2001 tacoma
Old Dec 23, 2009 | 01:27 AM
seth67357's Avatar
2001 tacoma
i have a 2001 tacoma 4x4 2.7 4 banger i want to lift it a bit and put bigger tires on it i was thinking something like a 31 inch tire and 3 inch suspension lift will that work on a 4 cylinder what should i do thanks
Old Dec 23, 2009 | 02:11 AM
space-junk's Avatar
what should you do??? well, i think the first thing that you should do is to check out the built in search function that this forum has...
Old Dec 23, 2009 | 03:25 AM
peapicker's Avatar
x2 on using that search thingy! There are countless threads on this subject. You should be able to find out what you want to know.
Just a side note, if your truck came factory with 265/75/16 tires, you already have 32s on it.
Another note, I think if ya lift a taco more than 2in you have to cut one of the crossmembers out. check me on that cause im not sure if its 3in or the 4in kits that require this.
Old Dec 23, 2009 | 04:24 AM
HazMat's Avatar
Some tacomas came stock with 265/70r16 which is a 31 inch tire. NOT 265/75r16. Therefore you need NO LIFT to run a 31. Never heard of having to cut a crossmember out. I went the cheap route and bought coil spacers for a 2.5" lift in the front and i have no complaints so far.
LCE_Performance
Oct 1, 2015 01:03 PM
bryan34w
12
Sep 30, 2015 02:50 PM
irv
Sep 29, 2015 01:04 PM
charlie_fong
Sep 27, 2015 10:06 PM
Project90
Sep 24, 2015 11:40 PM
