- The Runner is acting funny
- Axle Wrap or Automatic Transmission Problems?
- How tight can exhaust valves be with before they burn.
- slop in drive shaft where it meets axle
- Idle
- Anybody have a picture of the speacial service tool for the 3.0 valve adjustment?
- Neoprene Seat Covers
- road+track on k+n
- Brake Worries
- chip for tacoma
- 2006 HP reduction
- Just advanced my timing....ok?
- Are ADD hubs pretty much just manual hubs that are always locked?
- Do you think is REALLY OEM?
- need some help and tips for the V8/V6 into the pickup
- Will a 285 fit underneath?
- E85
- My check engine light is on (Code DTC PO171)
- 1995 4runner shifting problems
- Changing the color of the dash lights
- Lowering the Center of Gravity
- Heated Side View Mirrors
- replacing dimmer switch
- weird grinding noise from rear end
- The $95 Dynomax 3VZECat back exhaust.....
- Deal on stainless steel cat-back sys...
- Transmission and power steering cooler?
- rememberance day
- New Amsoil Oil Filters
- Smell gas when I'm accelerating
- transmission cooler
- help on how to buy downey coils
- 94 pickup dx reliability questions
- supra runner
- 2002 Sport ed w/ Tow package. What's included?
- Premium Gas or Regular Opinions
- Power Steering problem, some advice or experiance?
- How to remove power mirror and Limited cladding?
- Looking for Air Shocks
- do you know how to respring the acctuator?
- Who/What is to blame?
- stock wheel size?
- Help! my automatic trany jumps outa gear under hard acceleration.
- Code 71 and 41
- '95 T100 axle housing-'90 4Runner gears (4WD)
- Old Video my stock 4runner with new OME suspension
- front end clunk when first stopping after change of direction
- Who here is running a "BAMACHEM LIFT" setup?
- Weekend Maintenance
- My baby is in the shop today
- No start, No spark
- has anybody bought a bumper off of ebay
- Need Toyota part #s
- clutch/flywheel replacement question
- Retarded question on rear tails for 3rd gens
- Q? Does my 93 V6 really have a learning ECU
- Ignition problems
- Uneven rotor wear on one side of rotor...
- PreRunner
- shifting into drive(auto)
- Anybody have Sylvania XtraVisions?
- i got my rear lights tinted
- bent my gate
- 3000 rpm studder....
- Where can I get these freakin tires?
- HI EVERYONE Im new to the forum
- 2nd Gen 4Runner with "big tire kit" Stock Tire?
- First time really wrenching on my 3.0
- Engine Question: 3VZE - 3VZFE
- power inverter
- Ebay find....
- Strange noise ...
- '89 Transmission 22re question
- Satoshi in da house (Pics)
- Custom Aluminum Radiator ($985.00)- Never delivered!!
- "ISR mod" good idea or bad idea
- rear brakes seizing? please help
- Check engine!
- knock sensor?
- Seafoam on a 3.0
- Buying 1st gen (again)...
- Lincoln locker(s)?
- hesitation at startup?
- TJM finally on, fog light/turning light ideas?
- Steering arm swap question....
- 3rd Gen Replacement Leather Steering Wheel Cover (Pic Heavy)
- '97 4runner Sus-Lift
- can't shift to 4h on the fly
- Can too much oil in the engine show a code ?
- Transmission diference?
- Need buckets
- Need advice about " jerking" occuring with Toyota PUP, please.
- JBA EVOL cat back exhaust..
- Power antenna no worky
- Tacoma vs. 4Runner wheels...
- OEM Temperature Gauge - Flat Spot
- Newb question on 3rd member removal
- How do you figure out how much your speedo is off with larger tires.
- '88 p/u shock question
- 1992 Pick Up, now what do I have
- Taurus fan, Hayden 678, front diff fluid in a 3rd gen (pics)
- 1999-2002 4runner Hitches
- HELP! need info on 3.o egine swap
- Need Help With Automatic Hubs!!!!
- Another gas mileage prob.
- photoshop experts needed for taillight coloring
- Brake light demonized
- Using Royco 555 in diffs
- Blackout Headlights for 3rd Gen 4Runner
- Antenna - Where's the Fuse ?
- Did 2nd Gen Runner Ever Have Brown Tints
- I can't believe I'm asking this... where to get 1157 amber LEDs
- What part is this?? Cooling issue.
- 3.0 Radiator swap into 22-RE can it be done?
- Contact with Marlin Crawler
- clutch is out
- 01 Leaning Runner
- WANTED: Someone (someplace) to do a 3.0 to 3.4 engine swap (or 3.0 to new 3.0)
- Power difference between these 2 cams?
- I need a good rebuilt 22re
- Best place to get a water pump? 3.4L V6
- Recalibrate speedometer in our 99 4rnr?
- 93 Cluster to 87???
- about wheels...
- First parts to break in IFS ?
- Burnt ATF Fluid?
- 3rd Gen 4Runners - This could be a fun thread....
- Calender pics...vote for your favorite.
- no spark, need help
- 92 4runner 22re drive belts
- Are the auto rranny's in the 2001 Tacomas reliable?
- rhino lining the roof
- I'm Going To Be Living out of My Tacoma....
- not working - rear window defrost
- Turning off DRL
- Quick How To Remove Oil Pan
- Gonna be rebuilding soon
- pics of 4th gen wheels on a 3rd gen
- I love this picture... it gives me inspiration
- supra tranny in truck?
- JDM 99-02 Black headlights
- 11.2" tire on a 9" wheel
- Passenger side foglight not working, 98 4runner SR5
- High beam headlight doesn't work
- what is a 91 4 banger, 5 speed trany, and t-case worth
- cutting fenders on a 4runner
- What to do about stripped bolts
- Insurance
- Replacing shocks
- Safe w/ out skids?
- Project: Make truck look better
- dust seal...
- The Worst Brakes In the World
- '04 tacoma new owner....happy until today
- Tranny fluid change?
- Icon Fj40
- 16 mpg?? '80 4wd 5 speed...
- Could i use these on my 99 4Runner? (coil overs)
- I got an Oil cooler? now where should I use it?
- Winter Tires vs All-Seasons Siped and Studded.
- Ka-CLONK!
- Very unusual high-revving accelerating
- 22re starting problems help needed ASAP
- Do I take out the rear bumpers?
- Please help me troubleshoot my Check Engine light
- Wheel Spacers?
- 22r-e help needed!
- Could Rhino-Liner or Line X color match my paint?
- speedometer problem
- I think a winch would fit in there?
- Enkei Center Cap
- Identify this intake
- How often do you replace oil pan drain bolt & washer?
- HOw do I start a poll?
- Rear Brakes and Wheeling
- best brand of topper?
- Can't remove rear wheels?
- Where To Get A Good Rebuilt 22re
- True Flow
- Where to buy NEW transmission?
- 3VZ-E Water pump tips?
- Got New Tires Today!
- woohoo! replacing my clutch!
- Diameter of Intake Tube?
- Steering Rack Problem
- Where is my power steering fluid going?
- East Coast 4runners
- pickup rear window latch?
- Strongest, cheapest tires for 88 bone stock
- Pro Comp 8089
- Trueflow air filter...good?
- TPS bad?
- National forests to restrict off-road vehicles
- Donate your old rear shocks to a worthy cause!
- Supercharging the '96 Taco...
- Pitman arm removal
- recall problem with dealership
- aftermarket hoods for gen 2
- Long travel with drop bracket?
- 3rd gen 3.4L crap mpg...
- studded tires
- tire size versus acceleration
- Record breaking mileage on my 3rd gen
- Rear axle making noise
- brakes going out or something help please!!!
- Guess this bolt
- what to do about rear upper control arms hitting gas tank
- Toyota fuel filter
- *PICS Spark Plug Gap
- Planet Kaizen says Diesel pickups may come to the US!!
- What do ya think about these mods?
- Airbox mod..open lid
- Cornfed Lift
- 94 Runner vacuum problem?
- gas mileage
- My door shocks me and my windows have a mind of their own
- Painted Rims, and Bumper Black
- Stalling issue. What/where to get info, please.
- Need a Toyota for a military insurrection???
- Back window opens automatically
- Help with 84 Toyota P/U
- Cheapest shocks similar to OEM?
- 81 Trekker in Aurora CO on ebay
- how much do you pay for veh. registration?
- 3rd Generation rear window/wiper issue
- clutch isn't working
- bleeding the clutch line
- Throwout Bearing Problems
- SC'r & Valve Body Mod Done
- ping and vibration
- 3.4 tranny part number question
- Noisy 3rd gen
- How to get a free allignment after your lift !
- Delivery truck hits your car/ truck...
- 2nd Gen 4runner - High mileage
- Are these idler arm bushing part numbers right?
- MC and SC problems, tried some stuff, need help.
- Gauges?
- Yet Another Camper Build w/pics
- Volkswagens's Turbo- and Supercharged Car
- Any hope for headgasket recall?
- well that is where the oil has been going....
- touch up painting
- Where can I find a fog lamp??
- Bug Guard - Deflector - Shield Removal
- ATF fluid change concerns
- 3.4 ?
- CV joint noise...Help!
- Winter tire for Big Boys
- Painting Bumpers
