PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 [50] 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. Upgrading to Late 3rd Gen Interior
  2. 99 4runner wiring harness question
  3. gas pedal vibration
  4. Best way to stop early rust now??
  5. OME with tundra coils??
  6. Leaky 3rd gen 5vzfe valve covers dripping oil into my alternator.
  7. DIY: black housed tail lights
  8. Can anyone recommend a good independent Toyota shop in NY?
  9. Transmission Fluid change help
  10. questions about what locker to install on 99 runner
  11. 02 Tacoma will only start after I leave neg. Battery cable off for minute or two
  12. HELP! New plugs, new battery, won't run!
  13. 97 4Runner on 44" tires
  14. Trade 99 4Runner for DoubleCab Taco?
  15. 4Runner lug nut just spins
  16. 5VZ Oil Pressure Switch Size??
  17. Which bumper would you choose??
  18. Need URGENT help with gearing??
  19. Weird A/C Problem
  20. a/c problem??
  21. Having to mount my 285/75/16 to the stocker wheels. What size wheel spacer?
  22. Custom Sliders
  23. need a lil expert advise
  24. Winter Mileage is HERE!!
  25. Just intalled URD 7th injector on my 02 Tacoma and now IT WONT RUN
  26. 235/85/16 BFG KO's installed
  27. can you get rectek lift an keep your spacer lift
  28. PP springs & 1" BL enough for 285s???
  29. Do I need new wheel bearings? weird noise- any ideas? please help.
  30. Clutch makes a whirring noise - Should I be worried?
  31. Guess the lightbulbs (please help)
  32. So now my 4wd won't engage OR disengage, what did i do?
  33. where is the fuel filter 99 4runner
  34. Replace spark plug wires
  35. installing cruise control
  36. Humming noise from vehicle at high speeds
  37. supercharger or ring and pinion?
  38. 4Runner in winter: Only a matter of time before I roll
  39. Alternator w/ Scan gauge 2
  40. Factory E-Locker Upkeep
  41. traction/skid control help
  42. 2001 4runner traction/skid control
  43. Finally - A Proud New Owner!
  44. Day at the dealership
  45. Do all Highlanders have the shadow chrome insignia?
  46. Fuel Filter Nut Rounded Off
  47. Manual Hub Swap
  48. 4Runner Factory E-Locker question??
  49. Clutch slave cyl. hydraulic line question
  50. New Panasonic Head-Unit, Sirius, and Ipod Connector
  51. rear axle bearing question
  52. Pro Comp 8069/1069 wheels group buy!
  53. Check engine light turned off?
  54. how do you line up engine mounts after installing headers?
  55. 2004 Tacoma, replaced radio, now 4WD light doesn't work
  56. Tires: 33/10.50 vs. 32/11.50
  57. New Runner on the Block and Backspace questions
  58. Backlight for my climate control died! How much work am I in for?
  59. ABS Disable Switch
  60. Good Deal
  61. 96 4runner solid front axle
  62. Am I Missing a Hose?
  63. Clutch Adjustment?
  64. Another "3rd Member" question, from my earlier thread
  65. Trannsmission Swap
  66. Bent axle 98 4 Runner LTD
  67. new 4runner looking for some ideas
  68. Black FJ TRD's on 3rd Gen
  69. Ghosts in my 4Runner?
  70. bad coils or what
  71. 07 4runner wheels
  72. help!!! problem on check engine light???
  73. Who owns this black 4runner?
  74. Need help with clutch install in Dallas TX
  75. '01 4Runner Sport - Thrown Rod, need help!
  76. Question on speedo, odo, and bigger tires
  77. Air Lift 1000...off road?
  78. Speedometer/ ABS
  79. 1st gen roll bar
  80. My engine makes a bad sound (video)
  81. Unneccessary amp draw... MPX Multiplex Communication System MPX-B fuse
  82. ARB Compressor mounting spots for 3rd gen 4runner
  83. 97 4Runner project vehicle
  84. Projection Headlamps - Aftermarket 3Rd Gen
  85. electrical issue need help fast
  86. I think I broke my MC bleeding brakes Help!
  87. Starting Rebuilt Motor for 1st Time
  88. 2000 Runner 2.7L 2WD Oxygen Sensor Help!
  89. Lost Only Key for 2000 LTD
  90. extended bumpstops??
  91. lookig for advise on suspension
  92. No swaybars, front, rear both?
  93. Project SportRunner Pics Published in ORA Magazine
  94. 99 prerunner oil pan leak
  95. 01 w/HID's and DRL disable (FYI)
  96. *~-~ Best Bang for YOUR Buck? Rooftop Lighting Reviews Needed! ~-~*
  97. Running like crap..
  98. ECU data-logging & Tuning capability???
  99. Budbuilt skids installation questions?
  100. VSC/TRAC/ABS Disable mod for Tacoma
  101. Check Engine comes on
  102. Show me your Safari Rack on your 3rd gen 4Runner
  103. Drive shaft center bearing play
  104. Lift work in Minneapolis?
  105. How far can you go with coil spacers...
  106. Registering an AZ 4Runner in CA?
  107. 97 4Runner making horrible whining sound from rear diff
  108. 4WD not working
  109. 22re Vs 2.4 4 cylinder tacoma motors
  110. CEL/Emissions Question
  111. Suspension. CHECK! Tires. CHECK! now what?
  112. rear cargo aux power socket not working
  113. Brakes questions.
  114. Small problem with radio, and the solution
  115. My 4Runner has a weird suspension.
  116. Power Antenna blowing fuses
  117. Rear Suspension Q's
  118. '02 4Runner lift question, panhard bar
  119. Replacing Hood Release Cable
  120. Transmission Dictionary
  121. h4 led headlight bulbs
  122. Need help with a tire issue guys
  123. finally went offroading
  124. 3.4 cold start injector?
  125. rear axle seal leaking
  126. 02 4Runner T-case vent or breather
  127. help with screaming banshi
  128. hard start after fueling
  129. 35" tires finally installed.
  130. Sonoran Steel 1.2 Kit Help!!!
  131. Neutral Start switch - how to check?
  132. Northern Tunisia pics
  133. Good Quality iPOD Mount
  134. 99 Limited Push button 4wd issue
  135. OEM mini header install for 2.7L*(Pics)*
  136. Starting issue
  137. 4xinnovations tube bumper
  138. 99 4runner cargo hatch question
  139. OEM Radio Compatibility
  140. Little help on alarm install
  141. I may be missing a line/hose ... need some help
  142. Rear axle seals fail after switching to Synthetic Differential fluid
  143. 2000 4runner - transfer case or transmission problem
  144. 01 Tacoma winch bumper on a 3rd gen 4Runner?? Will it work??
  145. alarm problem
  146. help with stereo install...my new 4runner
  147. weird problems during deck install
  148. Won't start/idle/run after minor accident - help!
  149. Exhaust - muffler suggestions?
  150. Good times in Savannah
  151. Tacoma Bilstein 5100 height-adjustable struts for Tundra TRD/OEM 4Runner lift?
  152. clutch problems
  153. Acetone to increase mileage?
  154. Special Thanks to Steve Schaefer.....Sonoran Steel
  155. Locking rear diff?
  156. How the heck do you get the stock exahust manifolds off to install headers?
  157. Armour / skid plate suggestions for a 02 tacoma
  158. backspacing for stock 97.
  159. Performance Product 1" Lift Springs are Discontinued
  160. Front clip convesion?
  161. Strange noise when I turn.
  162. Gentlemen...I need your wise advice! re: clutch issues
  163. CRACKED my valve cover!! Where can i get another one from??
  164. 96 4runner fender flare fasteners - need
  165. Radio wiring harness.
  166. towing with the 4runner
  167. 10mm....10mm...10mm
  168. Missing gasket/seal on MAF?
  169. Brake Troubles...
  170. Stock Wheels? or Aftermarket?
  171. Coolant & Tranny fluid mixing? overflowing?
  172. 2000 4runner antenna nut
  173. finally did the clutch bushing mod for 3rd gens!
  174. factory hitch issues
  175. shock replacement and jack stand points
  176. fzj-80 springs on 3rd gen 4runner rear axle....
  177. Monroe Ceramic Premium Brakes for 97 4Runner
  178. i need help stripping front diff.
  179. 96 4 runner may need oil pump, will I damage if I drive it?
  180. Engine block coolant drain plug - 2.7L
  181. p/n for tokico tacoma dc shocks??
  182. Water in dash
  183. 3RZ-FE valve troubles
  184. Greasy/fluid leak on right rear wheel
  185. WTT 4 runner
  186. Mounted up a set of Flat Black Grids on my 4runner with 285's and took some quick pix
  187. '97 4Runner lost compression... likely cause?
  188. *** Opinion needed please. Rad Failure ***
  189. Guages only work when truck is warm?
  190. My new 4runner
  191. alternator? battery?
  192. Roof Bins and Spare Tire Carrier
  193. manual to auto locking hubs?
  194. Under Seat Subwoofer
  195. 15" or 16"
  196. Broken Trail Hitch Bolt can I only run 7?
  197. 01 4runner brake leakage
  198. got a problem from the wreck
  199. Seatbelt shreaded
  200. Replacing belts
  201. Part # --- '99+ Overhead Sunglass Holder
  202. 1998 lift kit???
  203. tundra coil spring color combo??
  204. Who can run a VIN for me?
  205. Subaru Gauge Pack (FMU) in 4Runner?
  206. Tundra CV shafts in 4Runner..?
  207. New 4Runner owner here.
  208. Where do I get one of these???
  209. 2000 4Runner Rear washer fluid line BROKEN needs repair
  210. Do NOT Buy Toyota's All Season Rubber Mats
  211. Hella 500's switch stays lit!
  212. Before and After Pics of Minor Suspension Upgrades
  213. Ignition key not fitting smoothly
  214. V160 trans on a 3.4L??
  215. Better Seats?
  216. How long before the factory springs start to sag?
  217. Photoshop help!
  218. Rear Locker for my Surf/ 4runner: Need help
  219. HID Xenon Kits
  220. 3rd Gen Magazine Reviews --- Where to find them?
  221. Am going to get a Class III hitch...
  222. Reading codes
  223. Truck may go up for sale, spread the word please
  224. 99 4wd 3.4 4Runner Air Fuel Sensor ?
  225. couple ?'s
  226. Optima Red Top (group 35) in 2002 4R
  227. bilstein shock/strut package
  228. 95.5 Taco/B4Runner
  229. Looking for a new ride
  230. Replaceing Shift Solenoid SL
  231. 99 cap on a 96
  232. Anyone running 22inch rims on there 4Runner's ?
  233. How to use / What to buy OBD Device
  234. cold weather first gear to second issues
  235. Rear Spacers
  236. AMSOIL cheaper than Mobil 1 EP?
  237. help me remove the rear door panels 96 4runner
  238. Tokico Trek Master R/T Shocks on Tacoma?
  239. OEM Sunroof Deflector
  240. Identify a part pics
  241. HELP**96 4runner won't start after body lift**HELP
  242. fuel filter
  243. Spring/Coil Identification
  244. Experience with Daystar Bump Stops in 3rd Gen 4Runners--Install problem?
  245. Sqeaky Clutch in Tacoma?
  246. Best way to accelerate...
  247. Shocks or Coils
  248. 99 4runner high engine rev while driving
  249. Clutch Shop Remomendation - North Country San Diego, CA
  250. Dead Pedal for 2000 4Runner
