PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 [58] 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. 97 limited body cladding
  2. Towing capacity??
  3. good white instrument panel gauges
  4. CB ideas needed
  5. headlight alignment/aiming 2000
  6. Pics of my 2001 Yota Taco!
  7. E-Brake broke; What am I about to spend?
  8. 3" body lift..help!
  9. supercharger oil
  10. Scoop hood finally installed!!!
  11. mudflaps part #'s
  12. Something broken in my front end??
  13. new and i need ideas!!!!
  14. 50 watt HID vs OEM 35 watt HID Installed
  15. Temp Guage not woking
  16. Anyone had to replace there steering rack?
  17. Pics of my Yota!
  18. Calling all 4runner owners who like desert driving
  19. 2000 plain fender flares
  20. tell me what you think
  21. Does this seem right...CV Axles?
  22. 024Runner Rear Suspension
  23. digital clock
  24. wood grain dash
  25. Finally, pics of lift with new meats!
  26. Pulsating Engine at Start-Up 3.4 L ...Please Help
  27. Mechanic Broke My Runner...
  28. 95-00 tacoma rust recall
  29. 4runner Limited Owners: Suspension in Inches
  30. Hella Micro DE's Installed.. OEM Fogs For Sale!
  31. Body Mount Missing Need Help ASAP!!!
  32. Stock 99 coils now, which coils should I upgrade too? Suggestions?
  33. sonoran 1.2 lift, more questions
  34. Discount OEM parts – Southeast?
  35. Theft Detterent HELP!!
  36. plugs & wires
  37. What is this unused plug for?
  38. Sway Bar Link Question
  39. Cold Tranny Issues--99Runner
  40. Need Airbox '99-'02
  41. Wheel bearing grease? Upper ball joint?
  42. smoked headlights where to get them
  43. Tundra/FJ80 lift installed...pics
  44. 2002 tacom recall??????
  45. Brighter Reverse Lights?
  46. 01 4Runner belt question
  47. bumper gap ideas??
  48. High miles on all original runner
  49. Misfire... Tried everything.
  50. Bumper Question
  51. lift question
  52. cv boot replacement
  53. Clutch depressed - 2 secs later tranny engages
  54. 97 tacoma in kentucky
  55. FOUND.Complete rear drum to drum w/e-lockr
  56. 97 T4R rear washer jet Replace?
  57. Hood Deflector Shield Fastener Replacement
  58. tranny cover
  59. It's been fun...
  60. 2000 taco - 1 or 2 cats?
  61. Running Boards Removed (before/afters)
  62. Violent Shaking
  63. Different Body Lift Sizes?
  64. 99 tacoma IFS locking hub conversion
  65. Throttle Sop adjustments
  66. Can somebody list tools needed for timing belt replacement on 3rd. Gen 4Runner?
  67. kmc rockstars pic request
  68. Calling all OME Customers
  69. Lift plans...need suggestions.
  70. Engine Bay Lighting Installation
  71. 4runner rear ends
  72. Extend Both Diff Breathers?
  73. 99 2x4 what to look for when buying
  74. Runs bad, cat cherry red ?
  75. FYI e-locked rear on ebay
  76. throttle body coolant mod?
  77. 881 OME springs on a 4cyl?
  78. 99 tacoma front diff lock
  79. Whats that noise??? Trans.? bearing? HELP!
  80. how much for a e locker
  81. Canadian 4runner Pics
  82. How hard is it to replace the Timing Belt on a 3.4L ?
  83. trying to ID my gear ratio
  84. 01 runner 3.4 swap into 97 taco
  85. 3 spacer lift
  86. 99 4runner Limited, what does this mean
  87. Opinions on my Maintanance Decision?
  88. 1998 3RZFE Burnt Exhaust Valves
  89. Timbren Suspension
  90. Coil spacers Vs Coils
  91. Bad Injector
  92. new taco w/blower need advice
  93. Please help Me ! Headlight Relay on 97 taco
  94. Plugs on Front Differential, Where is Fill?
  95. little help diagnosing starting problem
  96. My list of TB job parts, is it complete?
  97. Does this belong to someone here?
  98. 2nd GEN vs. 3rd GEN 4Runners?
  99. Axle shift post-lift
  100. Differential and Transfer Case Oil??
  101. Check THIS out.
  102. rear end size?
  103. 99 4runner keyless remote program
  104. Bull Bar for 4Runner
  105. Popping sound after hard braking?
  106. Coasting Vibration
  107. Good news for Tacoma owners....
  108. searched only found a couple
  109. 96 tacoma stuck in posi
  110. adding lights on 02 runner
  111. Engine Bay lights Installed
  112. 96 e-locker ?
  113. CA emissions vs. 49 state emissions 01-02 4Runner?
  114. Changing Anti-Freeze
  115. 3rd gen. 3" body lift help??
  116. Three child seats in a 3rd Gen. 4Runner?
  117. Quest for all of you 3rd Gen'ers, what is your prefered year of production? why?
  118. 02 sensor code after sensor was replaced
  119. High Milegage 3rd Gen...Park It or Drive It and Pay for the Gas?
  120. 3rd gen fiberglass fenders
  121. What are These Buttons?
  122. Automatic Transmisison Maintenance?
  123. homemade front bumper question
  124. Black Pearl OEM Emblems & other Treasures
  125. Towing with 285's.
  126. Cat back vs High Flow Muffler and Cat????
  127. Pull wire from plug OK?
  128. P0420 and Voltages at Sensors...Please Explain
  129. Paint code location
  130. totaled 2004 65K miles whats it worth?
  131. 00 2wd 4R - rough suspension, vibration and rear brake questions
  132. bushwacker installed pics
  133. What gears to run....
  134. Got my LED taillights installed!
  135. New photos in gallery of brake and Black headlights UPGRADES!!
  136. addco sway bar end links....please pics.!!!!!
  137. IAC Valve Cleaning
  138. Mounting 285/75 on stock 16x7 wheels
  139. Decorative Skid plate for 2000 4Runner?
  140. Toytat extends warranty for rust damaged Tacomas
  141. Some before and after pics of my 3rd gen
  142. Engine Bay Lighting
  143. Cylinder Misfire?
  144. Multiple CELs today (Engine Related..Sorry for Long Post)...Help me out guys!!!
  145. How many bolts for Differential Drop?
  146. maybe getting 3" toytechlift
  147. pics of our crippling winter (164 inches so far)
  148. What the!?* Wheels not even with eachother. *see thread
  149. Octane rating
  150. which tires would you recommend?
  151. Anyone got a set of super swampers for sale
  152. 2000 taco dash lights
  153. 2003 Xtracab Tacoma V6 fluid capacities
  154. ? for those with 4.30 gears and 33s
  155. E Locker Question
  156. 265/75/16's and a lift/BL
  157. hood scoop insert pricing
  158. 2000 4Runner Vibration/grinding Noise
  159. Shocks and BL for towing?
  160. Painted Rear Bumper, hood scoop grille, & LED Dome light (PICS)
  161. Can't remove CrankShaft Pulley bolt
  162. Painting Grille
  163. All 95-00 Tacoma Drivers Read This!
  164. Overheating 3.4?
  165. Misfire Madness
  166. 1997 SR5 4runner 4wd Pinion Angle issue
  167. Rust on Chrome?
  168. Oil sludge in intake normal?
  169. Price check?
  170. Rebuilt Motor Question - 2 Options
  171. Popping sound around front passenger side wheel
  172. what are the console options for my 95 tacoma?
  173. Toyota Rescues Dodge
  174. My 3rd Gen 4Runner leans towards the side with the fuel tank.
  175. High Idle (3.4L V6)
  176. Hey guys, need a little help on the brakes!
  177. FJ Cruiser Wheels
  178. Speedy's Project SportRunner Dyno
  179. Got my estimate for 4.56's.
  180. I have a CEL or ABS light...wah
  181. Parking brake light when I shift?
  182. is transmission to blame for flashing cel? 2000 limited
  183. Help!! Spark Plug Wire Problem
  184. Is there any way to lower the height of a Surco basket roof rack?
  185. how to clean MAF and TB
  186. trouble getting knob off 5sp shifter
  187. Toyota tacoma TRD diff lock
  188. '98 4Runner purchase advice
  189. Lift Measurements
  190. Brake fluid flush
  191. Cylinder Misfire?
  192. Auto Transmission Problem, Getting Multiple Codes, P0070, P0773, P0753
  193. Dumb Question Probably,
  194. Random cylinder misfire on 1998 Taco
  195. Pics of SS#1 with 265/75 and custom rear bumper?
  196. lift, bumper, hood, and spoiler pics
  197. 2002 4runner sway bar END LINKS..help!!
  198. 7th injector replacement help
  199. 2002 4runner Transfercase HELP
  200. Locker Questions?
  201. 3.4L Header install...installation tips/advice
  202. Engine Swap Complete But W/ Problems
  203. My Runner Is Dead!!!
  204. 2008 toyota off road events....
  205. Found the Wheels Im looking into.
  206. locker questions
  207. Alignment - anything unique ?
  208. My New Toyota 4runner Limited 4x4
  209. 3" suspencion +1" spacer..
  210. Need Opinions...Which do you like better?
  211. What do you recommend for plug wires?
  212. Gas Milage Conundrum
  213. Sport Hood / Lift / Clean pics
  214. 99 4Runner Limited 4X4
  215. ome lift....98 tacoma
  216. crank/cam shaft seal replacement...
  217. Will the limited wheel fit as a spare?
  218. How does the 3.4L respond to performance headers and no cats?
  219. Prepping TRD skidplates for new bumper?
  220. climate control selector swtich
  221. 130K Mile Fluid Changes...a couple of questions
  222. Weekend Lighting-a-thon
  223. Bumperzz Questionzz
  224. Shrockworks Bumper Finally On-How do I??
  225. How to get at top rear shock bolts
  226. help with O2 sensor
  227. auto climate control backlight
  228. Canadian 4Runners !!
  229. Big brake package and abs?
  230. Fake water pump??????
  231. Should i buy this!?!?! and how much to fix a bumper?
  232. backlight for heat/ ac cluster 97 T4R
  233. How much does new clutch cost?
  234. Brake Upgrade
  235. New to the site! Got some questions
  236. SS lift... help me choose
  237. Bud Built belly skid plate & gas tank skid??
  238. P0120 Throttle Position Sensor/Switch A Circuit Malfunction
  239. Installed hood struts on a 97 4runner
  240. '97 auto tranny question
  241. Motor's Gone
  242. headlight harness help
  243. whats it worth?
  244. Bad news
  245. Cat. Converter question...(yea, another cat. thread)
  246. Anyone with Diesel 4Runners or Hilux Surfs?
  247. Pacesetter Exhaust Headers 96 97 98 99 00 Tacoma 4WD
  248. 2.7L Blown Head Gasket and more - need advice
  249. problem with braking
  250. PICS Finally
