selling tacoma seat covers
- be gone bench seat- new buckets with PICS
- Blown Head Gasket Blown! '95 3.0...Looking for advice...
- got new tires, wheel question
- LCE alternator work on 3rd Gen?
- Alternative for wet okole covers?
- Volk Racing wheels
- 94 3.0 Air suction reed valve
- Exhaust Questions
- New to the game.
- a/c problem
- 1st gen rear travel
- New Sway Bar installation
- 1st Gen Air Induction Service
- Calling all VORTEX users...
- new 4runner :)
- Torsion socket change???
- Low Profile Bump Stops - Toyota IFS - Disadvantages?
- Need to replace engine for 91 4runner
- Stoptech Big Brake Kit Installed w/pics :)
- oil pan removal
- Dallas/ft. Worth Run
- UPS guy paid ME a VISIT! WOO!
- Rust Bullet
- body lift install
- Energy Suspension Sway Bar Endlink Kits
- my lift / shocks / tires -- PICS!
- MOOG Coil Springs
- What gauge wire?
- Somethings wrong.
- Map bulb size?
- Stripped bolt hole what should I do
- Gears, tires, speedo and rpm's
- Lose reliabilty with Upgrades?
- 93 Toy onkine repair manual
- Drive shaft counting for 4.88's
- Cool Steel Metallic
- My new 3.0 V6.......not as bad as I thought it would be!
- So many things.... so little time... so little money
- Identify this header?
- 5100's
- welders in temecula area??
- spare tire hanger
- Will a T-13 fit in my 1/2 4Runners cargo area?
- I might buy this runner how does it look?
- intake "growl" gone because of my custom mini catch-can?
- Push Bar & THULE racks ...
- 95-04 Tacoma Caliper Info
- 1st Gen Bumper ?
- 99 4runner Fuel Tank Capacity?
- When did Tacoma changed engines?
- 22re overbore
- Basic rebuild or stroker 22re?
- What/Who is T37?
- do mudders wiggle?
- Fan belts - V belts
- Gradient top of the windshield tint?
- New tail pipe
- To lift or not to lift
- 1995 FSM online
- for those who have painted your wheels
- c&d's 50th - 4runner 3.0 has worst 0-60
- Flowmaster 40 series or 50 series
- ARB Bumper Install Issue --- Comments / Suggestions (with pics)
- Finally decided on new wheels and tires....(pics)
- Wheel covers for 14" stock PU wheels
- 91 4runner seats in 90 extra cab
- should there be any play in driveshaft?
- Got rear ended.....
- Rear swinging tire carrier for 89 4Runner
- new lift option for front struts (bilsteins)
- dublin's 4runner with 33's w/o lift
- Sweet 1st gen runner in So Cal....
- 4runner pops up in game!
- Oil prefrences for a 3.0 with 111K ( Bought car 5 mnths ago & dont know whats in it)
- RIP My Runner head on crash...
- Exhaust prefrances?
- gas mileage..4 compared to 6
- my 05 has problems!!!
- will i drain the battery?
- Avon Tire ?'s
- i need advice on gears. please help
- Found the runnner for sale...
- 01 4Runner pulls badly to the right
- 95 Toyota 4runner (Engine Died) HELP!!!
- Driving a 3rd gen hard. bad?
- need a fast answer on 1998 Tacos
- CALLING ALL SMART 1st GENERS
- Thank god for that damn hitch!
- any 1st gen 4runner towwing a boat?
- Did the Deckplate mod. How long should I wait?
- Newbie w/ Questions...
- Are you running 15's on a 02-04 Tacoma?
- DFW area people
- Lost power, found problem
- Question for all you Toy buff's out there.....
- should have a new toy in a week.
- Price Check: '98 4Runner, 138k, $9950?
- Front Bumper Relocation Bracket.
- Pics from Northern Maine...
- Throttle Body Squeeky Clean
- rear window problem solved & 1 other problems
