- Scion T1808 in 3rd Gen 4Runner
- cyl #1 running lean and missing
- 1kw lighting system help
- 3RZ Headgasket... how to?
- Did any 3rd gen. 4Runners have steering mounted stereo controls?
- 99 4runner throttle response
- In my case OEM or are aftermarket headlights good enough?
- Any Gains porting 5VZ-FE heads?
- Rough idle and stalling when starting engine?
- 4:88's + 315/75/16's = MPG?
- 2000 4unner - Brittle Trans Solenoid Connectors
- 99 4runner tranny problem
- 5VZ-FE engine wont start.
- 97 4runner v6 tapping/ticking sound at idle
- taillight converter question
- Please help diagnose dead engine.
- A better exhaust system
- speedo not working and ABS light on suddenly
- Injector Swap
- 98' Tacoma won't shift
- 99 4runner highlander - autocheck report
- locker motor killing battery?
- Annoying lights on chime
- Just picked up a 99 with a dead motor!
- Apexi Safc/ Safc ii wiring diagram
- Brake Pad suggestions?
- Has anyone done the O gasket mod?
- Vacuum Tank
- ISR Mod tape
- Tacoma IFS CV-axle Upgrade, Lifts, Suspension Mods... (and the '03 Tacoma Build)
- Need Transmission Shop Reccomendation in Georgia.
- Tundra Limited Wheel fitment?
- Best / Cheapest OBD2 software (Toyota Specific)
- Small Issue....
- My front brake mini saga
- De-arching the leafs on my Tacoma?
- windshield wipers dont park, any ideas?
- 2000 4runner drivers door...
- JY find, auto dim mirror
- Opinion on Eastern Cats
- 2" Front Leveling kit, and add a leaf's...INSTALL PRICE and THOUGHTS??
- 96 4runner -brakes sticking!
- 99 OEM CD Player
- Need good Tech in Fort Worth
- Just purchased 1999 T4R SR5 "highlander" 4WD
- 3rzfe engine rattle?
- FJ80 frontcoils for rear 3rd gen 4 runner
- X01 Gasket Kit for 5VZFE 3.4L V6
- E-Locker Swap - Wiring Question
- LED Tail Lights 99
- Landcruiser part-out
- ARB bumper with 2" body lift???
- Rough idle/random misfires (I am frustrated)
- 99 Black Highlander 5 speed 74,500 Score!
- To all the electricians out there
- 1998 4runner - New/used auto transmission now in and working but no 4wd
- RR Diff Locker on a 99 4runner not engaging
- fuel sender
- Anyone ever buy an engine from these guys?
- 4WD not engaging
- Help with TRD E-locker.
- 99 runner Lower control arm question
- 5VZFE 3.4L V6 Rebuild
- question about brushguard?
- Mysterious antifreeze leak
- >> Will these LUG NUTS work?? (pics)
- wheeler's rear brake line
- 99runner / Question on installing new rear blisteins shocks
- 08 Tundra steelies on my 04 taco?
- 1995 Tacoma Coolant/Head Gasket Issue
- Transfer case blues..
- skid plate bolts stuck
- skid plates
- Transmission Woes
- Gobi Stealth Rack Install - 96-02 4runners
- New Savage Off-road Bumper!
- New Transmission Issue ~ trouble off the line
- Where to buy remote security key?
- Led exterior question
- 97 runner - What lift do I have?
- Sonoran Steel 7.1 lift question?
- Longer front wheel studs!
- 2.7 throttle body coolant bypass???
- Help with problems (97 3rz)
- Pulsating vibration at high speeds.
- Misfire Update
- How much tq will stock hold?
- Need to level out the front end (pics)
- My fuel pressure regulator doesn't work ?????
- 1998 Limited 4runner auto transmission slipping
- 2000 4Runner SR5 Running Boards for Sale
- 2000 4Runner SR5 4x4 Keyless Remotes
- rear diff problem
- 2000 4runner 4x4 SR5 Floor Mats
- 2000 4runner SR5 Running Boards Removed
- Heating - 2001 4Runner
- Blew a spark plug. Need new cylinder head. Wow. Fail.
- Rear hatch rod and cable
- 96 3.4L hard to start Cold and Hot
- Pacer Flexy Flares w/pics
- Trans interchange?
- 5VZ 3.4 V6 Head Gasket Poll
- Refreshing entire front suspension
- Transmission coolers - low temps and bypass thermostats - Tests and results
- Mad Crazy electrical
- pretty sweet 4runner
- 1996 4Runner will not start when cold
- headlight problems
- Popped my towing...well, first time towing experience
- 99 4Runner 3.4l V6 fuel gauge not reading properly
- Horn Airbag Cruise Cntrl Problem!
- 4runner transfercase question
- Routine Maintaince while intake off??
- Need Help with P0136 Code
- Question on replacing PS/AC/ALT belts
- power steering flush
- Taco to 4Runner fit, need verified
- Front studs shorter than back studs on 04 taco
- ABS light and other issues...HELP!
- Rough runnin RUNNER
- 98 Tacoma (2.7L 4x4) What to look for
- Why is 31x10.50x15 so common?Have any of you gone from 31x10.50x15 to a smaller tire?
- Bad U-Joint, Recommendations?
- Projector headlights
- 3RZFE Valve Adjustment - Need advice from Toronto area members
- looking for trans temp gauge recommendations
- skid plate questions
- Need some help mounting this brush guard, please.
- Question about starter issue on 98 Tacoma
- After market LC coils for 98 runner
- Custom front lightbars?
- 4Runner won't move forward in Drive when cold
- An interesting sound while at idle
- 5VZ 3.4L AC idler pulley
- Stock 99 2.7L Xtr Cab Build
- New Treadwright's and Running Boards Removed
- Tundra BIg Brakes on 96 4runner
- Locker Switch Idea
- question about dash 'brake' light
- Looking for a couple engine pics
- Please help me with brush guard?
- Back to Black again
- new yota owner with heat problems
- Engine stall first thing and high speed clunk?
- front dif leak!
- TRD supercharger install help
- Grille Guard installation, missing a set of pieces.
- Changed spark plugs today and cleaned throttle body, just couple questions.
- Fuel In Airfilter
- Auto shifter rattles
- Front Clunking and ABS Kicking In All the Time
- No Start Problem
- My new 4runner off to a rough start... Pics inside
- ect power switch
- Respraying 4Runner. Who's Done It?
- new toytec suspension lift
- Lightforce question, plus some brainstorming.
- 2000 Taco SR5 Speaker Size?
- 3RZ-FE Timing Chain
- Replacing spark plugs, clean throttle body while im at it????
- MC replacement Q's
- body mount bushings AWOL??
- Inner tie rod replacement
- Gauges
- Anyone used these taco 60/40 seat covers?
- Half-Shaft In-Diff Snap Ring Removal and Thoughts.
- URD and Oregon DEQ (P0420)
- 4runner steering wheel pad
- Can't figure out an interior squeek...
- Just another ARB bumper installed
- Interior Lights 3rd Gen. (2001)
- Remote Keyless Relay location
- Speedometer Cable Replacement
- 3.4 experts needed!
- Land Cruiser wheels 1st mod
- ECM Problem; Relates to Transponder Keys
- Spark plug part numbers for Supercharged engines
- 4runner cold start issue
- exhaust
- trany prob.
- Parts interchangeability - 1st gen Taco - 3rd gen Runner
- Brake Vibration issue..Not Rotors!
- Tundra TRD (with no spacer) and 906 combo
- timing belt what to replace ?
- Help replacing front bumber parts!?!
- 96 2.7 4wd timing chain
- 2008 Tacoma Wheels on '99
- Notchy Steering
- Recent article giving props to the 3rd gen Runners
- Own a 99 4 runner now
- Grille guards for lx 450???
- OME 883 vs Eibach coils
- Jungle Fender Flares
- Failure of 4wd in a '97 Limited?
- Engine Exchange? 96 Tacoma, 2RZ
- holiday modding!
- operating temperature?
- Got rear ended and now locker won't engage...insurance issue
- rear diff lock switch by-pass HELP
- 2000 Limited Alarm related questions
- Rear End Noise?
- 3.4 V-6 Engine Removal Install Tips
- Headlights NOT coming on, not relay problem
- New shocks, new springs, new tires, new pics...
- Scangauge II/XGauge question
- 4wd "pulling" when engaged?
- part number needed
- Does anyone have an ARB Bull Bar on a 96-04 series tacoma
- Rubber grommet on starter
- 2001 tacoma
- vvme 6000k hid lights installed
- Has anyone used Car Parts Wholesale for rear bumpers?
- horrible pulley noise
- A NON LIFT question about 315/75/16 MT
- Locks not working........
- OME Lift Installed.. w/ pics
- clutch questions
- Chipped crankshaft pulley
- A/T P light blinking???
- TRD Clutch, is it worth it...
- weird noise on my 2000 Runner
- 96 4runner Hatch Latch
- 4Runner 3.4L leak help
- 3.4 Liter Problems
- 2nd gear has slight grind 96' 4runner. Syncro?
- Crazy issue with right blinker cutting cruise control off
- Recommended source for JDM Engines
- valve cover gasket questions (1999)
- Shaking when applying brakes downhill
- Snow Chain Options
- Wipers will not turn off
- Bad ECM????
- How heavy is the 3.4L V-6 engine and trans?
- Water leak in cab when AC on
- Headers or replacement manifolds?
- 99 Tacoma 2RZFE: magnetic plunger p/n?
- 01 tacoma 350 swap
- Blown Head Gasket and Subsequent Hydro Lock
- can someone identify the bug guard?
- Can the starter contacts be replaced without removing the starter??
- Painting myself and need a little advise. :)
- 1996 4Runner AWD?
- 00 to 01-04 Conversion
- fender trim/flares
- New Shift boot/ Console Leather
- Misfire and Stalls
- Broken upper link. Is it common?
- Pictures of my 4runner on 35" s finally
- remove rear drive shaft
- FIELD MONITOR UNIT - update w/ pics
