4Runner driveshaft rebuild , parts ?
Old Jan 28, 2008 | 06:34 AM
bonzi88's Avatar
Question 4Runner driveshaft rebuild , parts ?
Rear driveshaft vibration on my '96 4Runner is getting a little worse now,time to rebuild. At first it was just a small vibration , kinda about 3000 rpm-ish around 60mph + . Now when i take off , sounds like a carrior bearing rumble , plus the highway speed vibration. Kinda isolated the slop to the front double u-joints (carden joint ?) on rear driveshaft.
Where the double u-joints are, i assume there's a centering ball and spring. Is their a parts kit for that avaiable somewhere ?? Part numbers and any advise would be most welcome. Thanks
I don't really want to spend 4 bills on a new driveshaft if i don't need to.
Old Jan 28, 2008 | 08:52 AM
Ultraman V's Avatar
I just went through the same thing.
Not trying to be a jerk or anything but just asking the obvious first, have you greased the carden joint? My truck has 190,000 miles on it and when I bought it six months ago the u-joints were really dry. I greased them all up and got rid of 50% of my vibrations.
Still having some issues I took my drive shaft in expecting to hear that I needed a new carden joint but mine was perfectly smooth. I had u-joints installed on both ends, had it straightened and balanced all for around $200.
I guess I would say be sure that's your problem before forking out the big bucks on a new joint.
just my $.02.
Old Jan 31, 2008 | 08:36 AM
bonzi88's Avatar
Amazing how a bit of grease took care of 70% of the vibration. Guess i didn't really understand how the joint worked. Was thinking old school constant velocity '72 Impala type. Thanks.
Old Jan 31, 2008 | 10:02 AM
dirtoyboy's Avatar
U joints should be serviced EVERY oil change or MORE depending on driving conditions. This is the most common reason for ujoint failure and it can be avoided completely
wberry85
Jul 6, 2015 03:24 AM
Valvoman
Jun 28, 2015 02:45 PM
Niameyrider
Jun 25, 2015 05:50 AM
yamaha73
Jun 18, 2015 06:19 PM
TheManOutside
Jun 18, 2015 03:32 PM
