PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 [100] 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. ugly 3rd gen.
  2. Sticky speedo
  3. OIL uh oh
  4. jet v-force. does it work???
  5. recall - 4runner / Truck / T100
  6. leaking differential ....breather is fine
  7. have a problem burning too much fuel- help?
  8. Winshield Replacement
  9. 4Runner stalled, electrical issues (long post)
  10. hub install
  11. Two Different Plugs In My '97 4Runner
  12. What to look out for in high mileage 3rd gen?
  13. Ticking Noise as RPM's go up
  14. New to forum and have a question???
  15. What Trans Do I Have?
  16. maxed out rear suspension
  17. bumper guard
  18. Clutch squeak squeal
  19. 96 4runner throttle body question
  20. Can you say dual 85's?
  21. anyone try these "condensators " yet ?
  22. Piston FIRING ORDER!!!
  23. How to install Bushwacker Fender Flares??
  24. n00b wiring question
  25. wind deflector on rear question
  26. African Outback or Tuffy Secutrity Products
  27. Header Help
  28. DIN Sized Radio in an 81 Pickup?
  29. RPM's kick up in 4th Gear
  30. Poll: what to buy/mod next?
  31. Exhaust Diameter Question
  32. Ignition Wires
  33. New to 4-Runner not to Toyota
  34. speaker set up is almost done
  35. Will these work?
  36. need shock help
  37. Studs or Bolts - Downey Headers
  38. help emblem removal
  39. real time timing belt replacement question
  40. 22RE Electrical Problems
  41. 2nd Gen brake job
  42. Clear corner bulbs
  43. Starting Help
  44. hubs...
  45. Factory Fog switch? (3rd Gen)
  46. More power for '88 3.0
  47. fan clutch assembly for 3.0?
  48. 01 Tacoma dome light, word of advice!
  49. A Couple of Loud Pings while Warming up
  50. 22R carbon a 20R Motor.. doable?
  51. please help! carb? ignition? Losing my mind
  52. researched and still couldnt find what i wa looking for
  53. 3" TOYTECLIFTS.COM LIFT INSTALLED
  54. Is there a 3vze expert in the house?
  55. Another Spongy Brake Problem Thread
  56. Engine light came on: Manufacture Contrl. Transmition
  57. New to the board, Just bought a
  58. Need Someone (DFW) to go with me to check out 4runner
  59. exhaust question
  60. smog test = easy pass !
  61. start problem... CLICK
  62. Hello all, I am new to the forum..
  63. Need Bilsteins for '02 Tacoma TRD...
  64. Help with Throttle Cable
  65. 4runner w/ Bed Camper
  66. muffler recommendations?
  67. Horrific engine noise on decel
  68. Jet Accu-Speed Recalibrator
  69. Finally installed my winch
  70. starting problems, CEL, etc
  71. High idle rpm after throttle body cleaning!!
  72. timing chain questions (searched)
  73. 3rd Gen. Low erratic Idle?
  74. Leak in rear end seal
  75. Lost a hella...
  76. 3rd Gen Pucker Factor?
  77. RPM's suddenly fine?
  78. Which MAF sensor?
  79. head bolts
  80. NEed help with vaccum lines
  81. Rear Heater Lines Routing
  82. WTF pink/purple fluid leak?
  83. 4Runner meets doomsday machine.
  84. Truck won't start!!
  85. 03 SR5 Fading Cladding
  86. Will 265/75R16 tires fit if I remove my lift?
  87. Slight hesitation at take off ?
  88. engine light on......
  89. 90 4runner not starting
  90. Auto hubs to manual hubs
  91. 98 Tocoma Squealing On Start
  92. 1991 2wd Toyota Mudguards?
  93. Vac-lines needed.
  94. I'm selling my beloved 99...
  95. 2wd engine options
  96. Dually Tacoma?
  97. '05 Tacoma hubs/ADD
  98. 1st Gen over cab roof racks
  99. Going from 3rd gen 3.4 V6 to 1st gen 4 cyl : will I save gas?
  100. 89' Runner rear window not working!
  101. What oil filter relocation kit?
  102. Emergency - replacing hitch on my 2000 4runner
  103. 86 pu suggestions
  104. Steering rack install, 3rd gen 4 Runner
  105. What wheels will woork on the 90 yota 4x4?
  106. 1'st gen with ARB bumper pics anyone?
  107. overheating issues
  108. Rear Diff Lock not Engaging (3rd-Gen 4-Runner)
  109. Paint and grime remover
  110. Sway-a ways in :)
  111. 2nd gen key fob
  112. Century truck caps
  113. Got new Skates for the Yota WOOT!
  114. MPG gurus...
  115. new BJs = need alighnment?
  116. Optima Blue top
  117. 2wd questions
  118. Did I get the correct Amsoil Gear Oil?
  119. If it ain't broke...
  120. Clinometer/ Altimeter my Tacoma on gauges
  121. Selling my supercharged/lifted 96 4Runner
  122. Help...battery problems
  123. Bleeding air from coolant?
  124. Remote entry FOB repair...
  125. Need new tires
  126. HELP my rig is bleeding to death
  127. Tacoma Leaf Spring
  128. Just got the FSM..
  129. Overheating-Need help bad!!!!!
  130. front suspention torque ratings
  131. Upgraded front brakes today, pics posted
  132. 96-98 Bumpers: SR5 vs Limited
  133. Ford Ranger Rims Swap
  134. Fuel Economy, Altitude, and Oxygen Sensors
  135. 87 toyota pick up
  136. BAJA AT OWL - 32x11.5R15 6Ply
  137. Integration Relay - 98 4runner
  138. sr5 rims
  139. Request for 3.4L deck mod/elbow removal info
  140. Last call on 3.4 Engine & 4runner
  141. tire issue
  142. Driving range dispaly gone haywire - help?
  143. Any Idea whats wrong with my transmission?
  144. Leaking Fuel ?!?!
  145. tacoma brake upgrade revisted.
  146. Redline D4 ATF (I searched)
  147. Engine Block
  148. truck tells me rear hatch is open, but its not
  149. Turbo Diesel Swap...Need some opinions!!
  150. Speedo needle is bouncing
  151. 3rd Generation 4 Runner front wheel bearing, bearing assembly? help please!
  152. tail lights help
  153. 2nd Gen 4runners & 3rd Gen P/U front Rotors
  154. Rancho RSX Shocks for 2nd Gen Cruiser Coil Lift
  155. That pesky metallic, noisy sound.
  156. P0171 with s/c, 7th ,and other stuff
  157. Tornado
  158. pic of fuel line into EFI please.
  159. 1998 4Runner slight engine miss
  160. I finally installed the Stubbs SKO sliders. Pics inside.
  161. 89 4Runner Rear Window Help!!!!!!
  162. Do you use wheel locks?
  163. Part it out or Parts?
  164. Anyone got these wheels...
  165. 2nd Gen Head Gasket
  166. New Tacoma Paint CHIPS anyone?
  167. What's the correct was to use your OD?
  168. Timing
  169. Mods/Upgrades for my 00' 4Runner SR5, 5spd
  170. Turn signal modification to corner light?
  171. Replacing rear bumper and hitch & Passenger headlight
  172. Can this be done on a 3.0 ? :think:
  173. Questions on realigning my rear axle and others
  174. Am I Missing Anything?
  175. 3rd gen 4runners rear storage space
  176. seat belt/key minder bell
  177. Tire pressure Sensors (2005 runner)
  178. Offroading sound
  179. front diff
  180. 1992 rear window heartache
  181. 5 speed transmission oil recommendations?
  182. what gear brand
  183. 1800 USD quote for AC repair??????
  184. Determining lift kit brand
  185. 2WD and 15" wheels upgrading brake size
  186. 2001 Tacoma Wheels on 97 4runner?
  187. ups has delivered :)
  188. Should I remove the spring clamps on my chevys?
  189. 92 4R injector leaking. What do I need?
  190. Restored Salvaged 2000 LTD 4Runner - how much?
  191. A good info site
  192. Fuel gauge problem solved(?)
  193. tacoma and 4runner rear shocks
  194. warning light questions
  195. Dealer or parts store
  196. Qs for 1st Gens - truck-bed style
  197. Over Heating 1990 T4R Trasmission
  198. Hannemann Tacoma Conversion
  199. seatbelt warning light
  200. Mobil1 ATF syn
  201. My 4runner dielemma
  202. 3rd Gen Hood Stripe Decals
  203. AC Recharge on a 96
  204. Rubberized undercoating warning
  205. 100k on 3rd gen
  206. Propane aybody?
  207. Amber bulb replacement for '02 4runner rear turn light
  208. Toyota OEM oil filters
  209. trailer hook up? (98 4R)
  210. toy-evy
  211. Which gasket to use with 22re thorley header?
  212. my starter is freakin out
  213. 96 4runner backspacing different than 1st generation?
  214. wobbling gear shifter
  215. Just got some Aisin hubs...
  216. stock hi flow cat?
  217. Super stiff clutch on 96 4runner
  218. Transmission Solenoid
  219. Advice on rust repair needed .
  220. Anyone know how to debead a tire?
  221. Any one installed Headers on their 3.4 ?
  222. 223K and the 3.0 lost #4 :(
  223. Brembo Slotted Disc part #?
  224. Timing Belt/rotor Replacement Experience
  225. hubs engaged/free?
  226. does anyone have.....
  227. EVAP charcoal canister is humming & buzzing a tune???
  228. battery cables
  229. Emissions control-bypass for better gas mileage
  230. ahhhhh now my rear window doesnt work...
  231. When doing the deckplate mod, is it important to take that fuse out?
  232. Is this Runner worth it???
  233. O/d Problem
  234. Hydraulic Brake Assist - newer 3rd gens
  235. gonna look at a rig in the morning
  236. 3rd gen brake pad sugestions
  237. Anyone tried OME springs with Bilstein shocks?
  238. Switching to synthetic oil?
  239. Any issues with larger tires??
  240. My ground lights are up and running!!!
  241. Manual Hub Install: Cone Washers
  242. Favorite shocks?
  243. Toyota Shackels
  244. Timing for bigger cam the same?
  245. backspacing question???
  246. Whats with the one tow hook?
  247. Some ?'s about maintenance.
  248. OMEs & 5100s
  249. help removing shift boot?
  250. Need Advice on '99 Tacoma
