- HID lighting... illegal in some states?
- i <3 3rd gens *pics*
- Turning lights like on a Caddy....
- Gauges for Trucks
- How-to: Shave your arse/Remove Decals *pics*
- up and down idle problem and blower motor problem...need help...
- Which seat covers?
- "...slight clicking sound in CV!"
- knocking vs ticking
- How-to: Pinstripe Removal *pics-56k*
- low idle, 3rd generation
- Thinking about 315s
- 1984 Toyota Pickup 4WD
- Molded vinyl padding in cargo area?
- High amp Alternator? For 3rd gen???
- *HELP* 3.0 Throttle Body not fitting
- calling 2nd gen 3.0 auto owners: gas mileage
- Seperating Tires!!!
- T4R Shut Off Sometimes
- 3rd Gen 4R- Rear axle seal dead/dying- Drivable?
- SEMA COVERAGE: Expeditions West
- Where in the U.S. do you guys buy Lightforce Lights?
- Looking for help in PA/MD
- Storing a diesel 4Runner for a year, or more
- TIP: rooftop wires, thule feet, factory rails
- Brake problems after changing tires and wheels
- Upgrading an 03 4Runner Limited brake rotors
- GENERAL AMERITRAC - any good?
- Recommendation for body shop in Denver
- Starter relief- Thx 4Crawler & HaveBlue!
- Locking differential 3rd member
- wiring lighted rocker switch/ fog light relay wiring
- Leak in rear heater line--part #?
- 99 4runner limited aftermarket fender flares?
- wiring harness
- Turbonator?!?
- Rollin' on Nitto's
- 1st gen shocks and leafs - Final words
- oil pan removal
- It Never Ever DFails - replacing O2 sensor
- rollover... no pics yet
- Adjusting valves on their 2.7L??
- Oil pump issues...desperate
- My turn for the #2 idler pulley replacement!
- just completed 120k mile service
- Softest "cheap" shocks
- Bad clutch or did it get hot??
- Diff Breather Extension Mod
- Houston Mechanic
- 85 4runner frame rust
- Hello, no questions just introducing myself.
- What size Rims for 32x11.5 R15
- Rear Heat Update gen.2
- When do warning lights come on for coolant temp / oil psi?
- Simple/cheap HP increase? *(3rd gen 'Runner)
- Changinng Transmission Fluid in V6 3.4L
- Do they all shake?
- test drove a 98 2wd 2.7L today, had a couple questions
- Went mudding and got stuck!
- My new toy's (no pun intended)
- Post a Pic of Your Ride and Mod List V.1
- wiring hella 500 question
- How's This Engine Swap Sound
- Tires Cupping - Uneven Wear
- MAF on 3rd Gen : which direction does it face!?
- Power of a 3rd gen on the freeway???
- MSD or Jacob's ignition suggestions for 22re
- Found hole in bed..rust
- 00-02 4runner heated mirror retrofited to a 01-04 Tacoma?
- Shaking after 75mph
- tipped the truck while wheeling
- tan or brown stone / bug guard for hood?
- Items to survive an east coast winter?
- TPS and timing problems...?
- 4.88 front diff questions
- need good mechanic in Philly
- Illegal taillight covers??
- Gas Mileage Problem
- vibration problem..throttle sensor? TPS
- 1987 4runner back door/needed
- Info on oil filter relocation kits
- Good shop in Plano/Dallas
- ECU Programming Software / hardware ???
- hesitation 22RE
- New Toy!!
- Build pics
- my purchase at Toyota this afternoon
- wiring diagram/1987 4 runner
- vacuum diagram for '87 pickup
- 1st gen windshield washer question
- 3rd Gen grab handle... you have one?
- Good shop in vegas?
- Parking brake relay switch location?
- Rotor Problems
- Guess what i did for $75.00
- Axle code 28, manual transmission?
- We can't get the new head back on the block!
- Parts and trucks in NH
- 3.slow what?
- R Heat Question
- where's that rim?
- Broke an axle yesterday..
- How to avoid tow hitch rust and other NE concerns...
- Floor heater switching and split heat
- Blown head gasket on a 22re
- Ahh! Terrible creaking noise when making right turns...
- Rough idle with URD kit... Anyone?
- what kit is better?
- Could this be a wheel problem?
- Oil drain back hole with pics... Should it be a concern?
- Brake pull fixed!
- True Flow Air Filter
- Leather seats, Lexol or ??
- Replacing window regulator...
- Ticking Noise??
- New Steering Stabilizer
- Is a 7MGTE a good Candidate for swap
- Put new wheels on my wife's 4Runner... what a difference!
- (4) IPF 900 MSR's on eBay for $250 shipped...
- 3.slow no, really...
- Need help with Fuel Tank
- coolant/water temperature gauge help
- ignition problems..79 4x4 truck
- 3rd gen 4Runner rear drive shaft lengths---whats yours?
- 5VZ-FE & 3VZ-FE Distributor compatibility GURU HELP Please
- da grill
- Relocating the ecu question
- I need a picture...
- More and more rust....
- any ideas? custom psp install
- how to take the dash off?
- Squeaky Grill Assembly
- OH OH I Broke it GOOD engine no Workie, Timing Chain ?
- 4 piston calipers for the waggy D44
- 91 runner wont start
- Rear Heater Core 2nd Gen.
- HELP with FTC install in CO
- Quietest aftermarket cat back at cruising speed ?
- New 2nd Gen. 4Runner
- anyone have a roof rack on their tacoma?
- Who else sells these (roof boxes)
- Hard starting when warm?
- Help with adjusting throttle body cables needed
- Pic request (AR Rims)
- 4runner ADD history
- Help- 1988 4Runner Radiator Options
- Weird Thing Happened with battery
- Pic Request. 3rd gens with Snowboard racks.
- transmission slip
- Buying a 3rd gen 4runner, what to look for?
- 89 4 runner/ rough country lift part#???
- Weird shifting when cold
- Weird noise when braking
- 100,000 miles. Finally.
- Knock Sensor 22re
- where to find chrome rocker panels for 00 4runner??
- Question about installing stock rear tire carrier on 2nd. Gen.
- Selling my 1996 4Runner and buying 2000 model LC.
- build-up update
- split cv boots
- Mastercraft Tires?
- Now check out my 83 p/u 4x4....today was a good day
- Anyone's tachometer have ADD?
- Surco Rack Mounting
- Another Rear Window Question (searched)
- 82 22R, thrust bearings destroyed
- Need listing of color codes for 2003+ 4Runner?
- Lighting Upgrade
- 1999 factory fog light wire color question?
- re-threading stripped tow points.
- satoshi mod on 1st gen???
- Rear Heat
- hubs getting hot
- '94 first time towing a pop-up trailer...advise?
- Wah Wah noise
- Spare Tire Protector- Brain Storm Time
- My very first toy!
- Optima battery tray on ebay
- digital thermometer
- idle sucks
- How/where do I find a paint code?
- VIN Request from Sport Models
- lights on stock roof rack
- Reliable online OEM Toy parts suppliers?
- Rear heat in 87 4Runner
- Relays and Fuses
- Will 17" wheels off 05 Tacoma fit a 3rd generation 4Runner?
- 3.0 knock/tap/fluttering noise
- Mucho oil in the intake-o
- stupid water pump
- First Mod: New Grille for 2005 Tacoma
- 3.0 automatic to 5speed conversion? Anyone know of a write up?
- 2nd gen with 3 slow...vacuum switch on PS pump ?
- 99+ LTD Auto CC Light Replacement
- Replacing Climate Control Lights - 99+ Limited Auto
- 81-82 grille on newer truck?
- 2.7 Heavy Flywheel
- Optima 75/25R Red Top
- What do your switches do?
- Denso Platinum Spark Plugs? Anyone got 'em?
- Did I hear that someone could get me an OEM O2 sensor for cheap??
- 1st gen runner center console wiring and topper trim questions
- Tires Questions
- 85 Auto Tranny Help
- 150,000 and counting...
- Code PO420.... Am I missing something here?
- Users of URD 2.2 supercharger pulley
- Ehaust manifold flange nut size.
- What type of transmission fluid is best for 3rd gen?
- Going to get wheel seals done at the dealer...
- roller cams?
- New Amsoil Air Filter
- In need of a P/S Hose
- Got the 85 4runner homw now....
- AT still wont shift in OD after thermostat replacement! HELP!
- Siping Tires in Desert Climates?
- High milage 3rd Gen 4Runner
- High mileage 3rd Gen 4Runner?
- driving without the front differential
- 120 dgree crankshaft?
- 3.0 Engine Help!!!!
- 96 with HG Problems
- Fsm
- ball joint compatibility
- 4WD tire size question
- 22RE idle issue?
- 2nd gen rear shock removal tip...
- 2nd gen OME prob... shock fouls upper bumpstop
- Amsoil Motor Oil
- Installed my supercharger now the engine won't start.
- air intake
- A new axle option...
- Experienced gear/locker shop or member in Denver, CO?
- will 90runner stuff fit my 92 PU?
- Knock Sensor Code 52?????
- Check out my new camper
- 86 4Runner died on highway, Distributor problems?
- newbie needs a part
- Tell me what you think of these new lights..
- 2wd 7.5 vs IFS 7.5 fitment non-Taco
- Detailing with these 5 yr. teflon, polymers
- Throttle Body Spacer? Your thoughts
- Next Investment? Recomendations
- clutch problems
- I need new Tires
- 96-02 t4r roof mounted bike rack
- 97 Tacoma D-Cab???
- Does Yotatech have any interset in a new alternative for trailer light converters?
- bad gas mileage
- 2 bizzare issues (brakes and transmission)
