Rear Sway Bar Bushing Popped Out
Old Sep 18, 2007 | 02:27 PM
hross14's Avatar
Has anyone ever had their rear sway bar bushing pop out of the bracket? Heard this noise all day and when i looked under the truck (after i was done wheeling) i noticed that the bushing was just sitting to the left of the bracket.
Could this be from too much Flex--am i supposed to have disconnects for the rear sway bar on a 97 4Runner? HMMM
Old Sep 18, 2007 | 02:47 PM
MATT0404's Avatar
Mine used to do it all the time. I just removed the entire rear swaybar assembly. If you don't want to do that, order a set of front endlinks and put them on the rear. The fronts are longer and won't be as prone to snapping.
Old Sep 18, 2007 | 06:44 PM
hross14's Avatar
thought i was smoking crack or something-i am suprised not hear the prob with other wheelers. THanks
Old Sep 18, 2007 | 07:02 PM
mjwalfredo's Avatar
I have had one split apart and fall out once but never had one just pop out. Weird.
Old Sep 19, 2007 | 06:08 AM
Potomacduck's Avatar
I've never seen or heard of this problem.
Anyone have a picture to post?
Old Sep 19, 2007 | 10:58 AM
MATT0404's Avatar
I just re-read the post and realized that I may have been referring to a different problem that I have experienced.
I have actually never heard of or experienced a swaybar bushing falling out of the bracket. I have experienced and heard of others experiencing their rear swaybar endlinks snapping or pulling through the mounting bracket. Sorry if my first post was misleading.
Old Sep 19, 2007 | 11:30 AM
97Limited's Avatar
Put some Polyurethane bushings and brackets, in place of the stock ones and you'll have no problem with them slipping out, and as said above longer end links will help!!
I'm running these on both front and rear sway-bars>
And I've built myself a set of Heavy Duty end links>
Old Sep 19, 2007 | 01:29 PM
hross14's Avatar
So, this is almost like a newbie question--but do ya'll run disconnects on the rear or just longer links. Any benefit from running disconnects in the rear?
Old Sep 19, 2007 | 06:04 PM
MATT0404's Avatar
I don't run a swaybar at all in the back. Longer endlinks will allow the rear swaybar more range of motion as the axle flexes. Discos will allow you to disconnect the swaybar before wheeling preventing snapped endlinks. There's benefits to both I'd just rather not have to worry about it.
Old Sep 19, 2007 | 06:52 PM
ROOFGOOF's Avatar
With my current lift set up, mine are just asking to snap at any momement.
Old Sep 19, 2007 | 07:10 PM
algranger's Avatar
eh, swaybars are over-rated, just take it off
Old Sep 20, 2007 | 08:27 AM
97Limited's Avatar
There is no real benefit to disconnecting the rear sway-bar on a 4Runner!! Its been tested that you will only get about 1" more wheel travel with stock length end-links as to not have'n it connected!! And the same results were seen for the front sway-bar!! If you run your Runner more on-road then off-road, IMO your better off keeping your rear sway-bar!!
Old Sep 20, 2007 | 10:04 AM
nc994run's Avatar
From: raleigh, nc for school chapel hill, nc for home
I've had the bushing pop out as well, I've never heard of using from discos on the rear, but seeing as how i have an extra set (took out front sway bar), I will definitely give this a try
88sasturbotoy
Jan 30, 2026 01:57 PM
glowz825
Jan 25, 2022 09:28 AM
mskalmus
May 28, 2017 07:51 AM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
Vargntucson
Jul 4, 2015 12:15 PM
