PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. My "New" Ride
  2. How to fix punched in hatck lock?
  3. Anybody still running an Aussie on 3rd Gen?
  4. NGK Spark Plugs, Pre-Gapped?
  5. How do I replace thise piece?
  6. Armrest Mod!
  7. HELP no power windows and I can't shift
  8. Rear axle oil seal and upgraded shaft?
  9. Steering rack bushing RE: washer
  10. 98 4Runner Speedometer/Odometer input adjustment
  11. 3rd gen 4runner intake / air filter combo
  12. body lift / susp lift need advice
  13. Epic Ball Joint Failure
  14. Gear Ratio
  15. 4runner pulls to the right in 4 wheel drive
  16. Advice on what to take from another 4Runner
  17. Week frames on 2000 tacomas ?
  18. Air conditioner control buttons not responding intermittantly
  19. Removing moulding/running boards on '98 4Runner?
  20. Best Shock with OME 882
  21. Factory Rear Leaf Springs
  22. Convert 97 runner, to 99 fat lip bumper
  23. camper shell that fits a dirtbike
  24. What do you call this part?
  25. 3VZE Valve Troubles?
  26. upper ball joint into pro comp spindle help
  27. Plexiglass 3rd gen window
  28. Anyone done this in a 01-04?
  29. starter
  30. wont move in drive
  31. 2000 4-runner engine misfiring
  32. 96 tacoma clutch
  33. Picture/Description Request
  34. 5VZFE alternator disassembly?
  35. 3rd row seat install in a 3rd gen 4runner
  36. P1126 “Magnetic Clutch Circuit” code with a CEL
  37. How many miles on your 3rd Gen 4runner?
  38. What to do with IAC valve?
  39. 4 runner steering issue
  40. Starter Problem
  41. bad igniter or other ideas?
  42. 1998 SR5 Fog Lights
  43. Trans Pan Gasket - FIPG or Autozone?
  44. 2 differnt coil packs
  45. Bump stop removal
  46. 2001 4-runner: Erratic tachometer reading
  47. 16" Ivan Stewart TRD wheels
  48. Oil Light Ignored - Now What?
  49. Control arm bushings and ball joints
  50. Engine Enigma
  51. is your leather soft?
  52. Sunroof won't open
  53. Outer oil seal wierdness
  54. Does 3.4 V-6 have EGR?
  55. How can i fix this exhaust problem?
  56. check engine light (02 sensor)s
  57. hard and notchy shifting
  58. oil cooler hose... from waterpump to oil cooler..
  59. (pics) Painted LC rims, 255/85 tires and 1" BL
  60. rarity of a 3rd gen 4runner?
  61. Goodyear MTR? No more!?
  62. Cooling system treatment & rust/scale/oil remover?
  63. 3rd gen 4runner exhaust super 44 vs super 40
  64. new member here with a newly rig!
  65. rear propellar shaft u-joint replacement (01 taco)
  66. Rear Wiper attachment
  67. Need instructions for progamming 98 4runner keyless entry
  68. steering making noise after starting
  69. Codes P0400 and P0071 Thrown. Emissions?
  70. Passenger side floor wet.
  71. Rear Diff Locker
  72. My New 4Runner
  73. Front sway bar end links broken
  74. still leaking after inner axel seal replacement.
  75. Awful thud while in 4WD
  76. Rack and pinion pressure feed and return hose wanted!
  77. Leaking Freeze plugs 3.4L
  78. Transmission Cooler Lines 96 Tacoma
  79. Running boards
  80. My first tow..
  81. I got rear ended. What do you guys think.
  82. 01-04 taco vs 01-02 4runner
  83. Maf rewire, DTC now
  84. Tacoma Lift
  85. Will cargo door panel from a 98 fit a 99 4Runner?
  86. Quality Struts, and/or a lift.
  87. Installed 4 lights on Rack
  88. Prepping a stock 99TRD for MOAB
  89. K&n fipk
  90. Adjusting Parking Break (passenger side not engaging)
  91. Changing the 2 tone, new black/tan
  92. Is radiator regular replacement item?
  93. stailness steel braided hose for tranny oil cooler?
  94. Don't know if I should continue throw money at
  95. Defeating the ADD system?
  96. Lights for rocks and other things of that nature
  97. 99 Taco Rally/Street Project need help
  98. 96 Taco - Rear end clunk
  99. True Flow Filter Oiling Kit Discontinued?
  100. Transmission from 2wd '00 fits what?
  101. Engine with A/C on Sounds like an old Diesel
  102. Noisey Power Steering Pump
  103. Ball joints and Tie rod ends
  104. Finally decided 2 pull trigger on shrockworks front bumper 2 find out 60 day wait! :(
  105. camper load lift kit
  106. Slack in rear axle
  107. Using other OEM brake fluid..???
  108. Why is it so difficult to find "3/8 transmission hose"?
  109. rust in my coolant
  110. 4runner wont start! Help please!
  111. Key won't turn over all the way to start
  112. Wondering if 95 runner rear quarter window glass will fit 2000 runner
  113. 5th Gen 4Runner
  114. Front Struts 95 Tacoma (Stumped the Parts Guy)
  115. Driver's window is stuck
  116. How do I check if my RS3200 VIP is dead or keyless remotes are bad?
  117. Do I need to replace my timing belt? 01 'Runner 100K Miles
  118. Name of pictured part
  119. How much is too much for maintenance
  120. Anyone have OME headlights to trade for mine?
  121. Tundra brakes, finally!
  122. Which headers are compatible with a 1" BL?
  123. technical question about bilstein 5100/5125 adjustable height shocks for lift
  124. 97 v 99 rear springs q
  125. smog check P0505 error code
  126. Starter Problems
  127. Keep throwing axle bearing....help!?!?! PICS
  128. Junk or Not??
  129. Not sitting level
  130. Swapped out my spark plugs on my 1999 4Runner
  131. TJM returns to America: possible group buy
  132. Shaking!
  133. Always Heat
  134. Cupholder Fix!
  135. Front Bearings Replacement
  136. Low idle and engine stall
  137. looking for a prerunner style bumper
  138. greasing the slip yoke
  139. sas'd 3rd gen 4runners
  140. Underglow vs. HID Headlight vs. Cold Air Intake
  141. Tires Rubbing??
  142. My 95.5 Tacoma
  143. A good rebuilt axle?
  144. Installed Hella 500s
  145. 2003 4x2 auto Transmission
  146. Weird noise drivers side dash
  147. Knock Sensor Pin Locations - 1997 4R 5vz
  148. Front end pop
  149. Car Seat for xtra cab
  150. Funny noise
  151. Trick to removing rear differential???
  152. Power Steering Fluid Leak
  153. lining up timing belt marks
  154. Thinking of rebuilding caliper
  155. 1996 Exhast Question
  156. 3rd Gen Bumper Light Mod
  157. Emergeny Brake Issue
  158. Rear Differential Leak
  159. working on t.belt w/p right now HELP
  160. 2001 antenna mast no worky
  161. 99 4runner engine problem
  162. hypertech
  163. So my mechanic installed 5mm sparkplug wire on my 96 Taco. Is that okay?
  164. Good rain/weather deflectors?
  165. 33" Spare???
  166. Directional not working
  167. Parts & numbers / Exploded diagrams ?
  168. still seemingly no rear brakes
  169. Clutch line question
  170. Help remove p/s hose from gearbox!
  171. Brake prop valve on 96 Runner?
  172. 2004 tacoma ring and pinion
  173. Speedy's Long Term Supercharger Update
  174. Whining sound from rear somewhere - how check the differential fluid?
  175. 96 4-runner engine problem
  176. Any 99 Limited w/ Multimode and a 5 speed?
  177. tie rod replacement: do I need to jack the truck up?
  178. crank seal question
  179. Donor motor (wreck) showed up Now what?
  180. trailer light fuse
  181. Tacoma Lift Options???
  182. Brake Problems
  183. lifted the runner
  184. Crossing high water - how high is too high and what to watch for ???
  185. Fuel Filter Line Issue
  186. Not shifting all the way in to 3rd and 4th
  187. Lightforce 170 Strikers installed
  188. Body Lift Removal
  189. Rattle in the front passenger floor board
  190. Strawberry Milkshake-Replacement Radiator Follow Up
  191. CV Boot slipped off.....
  192. Again with a gas guage issue (not sending unit)
  193. Changing the belts.
  194. 98 4runner lift and CV questions
  195. [97 4-R] Power Steering Leak w/ Pictures
  196. A03A gear ratio
  197. transmissions woes II
  198. Not so happy after Tundra brake install
  199. Aftermarket ball joints and bushes '02 4Runner
  200. Good Shop in Cincinnati
  201. 99 coils in a 96 do I have to replace my shocks?
  202. Total Chaos LT kit
  203. 2002 3.4L V6 knock issue and maintenance
  204. Elocker Cable Conversion
  205. Axel shaft bearing removal + bearing Q?
  206. common hose clamp size (hose Outer diameter?)
  207. Can't decide on front shocks w/ 881's
  208. Stock rear shock specs for 2002 4Runner
  209. arb bumper will it fit??
  210. Need Advice on Transmission Replacement
  211. OME N140S & 886 on 3rd gen but they don't fit
  212. I'M BACK!!!!!! Introducing the Crustang
  213. Questions about Hood and Satoshi Grille Mod
  214. My suspension plans.
  215. Factory Windows
  216. Felpro gaskets
  217. Will '99+ key work in '98 ignition?
  218. Replacing rear bench w/ buckets in my 4Runner?
  219. Spare tire size???
  220. Low Fuel light keeps coming on
  221. cb radio with pa
  222. axle seal replacement price
  223. my lift plans
  224. Heated mirrors on 3rd gen 4Runners
  225. Shrockworks Rebate
  226. transfer case stick removal and assembly help
  227. Supercharger Questions
  228. 00 rear driver side window intermitent. Suggestions?
  229. 3 to 4 inch soft ride lift ?
  230. Studbuilt Skid
  231. check engine light
  232. OME 883s Installed w/Pics
  233. Group Buy for 3.4L (5vz) Crankshaft Pulley.
  234. Difference between 2.5" lift and 3" lift
  235. Our new rig
  236. ARB Bumper install from HELL
  237. Rough idle for 5-10 seconds after cold start
  238. name that sound (with audio)
  239. Water Pump Recs. - 01 3.4
  240. EVAP/VSV/VPS/Gas line routing on CA 96 4runner 3.4L
  241. Do you need a TPMS valvestem to run FJ wheels on a gen3??
  242. 1999 4Runner Highlander For Sale
  243. CV Axle Replacement
  244. 3rd gen runner power door lock question
  245. Independent Fog Light Switch
  246. rear wiper washer, how to make it better?
  247. Gaskets Needed for Engine Replacement?
  248. check eng. light
  249. Auto tranny "clunk"
  250. Custom Bumper I built for my 99 limited
