PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 [66] 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. New '00 4Runner...center console getting hot?
  2. e-locker woe's
  3. new member with a bunch of Q's
  4. Hello Everyone Please Provide Expertise
  5. clank! on compression - what is it?
  6. Engine Oil
  7. Pulling
  8. Gas fuel saver
  9. Hatch wiring question and trouble shooting
  10. Painting Grille?
  11. bumper question
  12. Need quick help please!
  13. '00 Rough idling Taco
  14. 285/75 16 BFG A/T KO Size Question
  15. new wheels & tires (will it fit)
  16. Toytec OME3-RUN.
  17. Rear axle shaft seal question
  18. '98 vs. '00
  19. 285s with Running Baords?
  20. New Bumper wanted- ARB VS TJM
  21. Ordered My New Tires Today! - BFG MTs 255/85r16s
  22. Power Tower causing engine to code??
  23. Rear Sway Bar Bushing Popped Out
  24. Safari light bar
  25. FK-35 DC Controls electric fan controller
  26. 2.4 liter stock airbox/intake.. why so frickin' huge?
  27. Tokico Shock ??
  28. Where can i Find a 2.7l maf sensor
  29. Want New Tires
  30. 98 4Rnr ltd V6 timing belt
  31. Spare tire rim..you decide!
  32. Just put on the SS #7.1 on my 2000
  33. 2000 4runner Sport
  34. BFGs new tire
  35. 890 vs 891
  36. Where Factory Oil Cooler Mounts?
  37. Tranny Cooler
  38. locking differentials for a 1996 2WD Toyota 4Runner
  39. Check engine, VSC TRAC, VCS OFF
  40. COLD ENGINES...TRAIN YOUR WIFE (or girlfriend)
  41. 3rd gen V6 auto... intermittent miss at 60 mph
  42. OME N91SC and Tundra Coils
  43. tire rub
  44. Road Less Traveled link? I want to jam bigger tires on
  45. Which Plugs, Which side?
  46. why so stiff?
  47. Anybody have pics of 285's on 3.5" backspaced wheels?
  48. Engine Sludge FYI .....are you a "synner"?
  49. front driveshaft measurements 96-02 man or auto
  50. cig lighter repair 96 4runner?
  51. Need Replacement Rear Springs...
  52. Tundra vs OME 882
  53. toytec 3" lift
  54. Anyone here own this 4runner?
  55. Transmission or engine sound?
  56. dynamic tensioner bolts sheared
  57. brakes help.
  58. coil spacer bolt size
  59. 98 4 runner TPS confusion
  60. Need to get a hitch assy... Best offroad bumper with a hitch reciever?
  61. Help Help! Dent
  62. Suspension/Tire Help NEEDED!!!
  63. '04 Tacoma 4 cyl - plastic material blowing out defrost vent area ?
  64. swaybar endlinks
  65. 2" lift on a 2002 4Runner
  66. Front-end squeek
  67. HELP!! steering problem....
  68. Almost Stalling
  69. need help, please
  70. 1999 4runner
  71. Feelings on the 3.4L (5VZ-FE)
  72. rough engine trouble
  73. Recommendation - O2 Sensor 1999 4-Runner
  74. Auto dimming mirror/compass/temp in Gen 3
  75. 99 4RUNNER tranny/brake issues??
  76. transfer case question
  77. craigslist hood w/ scoop in Phoenix
  78. Traction control cause problems lifting 4Runner?
  79. Need some advice on SC'd 4runner purchase
  80. 2002 4Runner worn rear wheel bearing
  81. Need Diff Help Asap!! *** Searched
  82. LURCH needs a new home
  83. 2002 4Runner worn rear wheel bearing
  84. Which Old Man Emu for 98 4Runner
  85. Could Fuel Injector Cleaning cause a P0171?
  86. AFE Pro Dry S air filter
  87. Anyone Straight Piped?
  88. ARB Prado on my 3rd Gen.
  89. 98 4-Runner LTD rear ABS?
  90. 3.4L mileage poll
  91. Custom Stinger/baja Bumber
  92. Bleeping radio!
  93. Push Button 4wd Question
  94. 4runner = dead?
  95. gearing
  96. 1996 4runner lift
  97. 96 Tacoma 2.5" lift, tire fitment...
  98. Rear window assembly BROKEN!
  99. Wheels wheels wheels!
  100. Will this wheel fit my '97 Ltd?
  101. Limited trim
  102. Help! No 4wd At All!!!
  103. 01 tacoma sas D44 inner axel options
  104. Whose running 2 SS TopOut Spacers?
  105. Engine Trouble
  106. winter tires?
  107. Last beauty shot as she stands
  108. tires to fit my needs...
  109. Sliders and the different prices?
  110. 1998 2.7...4.556......285's 4runner
  111. clutch adjustment
  112. swaping seats
  113. Selling My 4runner for Taco D/C. What year?
  114. 96 4runner with bad gas mileage
  115. 97 runner check light HELP NEEDED
  116. Okay.. thinking of selling now...
  117. Well they fit.. but what about this offset??
  118. Are Optima/Odyssey's worth the money?
  119. P1130 and P1135 CEL codes
  120. I have the Tacoma Shakes!
  121. Iowa Drivers: Advice Please
  122. Tire fitment - One of the lucky ones
  123. 285/75R16 or 255/85R16 BFG Mts for 3rd Gen 4Runner
  124. Missing Tacoma Manual- Fuse Box Question
  125. F/R gear swap on 02 tacoma
  126. Should I??
  127. Interior Lights
  128. Leaking Sunroof?
  129. Where have all the 96/97 Tacomas gone?
  130. Lower links w/ Rubicon Express Super Flex Joint
  131. 881 & 890 install which side? ARB label issue fixed =)
  132. Pictures of 4runners with bolt-on coilovers
  133. Another Slider option for 3rd Gen's
  134. regear with stock factory locker ?
  135. '96 4Runner classic starter issues?....
  136. Exhaust Gasket '00 4Runner
  137. Running Spacers with Tundra Coils.
  138. The "Bamachem" TopOut Spacer.
  139. Diff Drop for a 2WD 1996 4Runner
  140. SS#7 install tips
  141. Neeed Help
  142. How Much Lift???
  143. Best place to find AT Tranny Kit?
  144. how are 4runners with the 2.7 and a 5speed?
  145. Tahoe Trip and 2002 LTD T4R
  146. I have a little wobble Steering dampener?
  147. Defrost
  148. Turning + braking = grinding...
  149. Replacement shocks for stock 1998 TRD Tacoma 4wd
  150. Converting manual tranny to automatic
  151. What am i missing???
  152. homemade rear coil spacers?
  153. 99-00 4runner higher?
  154. Tacoma 4wd drivetrain clunk/flex
  155. timing chain
  156. Addco Rear Sway Bar.
  157. Hood Compatibility
  158. Reliable Phoenix Alignment shop needed
  159. Magnaflow Part Number
  160. Got my rig back from Armorology...Dial-up beware
  161. Front Corner lights: When should they light up?
  162. FJC Swapping
  163. Hella's or factory fog lights
  164. Strange thing happened while driving (4R, 3G, 2002)
  165. Tacoma Superchaerger destroying catalytic converters?
  166. Installed new rear shocks this weekend Oh what a feeling.
  167. Question about mounting racks (Thule or Yakima) on tonneau
  168. First off-roading trip..with the wife!
  169. Tacoma lift Sonora Vs OME Vs?
  170. Semi-New member with pics
  171. Tranny slippin?
  172. Code P0170 gah?
  173. Arb question.
  174. 1998 4Runner 2.7L Code Reading?
  175. I have some questions about the Tundra Brake Upgrade
  176. ifs diff question
  177. Just a quick heads up for those who might be buying springs in the near future.
  178. If you need new wiper blades, they are awesome...
  179. Crazy Stater
  180. '96 4runner, parking lights and horn go on randomly, on solid...
  181. Gas gauge fixed itself???
  182. All day clean job with pics
  183. Limited trim installation
  184. How do you remove the rear cargo door panel?
  185. doors off on a 3rd gen
  186. i hate zerks. help!
  187. nerf bar bent : (
  188. I get a clicking sound when breaking .
  189. fuel line repair kit
  190. Proper Way to Check Transmission Fluid
  191. new member - a few questions i couldn't find in search
  192. What is this part called, part number?
  193. 1997 4Runner 3.4 V6 4wheel drive Fuel lines
  194. 2002 Tacoma P0128 code?
  195. manual vs. automatic
  196. 99 4Runner 4WD Question
  197. Black tail lights??
  198. panoramic retractable sunroof
  199. 2002 to 99 spring install
  200. Clear corners and bumpers
  201. interior/exterior electrical issue
  202. Pwer to manual windows?
  203. New kid on the block with a few questions
  204. Whos Pulled all the carpet in their 4Runner
  205. wheres the performance mods for 2004 prerunners?AHH
  206. Wild Country TXR vs. BF G A/T?
  207. Daughter's 4Runner dead
  208. LED Map & Dome Light Mod!!!
  209. 3rd Gen Front end swap
  210. Rear Left Brake Issue.
  211. 99 4runner overheating while sitting
  212. Might be getting a 96 4runner.....But he broke his ignition??
  213. 1999 daystar 2.5 front and ome 906 rear?
  214. New Guy here. Simple lift question
  215. 120,000 service
  216. What kind of mpg in your 3rd gen?
  217. 2001 4Runner muffler
  218. I bought a 98 4runner.
  219. transfer case leak 98 4Runner
  220. Installed a Marlin Crawler HD shifter seat...wow
  221. Alignment issues .
  222. 99 Runner front wheel alignment question
  223. Cheep 96 4runner w/bad engine
  224. no droop? and q's on a truck box. ^_^
  225. '97 4Runner factory alarm/keyless entry stopped working
  226. '97 Toyota 4Runner factoyr alarm/keyless entry stopped working
  227. Anyone use Pro Comp 2.5" spacers?
  228. Will 285/75R16 tires fit? 3rd gen 4runner stock?
  229. engine losing power and backfiring/knocking at WOT
  230. Coolant question
  231. Steering rack bushings question.
  232. Forgive me dino oil for I have synned!
  233. Optima Battery (Red Top) for my Tacoma
  234. Compartment in the cargo area?
  235. Can't remove key from ignition
  236. 2001 2.4 Tacoma Rear leafs are crap
  237. 3rd gen 1996-early98 rear suspension recall
  238. What should I do about a front bumper?
  239. Power steering
  240. rust and vehicles from the north
  241. Bigger tires on the back, possible problems?
  242. Anyone running 20's with an All Terrain tire & what size?
  243. Torque Specs for 4Runner
  244. Ivan TRD wheels for my 02.....
  245. Low profile roof rack mounts for surco
  246. how do ya post pic's can't copy and paste em here???
  247. Transfer Case Heat
  248. 01 Runner Body Lift Questions
  249. Need help with Hitch
  250. a ? for those who've done their drums...
