- May 00' 4Runner W/01' transmission parts?
- Thieves Suck
- 99 4runner oil filter???'s
- Oil in Throttle body.
- Is my clutch going out???
- quick question
- Pics of my rig finally!
- 99-02 headlights intalled and more
- Land Cruiser Wheels Installed
- 98 runner keyless lock problem
- cyl 2 misfire. help
- engine surge during acceleration
- How tuff are the bottoma of the 3rd gens?
- Will '01 Springs fit '96?
- Coolest Bug shield out there for a 99 runner
- Heater fan wont turn off
- 02 4 Runner Ride / 99 Springs?
- I think my tranny died
- Pics of 97 4run to 99 4run headlight and airbox conversion
- 98 4runner 'power blip?' Help
- powdercoat costs
- replacing instrument cluster
- Driving Lights - Which are Good ?
- Any one heard of liberty gears (ring n pinion)
- First Post - My new 2000 LTD
- Gen III 4Runner Disel Swap???????
- resetting the ecu
- A PO420 success story
- 01 Tacoma w/ Black Grillcraft w/ red TRD badge (Ivan Stewart look alike)
- Where can I find a rear bumper cover?!?!
- look what i found
- 15" wheels on a 2000 4Runner SR5 ???
- 96 4 Runner Rear Wiper
- QUESTION: True Flow air filter effectiveness
- EGR Valve...
- Tacoma BBS Wheels 18"
- 3.4L vs 2.7L
- Weird Oil Leak
- Can't pick the right shocks...
- Hesitation on acceleration
- Looking for
- New Here i own a 99 4Runner!
- UCA's Taco To Runner
- check out my new sport hood!
- Some fabrication for 3rd gens...
- 2000 4Runner w/ 08 Tacoma wheels/tires
- Sunroof/Moonroof closes half way...by design?
- What size wheel spacer for oem 5-spokes on 315/75/16's????
- rattle at 2000-2600rpms
- does anyone have torque values?
- New Setup....PICS............
- 4WD question/problem
- Thinking about rading uto a 96-02 p/u
- Help! 96 T100 3.4L won't start... No Spark
- looking to sell any ideas?
- Lightest/best tire out there 265/75/16??
- Sudden Gas Mileage Drop
- 97 4Runner tranny noise: only low gear
- cd changer question
- fender question
- Trade 98 4runner for similar Tacoma?
- Anyone liking their Kuhmo AT's KL78's?
- 01 4Runner sprung a leak!!! No no.. not like that...
- Muffler Questions (I'm Sorry...)
- 2JZGTE Motor swap...
- Time for new Offroad Rubber!
- steering box jacked???
- Tacoma oil pressure gauge
- Swapping A/C controls
- 4runner in southern az snow *pics*
- Which should i do next?(2 choices) suggestions welcome!
- searching for a 99-00 4runner
- 3rd Gen 4runner drivetrain slippage
- Running boards and mud flaps removed... *PICS*
- What to look for? Might be buying 3rd gen
- yota pink or yota red coolant
- Totaled (rollover) 4-runner purchase Question....???
- Question on Tie Rod End Hardware
- Help With Alternator Drive Belt Adjustment
- 2.7 gutless in high rpms
- New Truck!! (Pic)
- Stock rear shock valving
- Will I encounter lift problems
- HELP! 4wd not working
- ?s about Hilux tire carrier
- Anyone use MT tires in the sand?
- '97 4runner 4x4 2.7L For Sale
- P0136 code
- Help! Install gone wrong!
- 2 questions regarding 99 4Runner.
- rust control
- Knocking at Start-up
- ARB Locker part number, spline number?
- 2000 5spd 4x4 on ebay
- New Lower Control Arm Skids Installed
- Pulling engine off transmisson (3.4L V6)
- 2000 4Runner Clunk
- Which Wheels????
- Custom Grille Insert < Pictures Included>
- 2000 4Runner SR5 wierd flares
- My New Audio System Polk Audio db6501 Components and maybe new sub (ongoing project)
- OME Install Q's
- More about beaches: Which compressor
- new tjm installed
- 2002 4Runner RS3200 Keyless Entry
- Quiet muffler for a 2000 4Runner?
- Disable rear heat - 3rd gen
- Rear shocks
- What is this noise
- have my coils!
- roger brown or wabfab bodylift
- Dome light with remote unlock?
- Help!!!!
- Wrenching in Madison, WI
- Is There a differance between front drive Shafts on ABS and Non-ABS equiped 4Runners?
- Sunk to the roof
- Suggestions for tires for BEACH driving?
- Broken fan shroud
- stuck key
- 02 Sport lights/wiring help
- '01 Tacoma FAILED CA EMISSIONS???
- Squeeling Noise When I turn my steering wheel all the way in both directions???
- Tinted my windows woot! (PICS)
- What Spare Parts to Carry
- K&N Cold Air Intake FOR SALE!
- Anyone had this happen???
- loud exhaust on 3rd gen
- Help with LED tail light bulbs, fast flashing like bulbs are burning out
- What is this part? And is it replaceable?
- What backspacing to go with
- Sonoran Steel 7.2
- Seafoam in Fuel Tank or Injector Cleaner
- lift for prerunner?
- Bleeding Master Cylinder
- Looking for 3rd Gen T4R Drive line parts online
- Satin Black Paintjob and Additional Lift
- Bg 44k
- 3rd Gen rear bumper paint over chrome
- Another gas mileage question...advice please.
- Replacement Body Parts
- TJM and Warn M8000
- Another new 3rd Gen Owner with pics
- Problem at 55-65 mph. Any ideas?
- Why diiferent brake calipers but same pads?
- Cup holder solution or not?
- What type of differential fluid?
- diagram or pic request for 3.4L cylinder layout
- converting 5 speed to auto
- truck would not start today!
- 2000, 4Runner Limited, climate temp control knob
- paintable grill
- Thinking of selling my '02 4Runner Sport
- Need Pics of Horizon Blue Metallic
- badlanz exhaust cutout
- Clutch issues got any ideas
- add-a-leaf for taco OME springs?
- Anyone lowered their 4runner?
- would this work as a leveling kit for my 2WD?
- 01-04 toyota tacoma hood with 4runner scoop trying to get made
- 1" Rear Block, opinions?
- 3rd Gen with 35s ridin high
- 4Runner driveshaft rebuild , parts ?
- Dose anybody recognize this truck?
- Finished the cupholder mod
- Quick Axle Seal Question.....
- Rear End and Limited Slip Question?
- 98 ltd - broken cup holder (dash)
- Supra TT Maf, FTC tune
- 99 Tacoma V6 Hesitation problem
- My much loved and well sorted 98 Limited ...
- Trading a 97 SR5 for a 2000 LTD
- Pulling trailer with car on it?
- Another High Def Video added to Website
- finally new o2 sensor, CEL back on again
- Muffler advice
- 1996 4R ARB bumper install questions
- Snow Chain Recommendations???
- Suggestions Please
- New Lift and Pics.....
- 3.4L S/C How Much Boost ya got
- lifting 97 tacoma for 33's
- Thermostat Jiggle Valve?
- stock ride height
- Just sold my 4runner :(
- '96 4Runner - Should I purchase???
- 5 speed transmission whine..?? '97 tacoma v6..
- Looking for OHM readings on the IAC valve 2.7 2000
- Dealership Radiator Flushing argh
- Which wheel spacer?
- Muffler recomendations
- grease come out lower ball joint
- Newbie needs help!
- Header/Exhaust Advice (98 4Runner 5VZFE)
- 99+ Fog Lights are junk.
- want to run a set of 315's...looking at 3" lift + body lift, need some help
- IAC Valve Cleaning
- 1997 3rd gen airbox mods?
- Starter contact symptoms?
- 99 runner fenderflare
- 1.5 inch coil struts wondering if i can add a two inch spacer to it
- anyone know where I can get a DRL module for my 01 4runner?
- T belt.
- fender flairs
- Nate's Exhaust Thread: Magnaflow
- Converting 97 tacoma from A.D.D to manual locking hubs
- passenger side window issue
- Replacing Starter with TRD headers?
- Just bought an '01 runner.... help diagnose noise please!
- Other parts to replace along with brake calipers?
- Hella Micro DE Fogs...2 models...
- Braking issue...
- Some squealing noise from Alternator...
- cut out fenders
- Body swap on a 3rd gen 4runner?
- 96 4runner 4x4 problem
- -Picture Request- Before/Afters of 1-1.5" wheel spacers
- Milk don't belong in oil - arrrrggg!!!
- Rear window problem
- Recommendation for shock replacements
- tundra coils?
- Wheel clearance for Tundra brake upgrade
- OEM Remanufactured Parts from non-Dealer?
- New Starter and battery, but won't start?
- Bleeding brakes and MC question
- Advantages of the 3.4
- AT Transmission is on it's way out :(
- 3rd Gen roof cross beams?
- ABS light came on when i was driving home.
- Roof Top Tent on 3rd Gen 4runner
- 15" rims on a 96 limited?
- Persistent Starter Problems on 98 4Runner
- Can Someone help me with Flare Part Numbers???
- oil leaking from spark plugs
- Headlight Switch?
- 98 4Runner Battery Cables
- What is a fair price?
- Running Lean
- Testing Idle air controll valve
- TRD wheels for sale on ebay - florida
- steering rack bushings
- Engine Surge during Acceleration when Cold
- First 3rd Gen 4Runner. My new DD!
- Is it the water pump?
- Cut back muffler, Bad idea?
- 98 4 runner with factory alarm question..
- What is on your plate this year for mods
- Tacoma wheels on my 98 4runner
- Finally 255/85/16 on my 99...
- getting closer ths sound like a good deal
- Pics of 4runners running Boggers.
