PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. 99 4runner engine lugging + rattle at high RPM?
  2. Oil Pan will not seal on a 3.4L
  3. Unloading 1997 T100
  4. 4Runner runs fine but won't restart when its hot outside
  5. 98 toyota tacoma 2.7 4x4 temp gauge not working
  6. Fuel pressure regulator help
  7. Starting Problem, Battery Good!
  8. FSM P/N for a A340F in a 96runner
  9. never ceases to amaze me...
  10. power sterring fluid
  11. rear axle / inner seal question
  12. A340e vs a340f
  13. Need help from alternator experts
  14. Machine shop in SF bay area to inspect/rebuild head
  15. 97 4runner suspension options
  16. 02 Prerunner Transmission/Vibration Issue
  17. My new 97 4Runner Limited 4x4!
  18. Will valve adjustment correct Cyl. miss?
  19. clutch fork pivot
  20. Rear Dome Light fixed...
  21. Broken spark plug wires - Stranded 4Runner
  22. Afraid of PCV grommet falling in!!
  23. 2001 4runner occasional rumbling
  24. Shimming = quieter engine??
  25. 4runner rear window help
  26. t-100 Trans With Passenger Drop Transfer case?
  27. Power/Volume knob swap on 2002 4Runner
  28. General 3.4L and 3rd gen ?s
  29. sway bars needed with stiffer springs?
  30. cost for someone to replace wheel bearing
  31. 1996 4Runner front end night mare
  32. 99 4runner transfer case selector sloppy
  33. Gen 1 S/C issue
  34. OME lift questions
  35. high idle, until i restart
  36. Transmission conversion
  37. 2000 Stock 4-Runner acceleration hesitation
  38. stock transmission cooler thread size
  39. Remove & Replace Interior Fuse Box?
  40. Ball joint part list
  41. CV axle into Front Differential
  42. Rough Idle, Check Engine Light
  43. oil leak from header bolt?
  44. 99 4runner Limited Aux Fuse Block install
  45. Purcasing a 96 4 runner
  46. 97 2.7 tacoma won't start after long storage period
  47. What is this bolt?
  48. external tranny cooler
  49. Easiest way to gain 2" in height on 2002 4runner
  50. 98 4runner issues. Stumbles badly when cold, mileage off 3-4 mpg
  51. 96 4runner project
  52. 01 4runner electrical failure
  53. Roof Rack or Chop top
  54. PCV Hose 3.4 5vz
  55. Used 2001 4runner question
  56. Starter problem; not the contacts
  57. 3rd gen coils on 2nd gen runner?
  58. 1996 toyota lift identification
  59. Rough Country lift kit review for 96-02 4runner
  60. Dragging runner. Bearings, Tranny, or alignment - oh my?
  61. starting an engine swap. need some help
  62. 1996 tacoma lift
  63. Just got the 3.4 auto dipstick back in - on the 1st try !!
  64. Rear wiper issue
  65. Magnaflow Catalytic Converters (CA vs Non-CA)
  66. how can i disable traction control
  67. Looking for a resonator
  68. 98 limited awd??? Confused
  69. 4wd indicator light is flashing
  70. 4wd ligh
  71. Smitty's Super S brand ATF from Dealer?
  72. 99 3.4L 4runner ticking sound...need help.
  73. Loud Noise in reverse when in 4wd, any ideas?
  74. 3rd Gen 4Runner UCA
  75. Steel compression 10,000psi coupler
  76. Just my thoughts on my new ride
  77. Lights
  78. ECT Mod Observations
  79. ISO: New/like new Toyota AD6803 head unit
  80. Dig locking up on 2000 v6 trd
  81. OME+LC coils. Are extended brake lines necessary?
  82. Replacing the underhood insulation blanket
  83. P100 and P110 codes after Valve Cover Gasket Change
  84. 95.5 3.4L transmission
  85. 03 Tacoma Magnaflow Cat Back Leak
  86. outer tie rod end
  87. What shocks for LC coils.
  88. Tundra strut upgrade ?
  89. 2000 4Runner acts like its not getting gas
  90. intake gasket trouble on new build
  91. front brakes
  92. 1997 4Runner Tranmission Clunk
  93. Aftermarket wheels, balance problems? this will help
  94. Gas Filler Neck ?
  95. 99 auto motor into 98 manual.
  96. fan clutch
  97. ESP System??
  98. Weird problems with my Tacoma!
  99. 1998 Tacoma Prerunner 2.7L leaking crank seal
  100. 5vz-fe Timing Belt Woes...
  101. Where can I get a soft top
  102. Clutch problems
  103. Rear leaf springs sagging 98 Taco
  104. Fuel gauge issue
  105. Stumped... Any advice
  106. Headlights Issue on 4runner
  107. toyota transmissions a340f HELP!
  108. Can't find exhaust manifold leak
  109. pro comp 5001 series rims on 2001 4runner
  110. Fuel Pump Pressure
  111. Please God HELP ME :-) High RPM Miss
  112. Power steering issue
  113. 96 Tacoma Tranny Fluid Help
  114. transfer case questions
  115. rough start idle and engine code
  116. tundra bits up front?
  117. Length of Dipstick on 2000 4runner
  118. 98 Tacoma 4x4 Dash Bulb Compliment
  119. Need help with speedo not working and dash is a christmas tree
  120. Transmission Question
  121. Thub and Vibration on Start-up
  122. Looking for part number for exhaust cross over pipe
  123. Rear Sag ~ 99 4runner Ltd. 4x4 ~ Coil Springs FIX
  124. mysterious whine spreading - help!
  125. NEED quick help (tailgate glass)
  126. 2001 4runner hiccup/hesitation
  127. ome/toytec lift help!!!
  128. Front wheel bearing parts list
  129. 4Runner won't crank or start
  130. SecuriKey system alarm suddenly coming on
  131. Torque specs
  132. Dash Pics
  133. Misfire code for cyl #3 ...............
  134. Highest suspension lift 02 runner
  135. Newb Question - Unhappy sound from 98 4Runner
  136. Exhaust suggestions
  137. 96 T4R maintenance-suspension and oil
  138. Anyone Ever...
  139. Genuine Toyota Brake Pads or something else?
  140. Question about Wabfab clutch
  141. 01' 4Runner - Thumping when cold
  142. 98 toyota 4runner - replace axles
  143. New springs and shocks
  144. Differential info for 1997 tacoma
  145. Expedition Rig Advice, 2.7L or 3.4L Tacoma, or 3.4L 4Runner?
  146. how hard is it to replace the front bumper on 99 4runner
  147. 96 with some oil issues
  148. Opinions for lift? 97 4runner
  149. 3.4L Spark plug/ignition coil problem
  150. Performance
  151. Changed brakes now no brake power
  152. 02 4runner can't bleed brakes
  153. Vibration is making me crazy
  154. going to look at a 95 taco
  155. TPS adjustment for 1995 pickup
  156. JDM motors
  157. Transmission issue
  158. Fuel Gauge
  159. 98 tacoma leaking oil behind crankshaft pulley.
  160. High Idle and chugging at 2000-3000 rpms...help!
  161. Timing belt kit question
  162. Which Bilsteins and from where?
  163. 97 T4R still a little shaky.
  164. Break Light Problem
  165. Whats up with my 5VZ-FE??
  166. Rough idle, cel at 60+km/h
  167. Will denso O2 sensor for manual fit an automatic?
  168. 95 LE 4Runner-replacemnent indash 4" speakers wont fit
  169. Ran over something and now no reverse or overdrive
  170. Finally got one kinda ha ha ha
  171. Where to buy new O.E.M. style rear bumper for 02 Tacoma ?
  172. 2000 Tacoma 4x4Super springs
  173. 4Runner cranks but won't start
  174. 1995 tacoma 4x4 2.7 cel on not communicating w/scanner
  175. 98 4Runner will not start - have confirmed all parts are good
  176. Good deal on timing belt kit
  177. 3rd gen. 4Runner, rear axle swap and 1 diff question
  178. 4 runner lift install
  179. Tacoma SAS, axle questions.
  180. 2jz gte
  181. engine knock
  182. 96' 2.7L Hard Start Hot...
  183. 1998 4runner ignition key problem
  184. 03 Tacoma V6 misfires only when warm
  185. wierd squeal/squak coming from engine
  186. I think AutoZone fried something in my wiring
  187. Chasing my tail here. Misfire on 2/4/6 after t-belt replacement.
  188. Best, Cheapest place to get gear install kits for front and rear
  189. springs with bilstein
  190. 01 4Runner from New England!
  191. Q's about 'hi-mile '95 Tacoma 4x4 v6 XCab
  192. engine will not pass 4000 rpm's
  193. engine advice and help needed!
  194. ALT light takes 10 minutes to go out
  195. Transmission cable replacement
  196. P0171 Code Not the MAF
  197. tire pressure
  198. Cat back 2004 2.7 Tacoma
  199. Off Road Bumper for Tacoma 3 inch body lift
  200. brake pedel vibration
  201. lights out center dash 2000 4runner
  202. Climate controls not working
  203. Energy Suspension Poly LCA bushing problem
  204. clutch help needed
  205. Procomp 7069 rims....Should I??
  206. Will 32in tires fit a stock tacoma?
  207. 1997 misfiring and running rough
  208. Re and Re Rear Coils
  209. P0172........
  210. clutch swap help
  211. How difficult is it to fix an oil leak by replacing the oil filter housing & oil pan?
  212. 5vz timing advance at idle
  213. What should I Pay For A 2000 4Runner
  214. chopped top 4Runner
  215. Looking for 1996-1998 SR5 Black Fender Flares OEM
  216. 3RZ will NOT run at all after headgasket
  217. quick front diff breather question
  218. 97 Taco empty clutch master cylinder
  219. Seat repair
  220. Wheel spacer
  221. CV rebuild
  222. Bilstein HD - correct product number - '99 Limited?
  223. looking to buy 4Runner....Need help!!
  224. Rim Score
  225. In dash clock
  226. Who's running Camry cams in their 3.4?
  227. 99 tall coils or not ?
  228. 4runner tank strap discontinued
  229. Driver Side Door lock acting up
  230. add-a-leaf vs. all new leaf springs
  231. 96 Dune Runner
  232. which CV axles fit the '96 4Runner?
  233. Its been a long time.. Got a question
  234. In-Line Fuel Pump for 5VZ-FE
  235. Front Suspension Rebuild on 3rd Gen
  236. putting in clean injectors, but noticed a possible problem.
  237. valet remote starter , questions.
  238. Rim question
  239. Proud New 4Runner Owner
  240. Tacoma and 4Runner Third Member Questions
  241. Cold start engine stalling
  242. Aftermarket Headlights and HID
  243. 1999 Toyota Tacoma ISR & Rear wheel studs
  244. Tacoma clutch options
  245. A muffler question. Could someone please help?
  246. 4Runner (or possibly Tacoma) Auto transmission interchangeability
  247. Rebuilding LCA's - Lubrication
  248. 99' T4R Ltd (switch the climate control and radio postions)
  249. Leaky rear main 5VZ
  250. 4runner fix up cbus ohio
