PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 [48] 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. 01 4Runner Fuse Problem, need help!!!!!
  2. Is there ONE central thread \ page with info regarding lifts?
  3. Where is the radio fuse?
  4. 3RZ Oil light coming on...why?
  5. Snow lastnight...15cm -35
  6. Brake life - am I missing something?
  7. what size tires??
  8. Front Diff Plug Part #'s
  9. Lift Help
  10. E-Brake issues
  11. Why is the 4runner quality so hard to match?
  12. Is there a 3.90 e-locker?
  13. Engine Temp - Is this too HOT?
  14. Tacoma Seats?
  15. 3.4 hg
  16. Rear Axle Seals & Bearings Help
  17. an I tow 94 pickup w/ 02 4runner
  18. Drive Belt Writeup
  19. 99 4Runner SR5 minor accident frame question
  20. turning off check engine light
  21. 4wd won't engage
  22. ebay hood any good?
  23. Best prices on Tire/ Wheel combo shipped
  24. Truck wont start but turns over
  25. Backlighting on stock radio
  26. Broken FOB, need a new one
  27. Needing help
  28. Need help steering rack
  29. speed sensor wiring
  30. Sparks are due
  31. 75000 miles on 1 set of spark plugs
  32. foggy windows
  33. 5ft Grandma getting into my Runner *pics*
  34. Breaking in your new front brakes......fact or fiction
  35. curious if anyone knows
  36. seafoam
  37. Fuel Gauge Issue?
  38. Strange electrical problem!
  39. Water pump weep or vent hole location?
  40. 01 taco strut tower bar
  41. 1200 miles, 85 MPH and 16 MPG-but hey! gas is only $1.35!
  42. 96 4Runner Temperamental Starting
  43. Mismatched tire sizes
  44. 2004 5VZ-FE Hesitation Problem Solved
  45. 3.4L Top End Rebuild? -- Anyone done it?
  46. 265/75 speedometer and odometer
  47. sluggish tacoma
  48. Taco 4x4 clunking
  49. Rock's Used Oil Analysis Thread
  50. sonoran steel tacoma lift
  51. DECKPLATE mod. ????????????
  52. what tire size can I get away with?
  53. 3.4L Toyota Part Numbers
  54. Some regearing questions..
  55. 2002 Runner Anti-slide action
  56. Thinkin about man. hub swap
  57. 2000 Tacoma Lift?
  58. GPS Mounting in a 3rd Gen?
  59. dead battery question
  60. 16"brakes to 15"
  61. TRD and SR5 Packages?
  62. General Questions
  63. 99 runner.... Time to upgrade the front brakes
  64. Windshield Wiper Reservoir Replacement
  65. Anyone using the Husky All-Weather mats?
  66. After Market alarm is not allowing 4Runner to start
  67. Retractable running boards / side steps
  68. 3rd gen 4Runner advice
  69. aftermarket steering wheel
  70. 3.4L Supercharged 4Runner lean/ping fueling options
  71. 98 Tacoma lift problem
  72. Coolant leak
  73. Possibly the water pump?
  74. unstable at highway speeds. i think i know y
  75. how to spend 500 bucks
  76. Driveline play
  77. 1999 4runner Limited factory CD/tape deck, aux out?
  78. Best place to order OME suspension
  79. I need some seatbelt part# help
  80. I hit a guardrail..Does this look fixable myself?
  81. Towing 4runner cross country
  82. sumbich, I'm an idiot, real time help, crankshaft pulley
  83. Cup Holder improvement idea...
  84. Tune up Questions
  85. 15w-40 in a 3.4
  86. P1300
  87. How many u-joints on 1998 4Runner?
  88. 4wd indicator flashed while driving on interstate
  89. Rear spring suggestions for sag fix....
  90. New 2 Tone and 02 Headlights
  91. Hand brake light problem
  92. crappy phone pics of my 3rd gen
  93. Silver Gauge Bezel
  94. Wreck on Christmas
  95. 4500k or 5000k HID's?
  96. Merry Christmas
  97. What is the best way to lift a 96 Taco?
  98. 02 taillight swap-wiring harness upgrade?
  99. High Pitch Squeele
  100. 99 4runner hesitates on WOT sometimes
  101. Any good mechs in the Salt Lake City, Utah Area
  102. Belt Adjustment
  103. muffler choice
  104. Clean engine
  105. *All 01-04 taco owners, READ THIS *
  106. New Rear Bumper Guard for 3rd gens, pic
  107. HELP! Dealership says my rear diff might be shot.
  108. Maintaince and storage
  109. Who has installed a TRD decal on their 4Runner?
  110. 98 Tacoma vibration
  111. Boost Gauge install?
  112. Little Advice?
  113. Electric fan conversion
  114. HELP - Lights and HVAC won't turn off
  115. Fuel Gauge goes to E when I stop
  116. will a 95 tacoma bumber fit an '01 4runner?
  117. Rear left brake locked up again.....
  118. Got my Blackstone Lab results back (UOA)
  119. 4-Wheel Dive Question
  120. The Punishers New Meats
  121. Update on a throttle problem
  122. To those w/tranny coolers and in-line senders...
  123. Online manuals for download. Check it out
  124. steering problem
  125. Dfferences in stock height between 95-99 Taco and 99.5 and newer?
  126. all-pro hid kit?
  127. Shrockworks Bumper Installed
  128. Test Drove 97 5-Speed
  129. getting a paint job - quote?
  130. 99 2" Suspention Lift Springs: Need Help Please
  131. Trouble removing MAF to clean it
  132. ISR Mod problem
  133. loud fan
  134. Help! Bad fuel mileage from a 4runner converted to a 1kz-te
  135. Help! Bad fuel mileage from a 4runner converted to a 1kz-te
  136. 3rd Brake Light - No Worky...
  137. Need Help with this one!
  138. 85-89 vs. 95-98 4runner
  139. 6" lift for 3rd gen 4runner?
  140. lower output lighting for ipf's
  141. No IDL on my TPS? How do I test it?
  142. Snoooooooow
  143. inner tie rod ends
  144. Pro Comp Xtreme Alloy Series 8179
  145. Multi-Component Swap 1997-1998
  146. The Rattle is Back!!!
  147. OEM Brake Pads for 16" Verification
  148. 98 4Runner Problems.
  149. Manual Hub parts for conversion
  150. tacoma wheels- 16 x ?"
  151. driver side lean
  152. Lift Options for a 96 4x4 Taco.
  153. Greasing Ball Joints??
  154. New crankshaft bolt and timing belt
  155. Is this a good price for a timing belt change?
  156. Lifted Pictures please
  157. PO750 shift solenoid valve A1
  158. Urgent, please help with stereo harness
  159. Twansmission Kwestions
  160. Replacing Accelerator Cable??
  161. FJ springs shocks on 3rd gen?
  162. Tacoma MPG?
  163. replacing master cyl & ABS pump?
  164. New to site and Toyotas
  165. Tacoma vibration at idle
  166. coil/shock cobo. will it work?
  167. 90-95 vs 96+ 4Runner
  168. 4Runner is Gone :( Hello Tundra!!!
  169. Question About Gt Seat Covers For 4runner.........
  170. Why does my manual shift easier in rain
  171. Sloppy automatic shifter
  172. Cheap iPod mod
  173. 96 4Runner hesitation @ 2k RPM on highway
  174. 15" in sport edition/axle question
  175. O2 sensors... $130 vs. $35???
  176. Swap 2000 4runner Seats For 1996 4runner Seats????????
  177. 4WD relay location
  178. looking for slider opinions
  179. Really need some input re Heater Core
  180. What's that thump?
  181. climate control problem
  182. '99 4-Runner brakes freeze when below 10
  183. Engine knock
  184. 01-04 Tacome vs 97 4runner & 02 Tundra
  185. Vibration at highway speeds after lift.
  186. best seat covers for 4runner?????????
  187. Real vibration problems!!!!!
  188. Automatic Trans SWAP Question a 99' 4 runner 4x4
  189. clutch pedal problem
  190. Wheel Spacers
  191. Walker Vs. Bosal
  192. backspacin for my 99 4runner
  193. Schaeffer's 267 80w90 and Schaeffer oil in General
  194. Need 4runner seats ASAP!!! Will buy, any ideas???
  195. HID conversion>>>Retrofit
  196. Axle moves, just a tad
  197. My 1998 4Runner has started to vibrate & growl
  198. Fixing rust on rear hatch?
  199. How much body lift for Hitch flip?
  200. Trying to fix poor idle
  201. New Yokohama Geolander MTs
  202. Tires rubbing
  203. Using 4 Wheel on the streets
  204. 4Runner roof chop idea
  205. '98 4Runner SR-5 Fan clutch torque specs & HD water pump?
  206. 3.4L Oil Leak
  207. 1998 4Runner 4WD Doesn't Work in the Snow
  208. Suspension Suggestions
  209. 2000 4runner mudflap questions...
  210. Replacing Fuel Injector for 99 4Runner 3.4L
  211. New Member!
  212. Lots of poser pics (new camera) dial up be warned
  213. power steering belt tensioner
  214. Trying to clean the MAF and having a little trouble
  215. Install tips needed: Walbro 255L in 1998 4Runner
  216. towing a toyota pickup with a 4runner.
  217. 3rd gen 4Runner and rear mounted power inverter.
  218. re gear question?
  219. Denso Oxygen sensor Part # ??
  220. Getting Timing Belt ON...
  221. Need a part number
  222. I busted this boot... how long can I go??
  223. Elocker Troubleshooting
  224. Lift options.
  225. king adjustable coilover ride quality
  226. Tilt steering 2002 4runner...
  227. Driver side window very loud going down
  228. Electrical Prob no one can figure out
  229. seat question for 1996 4runner please help!
  230. ome run3 installed=creaking noise from rear?
  231. wierd buzzing noise...
  232. Just got my tokicos frm toytec questions??
  233. 2001 Taco TRD V6 Won't Shift into Drive when cold
  234. Help...where to connect OBD-II code reader
  235. List of Dismantlers
  236. 35MPG in a 04 prerunner: Come on- Water Cell?
  237. How Long Do Rear (Drum) Brakes Last?
  238. What gears do I have??
  239. How much will OME 890's settle??
  240. Light Bulbs - Corners / Tails / 3rd Brake Light
  241. Yukon Gear 5.29's Value Gear?
  242. Body Lift 1" or 2" Pros & Cons
  243. Koyo model A1998 aftermarket Radiator...???
  244. Finally posting what ive done! PICS!!
  245. Very soft brake pedal...
  246. Rattling/creaking noise on front-right when going faster than 50mph
  247. Timing belt and waterpump in Delaware
  248. bad gas mileage Q...
  249. remote keyless entry not working
  250. cost for plug replacement and repair cross-thread, too high?
