How many bolts for Differential Drop?
Old Mar 9, 2008 | 11:30 AM
Mason Dixon's Avatar
I've loosened the 2 big bolts the spacers are supposed to sit on top of. The differential doesn't seem to have dropped, are there any more bolts holding it in place?
Old Mar 9, 2008 | 01:10 PM
Bighead's Avatar
No...just the two for the front diff mounts.
Old Mar 10, 2008 | 07:57 AM
eric-the-red's Avatar
They don't usually drop freely because the rear bolt is tight, I had to pry mine down to fit the spacers.
Old Mar 10, 2008 | 09:06 AM
d0ubledown's Avatar
did you just loosen it? or remove the whole bolt? youre supposed to remove the nut, pull the bolt completely, then it should drop. Ensure youve got a method of support like a floor jack. Slip in the spacers, put in new bolts, and torque er down...
Old Mar 10, 2008 | 10:56 AM
I got the bolts off but you have to really pry the differential down to get the spacers in there and when you do, you are now trying to put a long bolt through somewhat of angle...is this right?
Old Mar 11, 2008 | 06:08 PM
skjos's Avatar
Yup, the bolts go through at an angle, sonoransteel has a tapered spacer, but the bolts are still at an angle.
http://www.sonoransteel.com/store_ta...diff_drop.html
Blamalam
Mar 12, 2022 07:34 AM
Ladythump
22
Nov 9, 2015 08:53 AM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
ripp96
Jul 31, 2015 11:14 AM
