Help...where to connect OBD-II code reader
Old Dec 12, 2008 | 11:40 AM
mtnmuse's Avatar
The check engine light glowing bright on my 2000 4Runner. Of course the dealer wants $125 to read the code, so I'd like to trouble shoot the issue at home.
Bought a "Creader", which was recommend on Yotatech, for generic OBD-II vehilcles to read the error code(s). Packaging states for "use on all models since 1996 with a 16-pin diagnostic socket". Tryed to plug it into the Toyota "Diagnosis" plug in the engine compartment, located above the drivers side spark plugs, but the plug types are different and will not connect.
Is there a different place to attach the code reader?
Did I just buy the wrong code reader?
Do you have a recommendation for a replacement code reader?
Thank you for any insight and input offered.
Old Dec 12, 2008 | 11:45 AM
eatmorechicken's Avatar
The spot that you plug it into should be under the dash. All obd 2 plugs are the same so yes you did get the right one.
Old Dec 12, 2008 | 11:57 AM
TRT4Runner's Avatar
Under the dash directly above the gas pedal....
Old Dec 12, 2008 | 12:09 PM
mtnmuse's Avatar
found it thanks.....code 0171...."system to lean"
now how to fix that???
Thank you for your help
Old Dec 12, 2008 | 12:37 PM
97ltd4x4's Avatar
Time to clean your MAF..... might as well,clean your throttle body and IAC valve(short cut way)...If you take the intake boot off anyway..
Lots of info about both...do a search
Old Dec 13, 2008 | 12:04 PM
florider's Avatar
look at the 1999 4runner thread. 97ltd does a real nice write up there on the iac valve
mussy01
Dec 13, 2016 08:20 PM
raptor510
Aug 19, 2015 02:15 PM
cr@ves4wheelin
3.4 Swaps
Aug 17, 2015 07:47 AM
Up&Down
Aug 5, 2015 06:20 AM
nonstop
Jul 24, 2015 06:29 PM
