- Triple guage dash pod
- 5x8 vs. 4x9 muffler
- cheap tires
- tps sensor ?
- Want Clear Tail Lights Cheap?...Check This Out!
- Got my new bumper! *finally*
- News on 2005 Tacoma
- 3rd gen shocks for lifts
- Need help! - just took off my skid plate...
- 1994 Xtracab pickup 4WD 27K miles!!
- Custom Bumper
- 3.4L Engines Destroyed by Detonation??
- double vision
- Clutch/Tranny Whine
- '02 Foglight bulb replacement?
- Brake conversion?
- 2nd Generation 3.0 Performance Chip Info
- Bolts to check & tighten before goin off road
- Car started shuddering when braking last night :(
- ever see this one?
- How much Of my caliper can i take off of here w/o problems? (PIC)
- Toyota paint
- 3.slow to 3.4L swap questions
- Best way to tone down a LOUD exhaust?
- A Few questions
- 22r pulled a 21' boat!
- Lighting question - multiple switches off of one relay
- Reverse lights not working
- Anyone have a pic of a tacoma Caliper?
- I'm going to be a proud owner of a.....
- Oh god do i want these!
- Checking Gas Mileage
- What Auto tranny with 7mgte swap...4x4 extended cab???
- Performance Products
- keyless entry?
- After 3 wks of hard work . I finally painted my truck, Woo, Hoo PICS
- cap and rotor for 3.0 question
- Do I really need Amsoil Engine Flush??
- More on Exhaust
- Bought some 16" Taco Wheels-Tire ?'s Again
- Front breaks/wheels making clank noises
- cab visor for 1987 pickup
- Dumb Idea??
- 2000 4runner running boards
- Magnaflow 11225
- Looking to get a new 22re
- 30 or 15 degree rock sliders?
- Air Shocks?
- Thinking about Nitrous. Maybe a 50-75 shot.
- 22re starting problems
- Engine Swap
- Downey rear HD coils springs installed
- Timing Survey
- Want to buy used cheap winch
- Aiming Headlights on 4th Gen
- 3.0 PCV valve replacement?
- jeep seats?
- Question About rollbars
- Rockstomper Motor Mounts
- OEM valves and seals
- Crossing water..
- 3.slow - Why?
- Cams on the 3.Sl0w
- new fuel filter,,,,is it possible?!!!!!
- Improving range of keyless entry
- Help with switches!
- resonator and AS reed valve
- Window Tint
- Performance Shocks
- will this work??
- Canadian dealer wants $125+ for shipping of a hood guard?
- fresh & clean
- benefits & drawbacks
- Finally Lifted (SAW/OME)
- my 4runner....
- Steel Brake Lines
- need engine for '94 4runner
- Reoccurring intermittent wiper problem
- Tacoma corner lights
- shes on cardomain now, check her out
- 99 still running lean
- IPT vs. LEVEL 10 - who wins?
- Questions on lubrication points
- Oil filter change (not the oil)
- 2nd gen 4runner Clutch Slave Location?
- R-12 to R-134a Conversion
- Satellite interface works with factory controls
- stupid question about the 3.0
- VAF - problem '95 Truck
- 96 4runner 4 cyl engine noise & 'lurch'
- Seafoam for oil?
- anyone interested in an 01 hood?
- compression problems
- 3rd gen full rear axle swap: What should I expect?
- I Think I Found Xm Factory Control
- Why Dealers Suck
- Alternative to TJM/ARB Bumper/Grill Guard
- MAF Problems
- Spare Parts to carry on the Trail?
- Who does valve jobs?
- rancho 44o44s on back what on front
- 1st Gen 4Run O2 Sensor Problems
- 3rd gen LTD runningboard removal???
- pro comp pre-runner bars
- TCase Shifter Problem
- 22R Carb to EFI Swap
- Removal of Rear Diff
- Cheapest 4x4's nowadays... ideas
- Custom Grills
- Need opinions on what to do with my Runner
- gas mileage varies per state
- HOW MUCH 134a?
- Winches are for Wimps!
- 1995 rear wiper blade replacement
- How to remove MAF sensor?
- Question about trd thermostat?
- Just found a 90 SR5 4 runner and I need some opinions...thanx!
- Ideas for where to mount an air tank in a Taco??
- Maintenance light and warranty
- Question on Brembo rotors
- Steering Wheel Remote
- Best cargo liner??
- XM Radio Adapter
- good vid of Surfs with supra motors
- New Here.. Have a Couple ?'s on a 94 Runner
- 3rd gen popping when turning hard r/l
- Finished our 1st-gen 4runner 22RE rebuild
- Where should I order my gears from?
- K&N filter FIPK AND OEM shocks/Struts on ebay for 9.99 start
- Taco rear leaf pack replacement questions
- Add a Leaf Questions
- Rear coil isolator??
- 1_z-lock? 2_custom soft top ideas 88 runner
- Screw close acceleration cable.
- just got a lift of the yota
- Water Storage
- Power Inverter
- Pictures/Videos of my Truck
- 20r vs 22r exhaust manifold
- 93 pickup need idias for more power?
- Rear Window Guides
- Another A/C question
- vin vumber search question
- 90 4runner windshield fit my 92 P/U?
- Need Help
- down travel uneven?
- Steamy Topless Pics!
- PIAA 12v Horn.....Thats right...PIAA
- Gen II Exhaust Questions
- Preload spacers and non
- Tires
- 4runner exhaust??
- 2nd Gen Chrome Grill
- Engine Replacement
- OME Installed! Pictures.
- ahriman's 4th gen lifted & shoe-d [pics]
- Check out my other Toyota!
- Surco rack need fairing advice.
- Preparing for my lift!!! WOO WOO
- Toyota factory paint Thunder cloud/thunder grey
- The Ugliest Tacoma Ever
- Anyone ever use Time-certs to tap threads?
- Runs on starting fluid, not gas
- Anyone out there planning on lifting but still needs rims AND tires?
- possible coolant sources help
- a taco question
- Idle hanging up at 1100
- '01 Runner for '94 FJZ80 LC?
- '03 4runner /Sequoia wheels---PICS!
- Cramped in 2nd gen... another solution?
- Rear ABS - sensor on rear end housing?
- Semi_Mettalic or NAO Organic brake pads ?
- Lights won't turn off - 2k 4-runner
- 02 SE AWD strange rubbing noise?
- 03 TundrA limited 4x4 ??
- auto tranny help 1st gen 4runner? UGHHHHHH!
- Chrome valence pic's wtd
- first rough start
- Finally Finished the rig (PICS)
- ISR MOD Query (yes i've searched)
- OME Installation... #@$@!!!
- 90 v6 to 4cyl swap
- ARB's service center/dept rocks!!!
- Painting a TJM bumper
- Clicking noise within R front wheel while in 4WD
- Lefty's 4th Gen belly skid prototype completed - DIAL UP BEWARE
- TRD Sc 3.4l
- New Gears and Lockers are in!!
- clutch bushing
- Need a photochop or pic of 84-88 clear corners & turn
- How much fluid from an auto Transmission drain on a 2nd Gen?
- Help
- Line-X My Bumpers Done! - Pics!!
- type of Catalytic coverter???
- New to forum. Need help with fitting Revos
- niose while turning 2nd gen
- What is the standard size ball for a trailer hitch?
- Looking for some Vents for my '91
- burning oil
- plug wires?
- What's a good asking price?
- Need part
- My website
- How much is your dealer's hourly labor rate?
- Rough Idle & ECU Codes
- 22RTE for sale near me
- steering question
- A Hilux Surf V6 - The best options...
- check engine light Q for 2001+
- Need a Power BOOST
- Need new shocks and coils NOW! 92 4runner
- 3.0's and Oil pumps...
- Violent "clunk" after letting off gas?
- bad cat?
- Bizarre ways to trade for/buy your Toyota?
- Where to get Roof-Mount Light Bar (besides safari rack)
- New to forum with a lift ? for '02 tacoma
- Performance parts
- Going in for service tomorrow, please help.
- If You Have Steel Wheels Please Help Me Out!!!!
- 03 Brake question for all you brake experts
- 03 4runner Jaos grill, eyelids, and exhaust (Pictures)
- 2000 4Runner headers
- Check these Out...Rear taillight question
- Anyone using TRD exhaust for 97 runner V6??
- 3rd Gen pickups
- 22re Turbo gauge swap
- '85 pickup 350 swapped, help with driveline
- Best Price On Antenna Mast
- are 3rd Gen and Taco Rack and pinions the same?
- Any ideas for my lady friend....
- Steering Stabilizer???
- 3rd Gen tranny question???
- 3rd Gen idles a little rough
- spare tire carier broke and someone took my spare!!!!!!
- My first attempt oil change on 2004 4Runner
- Cam/Engine Break in and What Type of Oil?
- urd supercharger performance kit question
- Pricing Question
- 17" graphite Tundra/Sequoia wheels...
- Any cure for noisy rear coil springs?
- Tire dilemma...opinions wanted!
- Toyota warranty question
- Gear grinding noise when vehicle at a standing stall or rolls back
- Metric or SAE?
- 1st Gen 4Run Brush Guard?
- 94 3.0 EGR Replacement
- 3.5 bore on throttle body? Rich/Lean
- Yet another Shock Thread. . . .
- mudflaps, not just for mullets anymore
