PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. Tailgate Handle Ineffective - 98 4Runner
  2. 97 4runner won't go past 4,000 rpm?
  3. Pre-empting the Strawberry milkshake
  4. 99 4runner front wheel bearing help asap
  5. 98 4Runner 3.4 engine noise
  6. 2002 4runner chrome package info
  7. 1996 Tacoma Dies When Cold
  8. master control unit?
  9. Huge Mileage Drop
  10. Help... Losing Coolant from under truck
  11. Stuck in park
  12. Turn signal switch ...
  13. Warm starting trouble...
  14. Need Line Identifying Help on 99
  15. Stock amp?
  16. Winch Ready Front Bumper
  17. oxygen sensor question before I buy
  18. Assistance needed to identify existing lift for best replacement
  19. California emissions?
  20. Highway Swaying
  21. Resistors for manual swap
  22. vehicle speed sensor
  23. Transfer Case Going?
  24. Harmonic Balancer Shot?
  25. 3.4 Valve Shims..Anyone Know Size Differences between Intake & Exhaust
  26. Upgrade from TruCool 4454 - Need advice
  27. urd 7th injector fuel pump
  28. Is my external tranny cooler too small?
  29. How to separate transfer case from transmission?
  30. Removing Drive Shaft
  31. replacing power antenna with regular antenna
  32. Vibrations
  33. 5VZE High Idle issues...
  34. Finally Removed The Running Boards.
  35. New to the forums...Having a missfire problem i cant finger out
  36. Leaky Valve Cover Seals
  37. Time for a raise
  38. Steering rack, and inner tie rod end questins
  39. 2002 4runner master cylinder problemhi everyone, i have an 02 4runner and need a new
  40. Wiring problem
  41. Rear passenger side pics
  42. Holes too close together in frame?
  43. Made it 10K after the "strawberry mikshake"..now the tranny is done!
  44. Having problems replacing the steering rack bushings
  45. Finally Lifted 2001 4 Runner Limited 4 X 4
  46. 97 4Runner Intermittent Speedo Issue, Recent ABS Delete
  47. Pioneer AVH-P3200DVD Installed
  48. Front Brake line bracket question
  49. Rocker Panels and Dog Legs! Will they fit
  50. Braking and ABS sensor
  51. Scion T1806 in 00' Limited
  52. Manual Trans Fluid, Redline's MT-90
  53. Long road trip prep - 2000 Tacoma 4x4...questions
  54. ARB and Gears
  55. half shaft / cv boot- sort of leaking?
  56. Spark plug change...hesitation
  57. S/C dynamic tensioner Issues
  58. Tacoma PreRunner driveline questions
  59. fix the oldie, buy the newbie??
  60. ebay timing kit has arrived
  61. Best Choice for a Rear Locker on a '95 Taco
  62. want to go from Cali emmisions to federal
  63. Grinding noise in the front end
  64. Defiant Light Bar
  65. 4wd problem after new CV installed
  66. Plastic bits in oil pan on a 3.4
  67. Open Center Console 97 4runner
  68. Two big new Tacoma products from 4x Innovations!
  69. chirping/squealing from underside of truck
  70. New 4runner
  71. Quick question on the alternator and charging system. I think.
  72. Changed spark plugs, now i have a high idle
  73. Dash Kits- Sherwood or Benevento
  74. Blown rad hose - only
  75. Truck won't start after jump
  76. Cruise Control Does Not Work 97 4runner
  77. Squeaky belt
  78. My Tranny Cooler Install (With Pics!)
  79. Clear Turn Signals for 3rd Gen 4Runner and 1st Gen Tacoma ARB Bumpers
  80. Taco Maintenance Questions
  81. Help! Bilstein HD rear shock bushing/collar question
  82. Fitting Magnaflow Muffler with 2.5" I/O to OEM Pipe Question
  83. Any harm to the drivetrain by going with bigger tires?
  84. Rear-end noise on 4Runner was suggested to replace Axle?
  85. can't remove front o2 sensor
  86. 98 Tacoma Oil Leak at Transfer Case/Engine
  87. Yikes! VSC Off light, VSC Trac light and Check Engine light all at once.
  88. Sequoia VSC Recall - could it include 4 Runners?
  89. 2000 4Runner Tundra wheel and spacer question
  90. 2.7 Coil Order
  91. Front Recovery Points on 2002 Taco
  92. HELP! frame rust issues on 98 4runner.
  93. Replacing 4Runner horns with American Car Horns
  94. NwRunners Taco Teardown (3RZ)
  95. Drive Belts replacement questions (pics)
  96. Starter Grind and no start after Sub/Amp theft
  97. Help deciding what mobs to get for moab, 1990 4runner
  98. ez locker n 98 runner
  99. MAJOR problem with the TPS!
  100. HydroLocked
  101. 1.5- 2 mpg increase
  102. Transmission Questions......
  103. I really got stuck in the mud!!!
  104. fog lights arent working??
  105. Alternator removal issue
  106. Cylinder Misfire Logistics...please help?!
  107. Wont turn over
  108. Need Parts List/Prices
  109. Help!! 02 4Runner transmission Woes after drain/refill
  110. Transmission Woes... Replacement?
  111. 1st gen supercharger decal
  112. oil in the intake plenum
  113. Oil Filter Relocation w/Oil Cooler?
  114. Aftermarket 3.4 throttle body?
  115. 99 toyota 4runner runs rich
  116. EFI Relearn?
  117. driveline noise
  118. Shock problem, need help ...
  119. Phantom Miss
  120. "heavy" steering
  121. Coil Problems
  122. where are the power window relays located?
  123. Need tranny advice
  124. 2001 Tacoma shift lever bushing
  125. New plugs and now sluggish
  126. 3" Lifted 97 4R - 1.1* Positive Camber on Pass Side
  127. Bulbs Burning Out
  128. Strange shifting by Auto in Texas Hill Country
  129. What is the best headlight in your opinion...?
  130. No spark taco...
  131. Length of oil dipstick?
  132. 2001-2004 4 runner.. Good for towing?
  133. 95 Tacoma Bed Drain Holes/Plugs
  134. Which Transmission Fluid
  135. Driver's side damp carpet (water leak)
  136. Daystar spacer question
  137. Started my Tundra brake swap today
  138. Fixed antenna for 4R - searched and now confused?
  139. black out third brake light
  140. How's my Cat look to you???
  141. mystery P0770 code being thrown along with P0136
  142. Mud Tire on pavement type sound?? Tried but can't stop it!?
  143. NO CLEARANCE after Valve Job 2.7 Help
  144. hard time starting
  145. 2000 abs?
  146. Project Big Bad Horns - 305/70-17's on 3rd Gen
  147. Hesitation/lurching at constant speed but NOT under acceleration
  148. ANYBODY'S COMMENTS ON Federal Couragia M/T TIRES
  149. Gremlins? or Did I really just kill my truck??
  150. 984runner which trutrac front
  151. NEED 97 4runner Transfer Case and or Transmission Diagrams
  152. 97 4Runner Light next to gear shifter broken
  153. Who's bushing kit is best?
  154. Corner Blinker Mod
  155. 97 4Runner Back Window Problem
  156. grrrr: 5vzfe timing issues
  157. Rear brake drums
  158. 15 inch wheel???
  159. Looking to get new wheels and tires for Tacoma, got a few questions
  160. Modifying steering lines for 6" DB Lift "HELP!!!"
  161. CV Axles: the good, the bad and the ugly
  162. IAC gaskets
  163. So I relocated my XRC 10 winch solenoid... (pics)
  164. throttle body issues!!!
  165. Step Bars on 02 4runner
  166. Broken Axle Bracket - Need some answers
  167. AC/Heater Climate Selector Stuck at half way
  168. timing belt and waterpump
  169. 02 Tacoma Pre RUNNER ISSUE
  170. '04 Tacoma bed versus '94 Hilux bed
  171. Power Steering Hard Line/s
  172. Installing stock roof rails on bare roof
  173. Arb bumper with a body lift - fix
  174. Finally pieced together my lift.
  175. engine seems louder after timing belt and water pump change
  176. Bad luck with advanced auto CV's
  177. 1998 power steering leak
  178. Suggest a source for unusual fasteners for 3rd Gen 4runner?
  179. Front diff bracket bushings - source??
  180. transmission slips after new radiator?
  181. stabilizer bar links
  182. 3RZ-FE Gasket Set
  183. Need help with my hitch wires
  184. New roof rack and gas can holder completed
  185. Wheeling Mistakes With Lockers
  186. Transmission Rebuild Time?
  187. Will helper springs help?
  188. 1999 3RZ-FE 2.7 L - What's the best way to remove the EGR / EGR Pipe ?
  189. Operation Sparkling Wiggles - The Debage Chronicles
  190. 98 4runner steal
  191. Diff Drop question
  192. lower ball joint write up...
  193. Vibration/Shaking Driving Me Crazy!!!
  194. Rear end, Complete, is this a good price?
  195. Re-gearing... need some advice
  196. P/Ns for 90,000 mile service kit for 3.4
  197. Brake help needed
  198. Oil leak, fix or not?
  199. Bolt-on Sliders
  200. TPS resistance values?
  201. IAC and choke
  202. Creak/Rattle from front of dash area at speed
  203. Easy install front level kit - is there such a thing?
  204. CS-144 alternator install
  205. OME lift kit, medium or heavy duty?
  206. 98 4runner front diff 2 or 4 cross pins?
  207. Yakima LoadWarrior Info (Pics)
  208. 3rd gen. V6 4Runners: best years for supercharging?
  209. Thanks a million!! MAF
  210. 3rd gen. V6 4Runners w/manual transmissions?
  211. p0171 CEL from new Catalytic Converter? Help!
  212. 3RZ Timing Cover Question
  213. Safety lighting on front interior door panel
  214. Marlin Crawler bumper+3rd gen
  215. 98 4runner--suggestions?
  216. new storage box for the runner
  217. coolant leak from under intake manifold
  218. Random rough idle
  219. Help 98 4runners problem
  220. Changing 2.7L fuel filter
  221. how much for a brand new cat
  222. 99 4Runner Intake Silencer Mod GONE WRONG
  223. Got Slammed Into Today... pics
  224. Help me with my 200k Service
  225. TJ coils for a 2000 Tacoma?
  226. starting issue
  227. 99 Coolant Leak
  228. Dual Dome Lights
  229. H4 HID Conversion now no HI beam indicator??
  230. Misfire, buts its Not what you think...
  231. OME 883 Question
  232. 99 4 Runner Antennae
  233. 87 octane with methanol injection
  234. Tune up parts ??
  235. 1999 4Runner turns over but doesn't catch
  236. budget throttle response?
  237. i want to install cruise control
  238. 99 Tacoma Prerunner Valve + Coolant = Blown Head Gasket?
  239. 1998 3.4l overheating? I NEED HELP!
  240. FYI...viberations at around 50+ MPH...driveshaft
  241. Jack points and jack stand locations 2WD and 4WD 1999 4runner
  242. Did up some limb risers
  243. Help with 99 4Runner Fuel Tank Drop-Electrical Connections
  244. New to the site, New 4Runner, already doing mods...PICS
  245. Check codes and VSC lights on after tranny install?? Any ideas??
  246. 1998 4runner Gauge Back Lighting
  247. Steering rack leaking time for a rebuild
  248. 3.4L Stumble or miss, very intermittant
  249. Crank position sensor voltage question
  250. Need new radiator...got an idea
