- Lockrite Numbers??
- Noise in front
- Leaf Spring Debacle!
- Wheel bearing gone bad?
- manual hub-rotor question
- Keys and remote stolen, what to do?
- Blinker Issue
- License Plate Frames
- Deck Plate on 2000 2.7 4Runner?
- Deal on stock Hella fogs for 96-98 4Runners
- Different look to 4runner...
- Cruise Control Hangs
- rear 4.88's whining under slight power?
- wierd sounds from the front
- 255/85/16's Help?
- Pan hard bracket or adjustable bar? That is the question.
- What's missing here?
- 158,813 miles between timing belts...
- Painting the Grille?
- plugs,wires,O2,A/F,and fuel filter questions
- Brighter Back up Lights??
- Will this work?
- so my transmission died...
- Tacoma parts work on 4runners?
- Custom paint jobs on 3rd gens
- Need Brake lines for my lift
- swappable 3rds? V6>TRD housing
- Gauge needles question.
- Exhaust (mileage)
- ARP head bolts for '97 4Runner
- Need more hp!!
- Problems starting followed by stalling... sometimes
- Airaid jr intake kit
- Flat bed conversion - did you sell your bed?
- Non-Hazmat Rust Treatment?
- Installed front and rear sway bar bushing.......
- First post
- Where (besides PP) to buy OEM foglights - '01 runner
- what diferential ?
- what oil for my tramsission?? dextron II or III other'?
- 2wd-4wd bumper intechangeable?
- Rim/Tire Size?
- 3rd Gen, 3.4 Auto starter removal write-up (pic heavy)
- 96' 9th/10th body mounts
- PROBLEM: Wire Set Install
- v8 in a Tacoma?
- Pulling a trailer
- 97 hood for a 2000 w/ scoop
- Illuminated Cup Holders
- 4WD not engaging
- What is this part?
- '98 4runner gearbox
- Thing that hangs on the right of transfer case
- Bought a new 4Runner, question about tire size
- P0420 code and header
- Question about vacuum throttle opener to SC
- P0171 Code - More clarification Please
- Who likes pictures of 35's on 3rd gens?
- Lights and light bars choices for 3rd generation 4Runners?
- Engine question?
- What a differnce new Bilsteins make! 99'runner
- Door Panel Question
- Help with 2000 4Runner Tailgate Shocks
- Manual locking hub conversion for 02 tacoma
- Removing rusted/rounder 02 sensor nuts..
- A weekend of modding- Installed my new Gabriel Hi-Jackers, etc
- How many 98 Limited's have immobilizer key...
- For those of you looking to do the Satoshi Grille mod..
- Spring & shock choices, etc. for 3rd gen 4Runner - Help needed!
- what gears do i have in My DIFFS
- Extended Cab Stereo Install
- Quick tire size opinions needed
- Custom Grounding Wire Kit
- Pics of my new bumper
- supercharged 4runner; worth it?
- Introduction & brake/tailight question.
- Supercharger hesitation
- What is "normal" operating temperature?
- Engine fired then died.
- Non-toyota OEM Front Bumper
- Gearing??
- crack in the head
- Will a 4Runner hood fit my Tacoma?
- Rear drum removal ?
- 98 tacoma 3.4 v6 tapping noise
- annoying rattle/squeel only at 2100 and 2800 rpm?
- New Battery ideas
- Front Hitch?
- post install lift questions/problems
- DENSO or NGK O2 sensor???
- Two Noises ( YES I searched)
- 99runner / fuel gauge TSB /Mileage question
- Replacing water pump on 3400
- Which shops in Colorado install SS lift kits?
- Taco tailgate issue
- Power Door Lock Troubleshooting
- Odd noise under electrical load
- yakima oem roof rack mounts
- Still having vibration issues with front diff after 2 fluid change.
- Jardine Catback Arrived!
- (3rd Gen) 4Runner - 4WD all the time or 2WD part of the time?
- 2002 4Runner Questions: Bought used, steering w/brush plates?
- which supercharger?
- 3rd gen Yakima roofrack Install
- OME901 coils on a '98--a potential problem?
- turn signal problem
- Hi Lift Finally On the Surco
- 01-04 Tacoma info
- 3.4 Harmonic Bal Bolt Article - Must read for timing belt replacement!
- 131k miles on original plugs
- Product Endorsement - Sway Bar Links
- Where is my blower motor resistor
- Starting Issue, Any Ideas?
- rim fitment problems
- tacoma double cab stick?
- fuel filter skid plate
- closed deck plate and air box lid= quicker 4Runner?
- 99' limited wheel backspacing?
- 99+ Headlights?
- 29x10.50 super swampers
- Aisin hubs on Tacomas...
- 1997 4runner Exhaust Question
- Poll: Rebuild or Rebuilt?
- Belt Whine Issue
- New sparkplugs/air filter = bad mileage
- Buzzing in my engine...
- RS 3000 Installation instructions
- Will OME 881's and one trim packer help?
- How to replace upper ball joint
- exhaust and cat questions
- 1.5" daystar spacer lift okay?
- Any 5 Speed Stick Shift Sports 4runners Out There?
- X-runner rear diff.
- Exhaust set up
- 99 runner..front shock bushings and spring pads needed
- Disable DRLs...Which wire?
- Lets see your 3rd gen bumpers
- Tacoma freewheel hub...only one side.
- need help deciding what size tires would fit
- Ugly dash.... Got any part #'s?
- Anything I might be forgetting?
- Lighted Door Switches
- 3rd gen Yakima roofrack.
- 2.5 gen.3 4runner lift question?
- Tundra Coil Question
- 3rd Gen: Switching to 4.30's & locker - help me with pre-install issues please!
- 33x9.5s are ON! very impressed (pics)
- Wheel specs to fit 305/70/16
- DRL Fuse... Why?
- upside down shocks!!
- Bulb keeps getting burned-out
- Donahoe's & OME's...anything else?
- OEM lift+CV knuckle= what?
- Overhead console field unit
- Quick help with stalling!
- Drive Shaft and Lube points
- 200 Limited with Sport Hood Scoop...SWEET!!! PIC
- Shaking at high speeds?
- 99Runner, heater problems
- Recommended Headers/Exhaust Setup? ('99 V6 Taco)
- transfer case leak
- Supra MAF questions
- Tacoma woes
- Interior light switch on tailgate?
- What is the Minimum lift needed
- 3rd gen down to 7 lives....
- Air Conditioning Display
- 3rd Gen starter removal
- 1998 V6 Tacoma timing problem
- Time for cat replacement
- Trnasmission mount adjustable?
- Spindle Bushing on 3rd Gen?
- 98 tocoma compression test specs
- 97 tacoma exhaust leak :(
- antenna went kaput!
- Cold weather problems with rear door latches
- *PICS* Engine is in.......simple question, GROUND wires?
- 97 runner braking fiasco.. input needed..
- Removing rear plastic step on rear bumper
- Shocks w/ OME 906?
- Is my NEW clutch bad after the truck sat for a month?
- Dual or single cat?
- My 4Runner starts itself without permission when i'm not around...
- Drawer/sleeping platform Help please!??
- Lightforce 240 Blitz on a stock bumper??
- Noise From Front Diff After Fluid Change?
- is my tranny going?
- 4cyl power handling question
- Front and rear True Trac's. Yeah?
- Rear Axle Q's
- P0465
- new tires and 2" RB body lift (pics)
- Engine shuts off while on Reverse
- My 99 Limited pic.
- Down to 2 lift choices for my 98 runner
- oops... I broke a fan pulley stud
- TrueTrac Model Number
- CEL --> code 420?
- Transmission Fluid Leak
- For those w/ 'Bling" UCA's
- ADDCO Front 1 1/4" Sway Bar CLEARANCED
- Opinions on Lotek A Pillar Pods
- front axel leak!
- What would u do w/ $1000 bucks?
- PC LX450 or LC wheels pics or photoshop
- maf sensor woes
- Feeler: 1999 4x4 4runner front springs
- What lift would be best?
- bought my 1st 3rd gen Saturday
- OEM 5 stars & 285's
- Interesting sounds...
- Awful grinding noise coming from Driver side wheel any suggestions???
- Dash/Taillight lighting problem
- TJM vs ARB
- Side Marker Light Question
- '02 4runner lowrider lift options
- Poor mileage on the 98 3.4 vs my previous ones
- Cost For Fog Relay
- shocks for an '02 2.7L 4WD SR5
- Modifying housing for elocked 3rd....
- seafoam, now CEL, runs fine?
- anyone powdercoated sport edition wheels
- Will these work? 33x12.5x15 Swamper tsl's summit soft 8 15x10 # 3975160 steel wheels
- 1999 SR5 2WD low idle,hard starting,random problem
- Supercharger hood scoop?
- replacing an alternator fuse on a 96 4runner
- 2.1" supercharger pulley installed
- lifting a 3rd gen runner....
- P0420 emission code
- Radiator / after market
- 97 Tacoma MAF cleaning - quick question
- CV Axle install issues
- Tundra coils/OME N91s strut question
- 2003 Tacoma with clicking/ticking noise
- Another Lift Question- 3rd Generation 4Runner
- Question about 2.4 liter
- Trekmasters on their way, springs too?
- my 97 repaired and ready for 07
- Rear tire locking up
- Battery Cable Extension
- lebra fender flares?
- indiglo guages
- Front Brake Pad replacement
- popping noise
- Speedy's Satoshi Grille Solution
- TRD Exhaust owners (and others) ...
- Permacool Fan Install
- E-locker waterproofness?
- What to upgrade broken rear diff with?
